Example networking sidecar ingress containers for Cloudflare Argo, Wireguard, Tailscale, LetSencrypt, Caddy, and SOCKS/SSH tunnel containers in Docker Compose.
Goes well with these docker-compose database container examples:
version: '2.4'
demo:
hostname: demo
image: nginx:alpine # Your image goes here
expose:
- 80
cpus: 2
mem_limit: 4096m
restart: on-failure
tailscale:
# https://rnorth.org/tailscale-docker/
# $ docker-compose up
# $ docker-compose exec tailscale tailscale up
# To authenticate, visit: https://login.tailscale.com/a/SOME_HEX_CODE
image: tailscale:1.76.1
build: https://github.com/tailscale/tailscale.git#v1.76.1
command: tailscaled
cap_add:
- NET_ADMIN
# - SYS_MODULE # usually not needed, depends on host OS
network_mode: 'service:demo'
- 41641:41641/udp
- /dev/net/tun:/dev/net/tun
- ./data/tailscale:/var/lib/tailscale
cpus: 2
mem_limit: 4096m
restart: on-failure
wireguard:
# https://hub.docker.com/r/linuxserver/wireguard
image: linuxserver/wireguard
sysctls:
- net.ipv4.conf.all.src_valid_mark=1
cap_add:
- NET_ADMIN
- SYS_MODULE
- ./etc/wireguard/wg0.conf:/config/wg0.conf
cpus: 2
mem_limit: 4096m
restart: on-failure
argo:
# https://hub.docker.com/r/cloudflare/cloudflared
image: cloudflare/cloudflared
command: tunnel --no-autoupdate --retries 8 --hostname demo.hhf.technology http://demo:80
depends_on:
- demo
# Get this cert from https://www.cloudflare.com/a/warp
- ./data/argo/cert.pem:/etc/cloudflared/cert.pem:ro
cpus: 2
mem_limit: 4096m
restart: on-failure
letsencrypt:
# https://github.com/wmnnd/nginx-certbot
image: certbot/dns-cloudflare
entrypoint: |
while true; do \
certbot certonly \
--keep-until-expiring \
--dns-cloudflare \
--dns-cloudflare-credentials /etc/letsencrypt/cloudflare.ini \
--domains demo.zervice.io; \
sleep 43200; \
done
- ./etc/letsencrypt:/etc/letsencrypt
cpus: 2
mem_limit: 4096m
restart: on-failure
caddy:
# https://hub.docker.com/_/caddy
image: caddy:2.8.4-alpine
command: caddy reverse-proxy --from demo.hhf.technology --to demo:80
- '80:80'
- '443:443'
cpus: 2
mem_limit: 4096m
restart: on-failure
cloudflare:
image: oznu/cloudflare-ddns:latest
- API_KEY=xxxxxxx
- ZONE=hhf.technology
- SUBDOMAIN=demo
- PROXIED=true
ssh:
# https://hub.docker.com/r/linuxserver/openssh-server
image: linuxserver/openssh-server
command: ssh -N -T -R 0.0.0.0:80:demo:80 -p 44 root@demo.hhf.technology
- ./data/keys:/root/.ssh
