Part 3 Testing and advanced configuration of Crowdsec with Pangolin
Part 3: Testing and Advanced Configuration of CrowdSec with Pangolin
Use with your own discretion. version 1.6.6 has auto allowlist command also please refer crowdsec documentation.
1. Testing CrowdSec Integration
1.1 Initial Testing Setup
# Verify CrowdSec is processing logs
docker exec -it crowdsec cscli metrics
# Check current decisions
docker exec -it crowdsec cscli decisions list
# Monitor live logs
docker exec -it crowdsec tail -f /var/log/crowdsec.log
1.2 Testing with Sample Data
Test different scenarios:
# Test ban scenario
docker exec crowdsec cscli decisions add -i 192.168.1.1 -t ban -d 1h
# Test captcha scenario
docker exec crowdsec cscli decisions add --ip 192.168.1.2 --type captcha -d 1h
# Verify decisions were added
# Test removing decisions
docker exec crowdsec cscli decisions delete -i 192.168.1.1
1.3 Log Analysis
# Analyze Traefik logs
docker exec -it crowdsec cscli explain /var/log/traefik/traefik.log
# Check AppSec metrics
curl http://localhost:6060/metrics | grep appsec
# Monitor Traefik logs
docker compose logs traefik -f
2. Advanced Configuration
2.1 Custom Scenarios
Create /config/crowdsec/scenarios/custom-scenarios.yaml:
type: trigger
description: "Ban IPs attempting brute force"
filter: "evt.Meta.log_type == 'traefik_access'"
groupBy: evt.Meta.source_ip
distinctBy: evt.Meta.http_path
capacity: 5
leakSpeed: "10s"
blackhole: 1m
labels:
  service: traefik
  type: bruteforce
  remediation: true
2.2 Custom Parsers
Create /config/crowdsec/parsers/custom-parser.yaml:
description: "Custom parser for Traefik logs"
onsuccess: next_stage
pattern_syntax: "LTSV"
patterns:
  - CUSTOM_TRAEFIK_LOG time=%{TIMESTAMP_ISO8601:timestamp}\tlevel=%{WORD:level}\tmsg=%{GREEDYDATA:message}
nodes:
  - grok:
      pattern: CUSTOM_TRAEFIK_LOG
statics:
  - meta: log_type
    value: traefik_access
  - meta: service
    value: traefik
2.3 Custom Collections
Create /config/crowdsec/collections/custom-collection.yaml:
parsers:
  - custom-traefik-parser
scenarios:
  - custom-ban-bruteforce
descriptions:
  custom-ban-bruteforce: "Ban IPs attempting brute force attacks"
3. Monitoring and Metrics
3.1 Prometheus Metrics
Update /config/traefik/traefik_config.yml:
metrics:
  prometheus:
    entryPoint: metrics
    addServicesLabels: true
    addEntryPointsLabels: true
    buckets:
      - 0.1
      - 0.3
      - 1.2
      - 5.0
3.2 Dashboard Integration
Enable metrics in CrowdSec configuration:
prometheus:
  enabled: true
  level: full
  listen_addr: 0.0.0.0
  listen_port: 6060
4. Advanced Security Configurations
4.1 Rate Limiting
Update Traefik dynamic config:
http:
  middlewares:
    rate-limit:
      rateLimit:
        average: 100
        burst: 50
        period: 1m
    custom-security:
      chain:
        middlewares:
          - rate-limit
          - crowdsec
4.2 IP Whitelisting
Update CrowdSec configuration:
whitelist:
  ips:
    - "10.0.0.0/8"
    - "172.16.0.0/12"
    - "192.168.0.0/16"
  cidrs:
    - "100.89.137.0/20"
5. Advanced Troubleshooting
5.1 Debug Mode
Enable debug logging:
# Set CrowdSec to debug mode
docker exec -it crowdsec cscli config show --debug
# Enable debug logging in Traefik
sed -i 's/level: "INFO"/level: "DEBUG"/' /config/traefik/traefik_config.yml
5.2 Testing Tools
# Test bouncer connectivity
curl -X GET http://localhost:9090/v1/decisions -H "X-Api-Key: <your_bouncer_key>"
# Test AppSec WAF
curl -X POST http://localhost:7422/verify -H "Content-Type: application/json" -d '{"request":{"uri":"/test"}}'
# Verify log parsing
docker exec -it crowdsec cscli parsers debug --file /var/log/traefik/access.log
5.3 Common Issues and Solutions
  1. Bouncer Authentication Issues:
# Regenerate bouncer key
docker exec crowdsec cscli bouncers delete traefik-bouncer
docker exec crowdsec cscli bouncers add traefik-bouncer
  1. Log Processing Issues:
# Check acquisition status
docker exec crowdsec cscli metrics
  1. Network Connectivity:
# Test internal networking
docker exec -it crowdsec ping traefik
docker exec -it crowdsec ping pangolin
6. Performance Tuning
6.1 CrowdSec Optimization
Update /config/crowdsec/config.yaml:
crowdsec_service:
  parser_routines: 4
  acquisition_path: /etc/crowdsec/acquis.yaml
  acquisition_dir: /etc/crowdsec/acquis.d
db_config:
  flush:
    max_items: 5000
    max_age: 7d
  use_wal: true
6.2 Traefik Optimization
Update dynamic configuration:
http:
  middlewares:
    crowdsec:
      plugin:
        crowdsec:
          updateIntervalSeconds: 10
          defaultDecisionSeconds: 10
          httpTimeoutSeconds: 5
Next Steps
  1. Implement AppSec WAF (Part 4)
  2. Configure captcha protection
  3. Set up alerts and notifications
  4. Monitor and tune performance
Part 4 Implementing CrowdSec AppSec WAF with Pangolin - Networking - HHF Technology Forums
I think the “4.2 IP Whitelisting” directive is not correct in /config/crowdsec/config.yaml, as it gives an error when running: docker exec -it crowdsec cscli config show --debug.
