Unlocking Your Home Lab's Full Potential with Pangolin-Deep Dive- Part 1
graph TB
    subgraph Internet
        VPS[VPS with Pangolin]
        CF[DNS Provider]
    end
    subgraph "Home Network"
        subgraph "Home Server"
            NEWT[Newt Client]
            subgraph "Hypervisor (Proxmox/Unraid/TrueNAS)"
                VM1[Web Apps]
                VM2[Media Server]
                VM3[Home Automation]
                CT1[Container Services]
            end
        end
    end
    Router -- "No Port Forward Needed" --> Internet
    VPS <--> CF
    VPS <-- "WireGuard Tunnel" --> NEWT
    NEWT --> VM1
    NEWT --> VM2
    NEWT --> VM3
    NEWT --> CT1
    style VPS fill:#f9f,stroke:#333,stroke-width:4px
    style NEWT fill:#bbf,stroke:#333,stroke-width:2px
Unlocking Your Home Lab’s Full Potential with Pangolin
Part 1: Understanding Pangolin and Its Benefits for Home Users
Pangolin is a game-changing self-hosted tunneled reverse proxy system that solves many common challenges faced by home lab enthusiasts. Think of it as your own private Cloudflare Tunnels, but with complete control over your infrastructure. For home users running Proxmox, Unraid, or TrueNAS, Pangolin offers a powerful way to securely expose your services to the internet without the typical headaches of port forwarding, dynamic DNS, or complex VPN setups.
Part 2: Common Home Lab Challenges Solved by Pangolin
Traditional home lab setups often face several hurdles that Pangolin elegantly addresses:
  1. CGNAT and Port Forwarding: Many ISPs use Carrier-Grade NAT or block port forwarding, making it difficult to access your services from outside. Pangolin bypasses this entirely by establishing an outbound tunnel.
  2. Dynamic IP Addresses: Home internet connections typically have dynamic IPs that change periodically. Pangolin eliminates this concern by maintaining a stable connection to your VPS.
  3. Security Concerns: Opening ports on your router creates potential security vulnerabilities. Pangolin keeps your network closed while still allowing secure access to specific services.
  4. Authentication Management: Managing different authentication systems for various services can be cumbersome. Pangolin provides centralized authentication and access control.
Part 3: Real-World Implementation Examples
Let’s explore three practical scenarios where Pangolin shines in a home lab environment:
Scenario 1: Media Server Access
Imagine you’re running a Plex or Jellyfin server on Unraid. Instead of opening port 32400 and dealing with remote access settings, you can:
  • Deploy Newt on your Unraid server
  • Create a resource in Pangolin pointing to your media server
  • Access it securely through a subdomain like plex.yourdomain.com
Scenario 2: Home Automation Dashboard
For a Home Assistant installation running in Proxmox:
  • Configure Newt to connect to your Pangolin instance
  • Create a secure resource for Home Assistant
  • Access your dashboard at home.yourdomain.com with Pangolin’s SSO
Scenario 3: Development Environment
When running development services on TrueNAS:
  • Use Pangolin to expose multiple services like GitLab, Jenkins, or development databases
  • Implement role-based access control for different team members
  • Maintain security without exposing your entire network
Part 4: Setting Up Pangolin in Your Environment
The setup process varies slightly depending on your hypervisor of choice:
For Unraid Users:
  • Install Newt from the Community Applications store
  • Configure with your Pangolin instance credentials
  • Create resources in the Pangolin dashboard
For Proxmox Users:
  • Create a lightweight container (LXC) or VM for Newt
  • Install Newt using Docker or the binary
  • Configure networking to access your VMs and containers
For TrueNAS Users:
  • Deploy Newt as a Docker container
  • Configure access to your jails or VMs
  • Set up resources in Pangolin
Part 5: Advanced Features and Best Practices
To get the most out of Pangolin in your home lab:
  1. Use Wildcard Certificates:
  • Configure DNS challenges with your provider
  • Enable wildcard certificates in Pangolin
  • Enjoy instant SSL for new subdomains
  1. Implement Role-Based Access:
  • Create different roles for family members
  • Restrict access based on user needs
  • Use temporary share links for guests
  1. Monitor Usage:
  • Track bandwidth usage per tunnel
  • Monitor service availability
  • Set up alerts for connectivity issues
Part 6: Future-Proofing Your Home Lab
Pangolin’s modular design means your setup can grow with your needs:
  1. Scaling Capabilities:
  • Add multiple sites for different locations
  • Expand services without reconfiguring networking
  • Integrate with existing authentication systems
  1. Disaster Recovery:
  • Keep configurations in version control
  • Maintain backup VPS instances
  • Document your setup for quick recovery
The true power of Pangolin lies in its ability to transform a complex home lab environment into a professionally managed infrastructure without the traditional overhead. Whether you’re running a small media server or a complex development environment, Pangolin provides the security, accessibility, and management features needed for a modern home lab setup.
Remember to regularly update both your Pangolin instance and Newt clients to benefit from the latest security features and improvements. With proper setup and maintenance, Pangolin can serve as the cornerstone of your home lab’s networking infrastructure.
sequenceDiagram
    participant U as User
    participant T as Traefik
    participant B as Badger
    participant P as Pangolin
    participant N as Newt
    participant S as Service
    U->>T: Request service.yourdomain.com
    T->>B: Check authentication
    B->>P: Verify session
    alt No valid session
        P->>U: Redirect to login
        U->>P: Login credentials
        P->>U: Set session cookie
        U->>T: Request with cookie
    end
    B->>P: Validate session
    P->>B: Session valid
    T->>N: Forward request
    N->>S: Access service
    S->>U: Service response
    Note over T,B: Badger ensures all requests are authenticated
    Note over N,S: Newt proxies traffic through secure tunnel
For detailed scenarios see part 2#
Securing Pangolin Stack
Hi there,
again a super solid peace of summary of yours. Thank you! I’ve been using pangolin as vps gateway for nearly 5 months now and have benefitted from dozens of your tutorials about pangolin, monitoring, backup etc.
Today i have another question, which i thought would fit (hopefully) good in here:
I have newt running in an lxc on my homelab (actually multiple newt containers across multiple machines in my homelab) and they have full subnet access 192.168.178.0/24 etc. Quick question: is this even the case for my tailscale subnet 100…? When my newt lxc/proxmox host is within my tailnet?
Even though i ABSOLUTELY love spinning up a new domain and newt tunnels for my services comfortably in my pangolin dashboard in minutes - sometimes i think, should i somehow harden this a little bit?
I mean - i have crowdsec, geoban, pangolin auth and additionally also pangolin firewall rules with restriction to only a few countries and of course with auth and so on - but just in case newt code would be corrupted or so - i sometimes think of how could i secure my subnet a little more, if this makes any sense. Of course it should be a reasonable and efficient restriction/hardening.
I thought about strict outgoing firewall rules for the newt lxc, which of course would mean, that i update the rules in proxmox everytime i spin up a new tunnel to a new ip. Maybe this would be a consequent, somehow fast solution?
I wonder if someone has better suggestions or thoughts about this topic. As i learned - better assume having a breach from within someday, than just guarding the gates. Might be also too paranoid :smiley:
