To integrate Immich with Authentik, follow these step-by-step instructions:
Step 1: Set Up Authentik
Create a New Client Application:
- Log in to your Authentik instance and navigate to the Admin Interface.
- Go to Applications > Providers and click on Create.
- Choose OpenID Connect as the provider type.
- Fill in the required details:
- Name: e.g., “Immich Provider”.
- Client ID: Note this down for later use.
- Client Secret: Note this down as well.
- Set the Authorization Flow to “Implicit” if you want users to log in without consent.
Configure Redirect URIs:
- Under redirect URIs, add the following:
app.immich:/ http://[YOUR_DOMAIN_OR_SERVER_IP]:[PORT]/auth/login http://[YOUR_DOMAIN_OR_SERVER_IP]:[PORT]/user-settings - Save your changes.
Step 2: Configure Immich
Access Immich Settings:
Navigate to your Immich instance and go to the System Settings.
Find the OAuth Authentication section.
Input OAuth Details:
Enter the following details:
- Authorization URL: This is typically your Authentik instance URL.
- Access Token URL: Same as above.
- Client ID: Use the one you noted from Authentik.
- Client Secret: Use the one you noted from Authentik.
- Scopes: Include
openidand any other necessary scopes.
Set Up Redirect URIs in Immich:
- Ensure that the redirect URIs match those configured in Authentik.
#IMPORTANT: #Since auto lunch is enabled, immich won't ever ask you to login back again, it #will #redirect you to authentik so you can enter your credentials there. #So if you want to log back in with your immich Administrator account then you #have to use the following URL: http://debian-tests.home.lan:1002/auth/login?autoLaunch=0
Step 3: Create Users and Test
Create Users in Authentik:
- Go to Directory > Users > Create in Authentik and add users as needed.
Testing the Integration:
- Open your browser and navigate to your Immich instance.
http://[YOUR_DOMAIN OR SERVER_IP_PLUS_PORT]/ # sample: http://127.0.0.1:1002/ -or- http://localhost:1002/ -or- https://photos.my-amazing-domain.com/-
You should be redirected to Authentik for authentication.
Log in using one of the user accounts created in Authentik.
By following these steps, you should be able to successfully integrate Immich with Authentik for a seamless authentication experience.
I obviously didn’t include a bunch of stuff like how I configure groups in authentik so that certain users can access the photos app and some others don’t. Or how do I configure authentik to talk to google, because I don’t wan’t to create accounts for all my family if they can just use their google accounts.
Will post everything one by one dont worry.
