IP Whitelist Shaping Using the Middleware Manager and Pangolin
:locked: Getting Started with the IP Whitelist Shaper Plugin Using Middleware Manager and Pangolin
IP Whitelist Shaper is a Traefik plugin that provides dynamic, admin-approved IP whitelisting. It’s especially useful for environments where temporary access to protected services is required.
This guide will walk you through a minimal working example using Pangolin, Middleware Manager, and the new Plugin Hub.
:loudspeaker: Use the Traefik Dashboard to debug and confirm that your configurations are active.
:rocket: Features At-a-Glance
  • Temporary, time-limited IP access
  • Admin approval via Discord webhook
  • User-friendly request UI (/knock-knock endpoint)
  • Automatic whitelist expiration
  • Smart IP detection (with support for proxies)
:white_check_mark: Step-by-Step: Simple Setup
Step 1: Enable the Plugin
Open the Plugin Hub in Middleware Manager and enable:
experimental:
  plugins:
    ipwhitelistshaper:
      moduleName: github.com/hhftechnology/ipwhitelistshaper
      version: v1.0.7
:camera: Screenshot - the plugin added to traefik_config.yml
Restart Traefik:
docker compose restart traefik
Step 2 (Optional): Set Up Discord Webhook
To receive approval requests in Discord:
  1. Create a server
  2. Create a channel or use an existing one
  3. Click the gear icon > Integrations > Webhooks > Create Webhook
  4. Copy the webhook URL
:camera: Screenshot webhook creation in Discord
Step 3: Add Middleware via Middleware Manager
If not already in templates.yml, add:
- id: "ipwhitelistshaper"
  type: "plugin"
  config:
    ipwhitelistshaper:
      approvalURL: "https://mywebsite.yourdomain.com"
      defaultPrivateClassSources: "true"
      excludedIPs:
      expirationTime: "300"
      ipStrategyDepth: "0"
      knockEndpoint: "/knock-knock"
      notificationURL: "https://discord.com/api/webhooks/webhook-id"
      saveInterval: "30"
      secretKey: ""
      storageEnabled: "false"
      whitelistedIPs:
        - "127.0.0.1/32"
        - "192.168.1.0/24"
        - "10.0.0.0/8"
Restart Middleware Manager:
docker compose restart middleware-manager
Step 4: Create a Resource to Protect
Option A: Use an Existing Resource
Just attach the ipwhitelistshaper middleware.
Option B: Create a Test Resource
Add to docker-compose.yml:
  python-http:
    image: python:3.11-slim
    container_name: python-http
    working_dir: /app
    command: python -m http.server 15000
      - "15000:15000"
Then in Pangolin:
  • Create resource mywebsite.yourdomain.com
  • Point to: python-http port 15000
  • Apply your new ipwhitelistshaper middleware in Middleware Manager
:camera: Screenshot Suggestion: Resource form in Pangolin for mywebsite.yourdomain.com
:globe_with_meridians: Step 5: Testing
:locked: Attempt to Access the Protected Resource
Visit:
You should get a 403 Forbidden.
:sparkles: Visit the Knock Endpoint
Go to:
https://mywebsite.yourdomain.com/knock-knock
You will see:
Approval Required
Your request requires approval.
Validation code: elephant
:camera: Screenshot - Knock-knock page showing validation code
:person:‍:clipboard: Admin Approves the Request
  • The admin receives a Discord message with:
    • IP address
    • Validation code
    • Approval link
Clicking the approval link:
  • Whitelists the IP for 5 minutes (or your configured value)
  • Displays a confirmation page
:camera: Screenshot - Discord webhook message + approval success screen
:balance_scale: Summary
You now have a working, secure IP approval system that:
  • Prevents unauthorized access
  • Empowers admins to grant short-lived access
  • Supports Discord for approval workflows
  • Is fully integrated into Pangolin and Middleware Manager
:folded_hands: Thanks for Following Along
For more complex configurations (e.g., persistent storage, advanced headers, or multi-admin workflows), visit the official GitHub repo.
Happy shaping! :memo:
If The approval URL refers to a specific resource being protected, how is it that we can apply the IP whitelist shaper to multiple resources at the same time? What am I missing?
Use the middleware manager to add the middleware to each resource
Thanks for the reply. I’ve added it to one of my resources via middleware manager, but since the approval url in the JSON config refers to that specific resource (app1.mydomain.com), how does one successfully apply it in middle ware manager to another resource (app2.mydomain.com). I must be missing how to configure the JSON to dynamically apply to the protected resource’s url.
Yes. I see the problem. @hhf.technoloy may know if there’s a workaround
If I might make a suggestion…
This would be incredible if integrated with pangolins email whitelist or perhaps just the normal user login.
Use case:
User is added as an approved user via pangolin authentication
This doesn’t allow login via apps, like for example phone or TV apps
User visits url and logs in via pangolin, which then automatically whitelists their IP
No admin intervention required!
interesting suggestion.. let see what i can do.
I’ve been thinking about this a lot. I want to use pangolin authentication as much as possible. Whitelisting an IP doesn’t bypass pangolin authentication right?
So this idea would really need to be integrated into pangolin, not just traefik? Or does the pangolin IP whitelist under rules also use traefik, so this idea would bypass pangolin authentication as well?
@hhf.technoloy A fork of this script would allow a very quick update to the knock knock to allow pangolin whitelisting as well. A version that could whitelist in pangolin and crowdsec via a visit to a URL would be absolutely KILLER!
Anyone willing to take on the project? I unfortunately do not have the capability.
