usulnet is a Portainer-style web UI for managing Docker, but written
as a single Go binary and shipped under AGPL with no biz gating. v26.5.2
is the release where the “privacy + security” tagline earns its keep.
What’s new vs v26.5.1:
Privacy + security
- Shodan recon connector (bring your own key) — joins HIBP for OSINT
scans against identifiers you own (with ownership verification). - L7 egress filter — in-process forward proxy with per-host allow/deny
policies. Default-deny, audit log of denials. - YARA scanner against host files + container paths (ships
linux-elf-suspicious ruleset). - Container forensics snapshot — one-click memory dump, process tree,
open FDs, network connections, as a verifiable tarball. - Marketplace honeypots — Cowrie, Dionaea, Endlessh, one-click
deployable. - Tor SOCKS5 proxy marketplace app for individual-workload anonymisation.
Operator UX
- Host-side CLI binary (you run
usulnet containers lsfrom your
laptop against a remote server). - Sidebar regrouped 9 → 7 sections (Compute / Operations / Security /
Privacy / Platform / Admin / Help). - First-run wizard for password change + host attach.
- Uniform empty-states across 12 modules. a11y landmarks.
Recon sandbox
- recon-toolkit container rebased on Arch (mat2, exiftool, yara,
holehe, h8mail, oletools, pdfid). Weekly rebuild so the toolset
stays current.
Reliability
- Smoke E2E in CI boots the actual compose stack and walks the
sidebar before any release. - govulncheck on every PR with empirically-pinned allowlist
justifications. - Multi-arch images (amd64 + arm64) on GHCR and Docker Hub.
Zero breaking changes, no new external port, no new bind mount,
no new capability, no call-home.
Honestly deferred to v26.6: full per-page light-theme audit,
frontend animations, trufflehog volume secrets scanner, BlackArch
overlay for the recon-toolkit.
Install: GitHub - fran-olivares/usulnet: Open-source Docker infrastructure platform. One web UI — containers, security, DNS, VPN, monitoring, backups, reverse proxy, terminal, and multi-node orchestration. Replace a dozen tools with one. · GitHub
Release notes: Releases · fran-olivares/usulnet · GitHub
