Using NGINX to prevent DDoS Attacks
Nginx, a highly popular server system for Unix machines, comes with enough built-in functionality to greatly limit the effectiveness of DDoS attacks. These features could handle a DDoS attack by regulating the incoming traffic and by controlling the traffic as it is proxied to backend services.
Before you change any settings, make sure you make a quick backup of your server’s configuration. The following command works for this:
sudo cp /etc/nginx/nginx.conf /etc/nginx/nginx.conf.backup-original
Nginx worker connections
One of the important parameters that we tweak is the number of worker process and number of worker connections in the Nginx configuration file /etc/nginx/nginx.conf.
We’ll gradually adjust the worker process and worker connections to a higher or lower value for handling DDoS attacks.
events {
worker_connections 50000;
This setting allows each of the worker process to handle up to `50000` connections.
Limiting requests rate
Among the many useful tactics worth trying for staving off DDoS attacks, one of the simplest and most effective is the limiting of incoming traffic rates. You can limit the rate at which NGINX accept incoming requests to a normal value for your service from a particular client IP address within a certain period.We tweak the limit_req_zone directive in the Nginx configuration file to rate limit requests.
limit_req_zone $binary_remote_addr zone=one:1m rate=30r/m;
server {
location /wp_login.php {
limit_req zone=one;
This example creates a memory area called one, that can hold up to 16,000 (1m) unique IPs, and the 30r/m means that only 30 requests per minute are allowed. Then, we use the limit_req directive to rate limit the connections to a particular location or file, in this case wp_login.php.
Limiting number of connections
You can limit the number of connections that can be opened by a single client IP address,Here we tweak the limit_conn_zone and limit_conn directives to limit the number of connections per IP address.
limit_conn_zone $binary_remote_addr zone=two:1m;
server {
location / {
limit_conn two 10;
This example creates a memory zone called two to store requests for the specified key, in this case the client IP address, `$binary_remote_addr`. Then the `limit_conn` directive sets a maximum of 10 connections from each client IP address.
Timeout parameters
Slow connections can represent an attempt to keep connections open for a long time. As a result, the server can’t accept new connections.```nginx server { client_body_timeout 5s; client_header_timeout 5s; } ```
In this example, the `client_body_timeout` directive defines how long Nginx is waiting between the writes of the client body and `client_header_timeout` means how long Nginx is waiting between the writes of client header. Both are set to 5 seconds.
Limit requests size
Similarly, large buffer values or large HTTP requests size make DDoS attacks easier. So, we limit the following buffer values in the Nginx configuration file to mitigate DDoS attacks.client_body_buffer_size 200K;
client_header_buffer_size 2k;
client_max_body_size 200k;
large_client_header_buffers 3 1k;
Blacklist IP adresses
If you can identify the client IP addresses being used for an attack, you can blacklist them with the deny directive so that NGINX and NGINX Plus do not accept their connections or requests.```nginx location / { deny 123.123.123.3; deny 123.123.123.0/24; } ```
In this example, the first deny directive blocks an specific IP, and the second deny, blocks a complete range of IP’s.
Whitelist IP adresses
If access to your website or application is allowed only from one or more specific sets or ranges of client IP addresses, you can use the allow and deny directives together to allow only those addresses to access the site or application.location / { allow 123.123.123.3; deny all; }
You can restrict access to only addresses in a specific local network, Here, the deny all directive blocks all client IP addresses that are not in the range specified by the allow directive.
Blocking access to a file or location
It is possible to use Nginx to completely block the access to a file or a location. For example if you notice that the file register.php is the target of the attack, you can completely block the access to this file.location /register.php { deny all; return 444; }
This will drop all request that try to reach this file. The code 444 closes the connection without response.
Enable sysctl based protection
Additionally we can tweak kernel and system variables in our server. Edit the file /etc/sysctl.conf, and set these two lines to 1 like this:net.ipv4.conf.all.rp_filter = 1 net.ipv4.tcp_syncookies = 1
The first parameter enables protection against IP spoofing, and the second allows TCP SYN cookie protection.
Nginx as load balancer
When Nginx is used as load balancer, it is possible to adjust parameters to limit the connections number for each server:upstream domain { server 123.123.123.1:80 max_conns=100; server 123.123.123.2:80 max_conns=100; queue 20 timeout=10s; }
Here the max_conns directive specifies the number of connections Nginx can open up for the server. The queue directive limits the number of requests that have been queued when all servers in this group have reached the connection limit. Finally, the timeout directive specifies how long a request can be retained in the queue.