Does anyone know how to define the whitelist in this case?
Setting
Componente Tipo Imagen VersiĂłn URL
Pangolin fosrl/pangolin 1.1.0 Releases · fosrl/pangolin · GitHub
Gerbil fosrl/gerbil 1.0.0 Releases · fosrl/gerbil · GitHub
Newt Cliente 1.1.2 Releases · fosrl/newt · GitHub
Traefik traefik v3.3.3 Releases · traefik/traefik · GitHub
Plugins Traefik
badger v1.0.0 Releases · fosrl/badger · GitHub
crowdsec-bouncer-traefik-plugin v1.3.5 Releases · maxlerebourg/crowdsec-bouncer-traefik-plugin · GitHub
geoblock v0.3.2 Releases · PascalMinder/geoblock · GitHub
Crodwsec crowdsecurity/crowdsec v1.6.8 Releases · crowdsecurity/crowdsec · GitHub
Headscale headscale/headscale 0.25.1 Releases · juanfont/headscale · GitHub
Headplane headplane 0.5.5 Tags · tale/headplane · GitHub
Prometheus prom/prometheus v2.53.4 Releases · prometheus/prometheus · GitHub
Grafana grafana/grafana 11.6.0 Releases · grafana/grafana · GitHub
Thanks,
Odon
use basic whitelist first then you can opt for advance ones
description: "Whitelist events from my ip addresses"
whitelist:
  reason: "my ip ranges"
  ip:
    - "80.x.x.x"
description: "Allowlist events from Plex"
filter: "evt.Meta.service == 'http' && evt.Meta.log_type in ['http_access-log', 'http_error-log']"
whitelist:
  reason: "Plex Allowlist"
  expression:
   - evt.Meta.http_status in ['200', '404'] && evt.Meta.http_verb == 'GET' && evt.Meta.http_path startsWith '/video/:/transcode/'
   - evt.Meta.http_status == '200' && evt.Meta.http_verb == 'GET' && evt.Meta.http_path startsWith '/photo/:/transcode/'
   - evt.Meta.http_status in ['200', '400'] && evt.Meta.http_verb == 'GET' && evt.Meta.http_path startsWith '/:/timeline'
   - evt.Meta.http_status == '200' && evt.Meta.http_verb == 'GET' && evt.Meta.http_path matches '^/library/metadata/\\d+'
   - evt.Meta.http_status == '200' && evt.Meta.http_verb == 'GET' && evt.Meta.http_path == '/status/sessions'
   - evt.Meta.http_status == '404' && evt.Meta.http_verb == 'GET' && evt.Meta.http_path startsWith '/playQueues/'
   - evt.Meta.http_status == '403' && evt.Meta.http_verb == 'POST' && evt.Parsed.request == '/log' && evt.Parsed.http_args contains 'X-Plex-Product=Plex%20Cast&X-Plex-Version='
   - evt.Meta.http_status == '200' && evt.Meta.http_verb == 'GET' && evt.Meta.http_path startsWith '/music/:/transcode/universal/session/'
#/etc/crowdsec/parsers/s02-enrich/mywhitelist.yaml
description: "Whitelist events from certain countries"
whitelist:
  reason: "whitelist countries"
  expression:
   - evt.Meta.IsoCode in ['AU'] ## Country ISO code in two digit format
description: "Allowlist events from Emby"
whitelist:
  reason: "Emby Allowlist"
  expression:
    - evt.Meta.http_status == '200' && evt.Meta.http_verb == 'GET' && evt.Meta.http_path matches '^/Videos/\\d+/stream'
    - evt.Meta.http_status == '200' && evt.Meta.http_verb == 'GET' && evt.Meta.http_path matches '^/Items/\\d+/Images/.*'
    - evt.Meta.http_status == '200' && evt.Meta.http_verb == 'GET' && evt.Meta.http_path == '/Sessions'
    - evt.Meta.http_status == '200' && evt.Meta.http_verb == 'GET' && evt.Meta.http_path matches '^/Items/\\d+$'
    - evt.Meta.http_status == '200' && evt.Meta.http_verb == 'POST' && evt.Meta.http_path startsWith '/Sessions/Playing/'
description: "Whitelist events from jellyfin"
whitelist:
  reason: "Jellyfin whitelist"
  expression:
   - evt.Meta.http_status in [ '403','204'] && evt.Meta.http_verb == 'POST' && evt.Meta.http_path contains "/Sessions/Playing/Progress" # When playing videos
   - evt.Meta.http_status == '404' && evt.Meta.http_verb == 'GET' && evt.Meta.http_path matches '(?i)^/items/.+?/images/(thumb|primary)' # when browsing on Roku or Swiftfin Clients
I’m referring to the basic whitelist, which in point 4.2 I understand is in /config/crowdsec/config.yaml, above it says:
whitelist:
ips:
- "10.0.0.0/8"
- "172.16.0.0/12"
- "192.168.0.0/16"
cidrs:
- "100.89.137.0/20"
And now you tell me:
description: "Whitelist events from my IP addresses"
whitelist:
reason: "my IP ranges"
ip:
- "80.x.x.x"
That’s what I don’t understand, sorry if it’s too basic, I’m a good student… haha
They have depreciated this feature. So I encourage you to start using allow list. Allowlists | CrowdSec
Why I said basic because we can debug better. Discourse indentation sucks. It’s probably my issue of pasting the code.
