Securely Exposing Docker Services with Tailscale and Caddy: An HTTPS Guide
version: "3.7"
# network created via docker cmd line,
# and all other containers are also on it
proxy-network:
caddy:
image: caddy:latest
container_name: caddy
hostname: caddy
# caddy is in the network with the other containers
- proxy-network
depends_on:
# wait for tailscale to boot
# to communicate to it using the tailscaled.sock
- tailscale
- "80:80"
- "443:443"
- "443:443/udp"
- /home/io/docker_config/caddy/Caddyfile:/etc/caddy/Caddyfile
- /home/io/docker_config/caddy/data:/data
- /home/io/docker_config/caddy/config:/config
# tailscale creates its socket on /tmp, so we'll kidnap from there to expose to caddy
- /home/io/docker_config/tailscale/tmp/tailscaled.sock:/var/run/tailscale/tailscaled.sock
tailscale:
container_name: tailscaled
image: tailscale/tailscale
network_mode: host
cap_add:
- NET_ADMIN
- NET_RAW
- /dev/net/tun:/dev/net/tun
- /home/io/docker_config/tailscale/varlib:/var/lib
# https://github.com/tailscale/tailscale/issues/6849
# add volume for the tailscaled.sock to be present on the host system
# that's where caddy goes to communicate with tailscale
- /home/io/docker_config/tailscale/tmp:/tmp
# https://github.com/tailscale/tailscale/issues/4913#issuecomment-1186402307
# we have to tell the container to put the state in the same folder
# that way the state is saved on the host and survives reboot of the container
- TS_STATE_DIR=/var/lib/tailscale
# this have to be used only on the first time
# after that, the state is saved in /var/lib/tailscale and the next line can be commented out
- TS_AUTH_KEY= < your generated key >
Caddyfile
(network_paths) {
handle_path /backup/* {
reverse_proxy /* syncthing:8384 <<<< those are my container names
handle_path /docker/* {
reverse_proxy /* portainer:9000 <<<< those are my container names
reverse_proxy /* homer:8080 <<<< those are my container names
<machine-name>.<tailnet-name>.ts.net {
import network_paths
http://192.168.2.30 {
and don´t forget to generate the cert on it by running:
docker exec tailscaled tailscale --socket /tmp/tailscaled.sock cert <the server domain name>
