Implementing External Authentication in Pangolin Using Tinyauth and the Middleware Manager
Pangolin now supports flexible authentication options through the Middleware-manager. While Authentik and Authelia are popular options, this guide shows how to implement external authentication using Tinyauth — a lightweight, rising middleware project. :tada:
:puzzle_piece: Prerequisite: This article assumes you’ve already implemented Pangolin’s Middleware Manager. If not, go through that guide first.
:hammer_and_wrench: Prerequisites
  • Pangolin deployed with the Middleware Manager
  • Docker and Docker Compose set up on your VPS
  • A registered domain (e.g. mydomain.com) with a subdomain for Tinyauth (e.g. tinyauth.mydomain.com) pointing to your VPS
  • Basic familiarity with managing Docker and editing YAML files
:spouting_whale: Step 1: Add Tinyauth to Docker Compose
In your existing Docker Compose setup, add the following service:
  tinyauth:
    image: ghcr.io/steveiliop56/tinyauth:v3
    container_name: tinyauth
      - PORT=10000
      - SECRET=${TINYAUTH_SECRET_KEY}
      - APP_URL=https://tinyauth.mydomain.com
      - LOG_LEVEL=0
      - USERS_FILE=users_file
      - ./config/tinyauth/users:/tinyauth/users_file
:file_folder: Step 2: Create the Secret Key
Create a .env file in the same folder as your docker-compose.yml file with this line:
TINYAUTH_SECRET_KEY=your-generated-secret-key
You can generate the key using:
openssl rand -base64 32 | tr -dc 'a-zA-Z0-9' | head -c 32
:bust_in_silhouette: Step 3: Create User Credentials
Create a new folder in the pangolin config folder called tinyauth
Inside ./config/tinyauth/, create a users file with the login credentials.
Use the htpasswd tool to generate secure bcrypt hashes. Note: escape $ characters as $$.
echo $(htpasswd -nB test) | sed -e s/\\$/\\$\\$/g
Example content for a test/test login:
test:$$2y$$05$$BsP6eSe4FIAqhhtGO8EUEuZWkdgWtU9NdqrJopxicTVvqxMQZ6BYu
:warning: Alternatively, credentials can be passed directly via the USERS environment variable
You can get more info on the Tinyauth set up including integration of OAuth to Github in this Jim’s garage video).
NOTE: THE FOLLOWING CHANGES COULD RESULT IN BREAKING CHANGES. PLEASE BE CAREFUL.
:test_tube: Step 4: Expose the Tinyauth Port
Update your gerbil service in Docker Compose to expose the Tinyauth port:
      - 10000:10000  # Exposes Tinyauth
:gear: Step 5: Add Traefik Routing Rules
Edit your Traefik dynamic configuration file (e.g., dynamic_config.yml) to include Tinyauth routes.
:green_circle: HTTP Redirect Router
  tinyauth-router-redirect:
    rule: "Host(`tinyauth.mydomain.com`)"
    service: tinyauth-service
    entryPoints:
      - web
    middlewares:
      - redirect-to-https
:locked_with_key: HTTPS Router
  tinyauth:
    entryPoints:
      - websecure
    tls:
      certResolver: letsencrypt
:door: Service Entry
  tinyauth-service:
    loadBalancer:
      servers:
        - url: "http://tinyauth:10000"
:brick: Step 6: Define Middleware Template
In your Middleware Manager templates file (middleware/templates.yml), add a new entry:
  - id: tinyauth
    type: forwardAuth
    config:
      address: http://tinyauth:10000/api/auth/traefik
:rocket: Step 7: Start Services
Start everything:
docker compose up -d
Check services are running:
sudo lsof -i -P -n | grep LISTEN
:magnifying_glass_tilted_left: Screenshot: this is the command and the result with :10000 showing in the list.
In your browser, open an incognito tab and visit:
You should see the Tinyauth login page.
:test_tube: Step 8: Test with a Simple App
Set up a basic app (like a Python web server):
python3 -m http.server 8000
Expose it with Pangolin as a resource, e.g.:
https://helloworld.mydomain.com
Verify it works without authentication first.
:camera_with_flash: Screenshot Here’s my URL unauthenticated.
:shield: Step 9: Attach Middleware in Pangolin
  1. Open the Pangolin Middleware Manager UI.
  2. Navigate to the Middlewares tab.
    • Confirm you see Tinyauth listed.
  3. Return to the Dashboard and click Manage next to the resource you want to protect.
  4. Under Attached Middlewares, click Add Middleware.
  5. Select Tinyauth (forwardAuth) and click Add Middlewares.
:camera_with_flash: Screenshot: Here’s the middleware list and the form where you attach Tinyauth.
:white_check_mark: Step 10: Final Test
Open your protected resource in an incognito window:
https://resourcename.mydomain.com
You should be redirected to https://tinyauth.mydomain.com for login. After authenticating, you’ll return to the protected app.
:pushpin: Summary
In this article, we walked through how to set up the blazing fast, minimalist Tinyauth as a forward auth provider for Pangolin. With just a few steps and clever integration using the Middleware Manager, you now have a lightweight and secure authentication layer protecting your self-hosted apps. There are more integrations to come!!!
:folded_hands: Thanks for Reading!
Tinyauth is a fantastic project from an incredibly talented young developer — it’s inspiring to see such innovation in the open-source space. If you found this guide helpful, consider exploring more of what Pangolin has to offer, and feel free to share your feedback or improvements in the Pangolin forum.
Happy self-hosting! :laptop::locked:
Thanks a lot! Is there a step by step guide like this for Authelia? I have a hard time setting it.
Hi.
I thought we had one. But can’t see to find it. Looking back on my notes it’s very straightforward
  1. deploy Authelia docker container
authelia:
              image: authelia/authelia
              container_name: authelia
                - ./config:/config
                - /etc/letsencrypt:/certs:ro
                - "9091:9091"
              expose:
                - 9091
              labels:
                - "traefik.enable=true"
                - "traefik.http.routers.authelia.entrypoints=websecure"
                - "traefik.http.routers.authelia.rule=Host(`authelia.yourdomain.com`)"
                - "traefik.http.routers.authelia.tls=true"
                - "traefik.http.routers.authelia.tls.certresolver=myresolver"
                - "traefik.http.routers.authelia.service=authelia"
                - "traefik.http.services.authelia.loadbalancer.server.port=9091"
                - "traefik.http.routers.authelia.middlewares=redirect-to-https"
                - "traefik.http.middlewares.redirect-to-https.redirectscheme.scheme=https"
                - TZ=Europe/London
  1. apply the middleware to your protected resource
        authelia:
            forwardAuth:
                address: "https://authelia.yourdomain.com/api/verify?rd=https://authelia.yourdomain.com"
                authResponseHeaders:
                    - Remote-User
                    - Remote-Groups
                    - Remote-Name
                    - Remote-Email
                trustForwardHeader: true
Thanks! What about the files mentioned there :
Standalone Example
The following examples are Docker Compose deployments with just Authelia and no bundled applications or proxies.
It expects the following:
They don’t seem to autogenerate. I should create them?
Do you use AWS? Here’s a guide for setting up auth servers on AWS.
Oracle free tier. But I’ll try to infer from thee AWS guide. Thanks!
