Guide to database container setups for PostgreSQL, MariaDB, Redis, Memcached, MongoDB, Neo4j, Hasura GraphQL, CockroachDB, and TiDB in Docker Compose
Example database container setups for PostgreSQL, MariaDB, Redis, Memcached, MongoDB, Neo4j, Hasura GraphQL, CockroachDB, and TiDB in Docker Compose
Goes well with these docker-compose networking/ingress container examples:
Guide to Networking sidecar ingress containers for Cloudflare Argo, Wireguard, Tailscale, LetSencrypt, Caddy, and SOCKS/SSH tunnel containers in Docker Compose
version: '2.4'
    postgres:
        # easy upgrades: https://github.com/tianon/docker-postgres-upgrade
        # admin shell: docker-compose exec postgres env PGPASSWORD=examplepass psql -U admin postgres
        # dump backup: docker-compose exec postgres env PGPASSWORD=examplepass pg_dumpall -U admin | pv | gzip -9 > ./data/backups/$(date +%s)__all.sql.gz
        image: postgres:alpine
        expose:
            - 5432
            POSTGRES_USER: admin
            POSTGRES_PASSWORD: examplepass
            # optional, restore from the latest backup on first run
            # - ./data/backups/latest.sql:/docker-entrypoint-initdb.d/dump.sql
            - ./data/postgres:/var/lib/postgresql/data
        cpus: 2
        mem_limit: 4096m
    mariadb:
        image: mariadb:latest
        expose:
            - 3306
            MYSQL_DATABASE: someapp
            MYSQL_USER: someapp
            MYSQL_PASSWORD: examplepass
            MYSQL_RANDOM_ROOT_PASSWORD: '1'
            - ./data/mariadb:/var/lib/mysql
        cpus: 2
        mem_limit: 4096m
    redis:
        image: redis:alpine
        command: redis-server --appendonly yes
        expose:
            - 6379
            - ./data/redis:/data
    memcached:
        image: memcached:latest
        expose:
            - 11211
    mongodb:
        image: mongo:latest
        expose:
            - 27017
            - ./data/mongodb:/data/db
            MONGO_INITDB_ROOT_USERNAME: root
            MONGO_INITDB_ROOT_PASSWORD: somestrongpassword
    neo4j:
        image: neo4j:latest
        expose:
            - 7474   # HTTP API
            - 7687   # BOLT API
            NEO4J_AUTH: none
            - ./data/neo4j:/data:Z
    hasura:
        image: hasura/graphql-engine:latest
        expose:
            - 8080   # GraphQL HTTP API
        depends_on:
            - postgres
            HASURA_GRAPHQL_DATABASE_URL: postgres://postgres:postgrespassword@postgres:5432/postgres
            HASURA_GRAPHQL_ENABLE_CONSOLE: "true"  # set to false on prod
            HASURA_GRAPHQL_DEV_MODE: "true"        # set to false on prod
            HASURA_GRAPHQL_ENABLED_LOG_TYPES: startup, http-log, webhook-log, websocket-log, query-log
            HASURA_GRAPHQL_ADMIN_SECRET: someadminpasswordhere
    cockroachdb:
        image: cockroachdb/cockroach:latest
        command: start --insecure
        hostname: cockroachdb_node_1
        expose:
            - 26257  # inter-cluster communication
            - 8080   # DB console web UI
            - ./data/cockroachdm:/cockroach/cockroach-data
    tidb:
        image: pingcap/pd:latest
        hostname: tidb_node_1
        expose:
            - 2379
            - ./etc/tidb/pd.toml:/pd.toml:ro
            - ./data/tidb:/data
            - ./logs/tidb:/logs
        command:
            - --name=tidb_node_1
            - --client-urls=http://0.0.0.0:2379
            - --peer-urls=http://0.0.0.0:2380
            - --advertise-client-urls=http://tidb_node_1:2379
            - --advertise-peer-urls=http://tidb_node_1:2380
            - --initial-cluster=tidb_node_1=http://tidb_node_1:2380,pd1=http://tidb_node_2:2380,pd2=http://tidb_node_3:2380
            - --data-dir=/data/tidb_node_1
            - --config=/pd.toml
            - --log-file=/logs/pd0.log
