Why Direct IP Resolution is Best Practice for Reverse Proxies
When configuring DNS for reverse proxies like Traefik or Nginx Proxy Manager, using direct IP resolution through A records (IPv4) and AAAA records (IPv6) for both root domains (@) and wildcard subdomains (*) emerges as a clear best practice. Here’s why this approach stands out and why you should consider implementing it in your infrastructure.
The Power of Direct Resolution
DNS resolution is a critical component of web infrastructure, and its efficiency can significantly impact your application’s performance. When you use A/AAAA records, you create a direct mapping between your domain name and IP address. This directness brings several advantages:
  • Immediate resolution without additional lookups
  • Reduced latency in request processing
  • Simplified DNS chain that’s easier to troubleshoot
  • Better performance compared to CNAME-based solutions
Wildcard Subdomains: Flexibility Meets Simplicity
The wildcard subdomain approach (*.yourdomain.com) particularly shines when paired with A/AAAA records. This combination provides:
  • Uniform resolution across all subdomains
  • Simplified management through a single record
  • Elimination of complex CNAME chains
  • Dynamic subdomain support without additional configuration
Reverse Proxy Integration
Modern reverse proxies like Traefik and Nginx Proxy Manager are designed to work seamlessly with this setup. They rely on HTTP Host headers for routing, making direct IP resolution an ideal match. The benefits include:
  • Clean separation between DNS resolution and request routing
  • Optimized SSL/TLS certificate management
  • Streamlined traffic flow from client to service
  • Reduced points of failure in the request chain
Operational Benefits
From an operations perspective, this approach offers numerous advantages:
  • Simplified troubleshooting processes
  • Reduced complexity in DNS management
  • Easy IP address updates when needed
  • Better visibility into the resolution chain
Implementation Best Practices
When implementing this approach, consider the following recommendations:
  1. Configure both IPv4 and IPv6 records for maximum compatibility
  2. Ensure your reverse proxy is properly configured to handle wildcard domains
  3. Monitor DNS propagation after making changes
  4. Keep TTL values appropriate for your update frequency
Real-World Impact
This configuration has proven particularly valuable in modern cloud-native environments where:
  • Services are frequently deployed and updated
  • Multiple subdomains need consistent handling
  • Performance optimization is crucial
  • Infrastructure needs to remain flexible and maintainable
The use of A/AAAA records for both root and wildcard domains represents more than just a configuration choice—it’s an architectural decision that brings tangible benefits to your infrastructure. By implementing this approach, you’ll build a more robust, efficient, and manageable system that’s well-prepared for modern web hosting challenges.
Remember: While DNS configuration might seem like a minor detail, it forms the foundation of your web infrastructure. Getting it right from the start pays dividends in performance, reliability, and maintainability.
