Overview
This document provides a comprehensive guide for recreating the Docker.img file on Unraid while preserving container configurations and custom networks. This process can be useful for maintenance, troubleshooting, or resizing the Docker virtual disk.
- Administrative access to Unraid
- Basic understanding of Docker networking
- Terminal access to Unraid server
- Backup of critical data (recommended)
Important Notes
- This procedure will not result in data loss if followed correctly
- Container configurations will be preserved
- All custom networks will need to be recreated
Detailed Procedure
1. Document Custom Networks
Important: Complete this step before proceeding if you have custom networks.
Option A: If Docker is Running
docker network ls
Make note of all custom networks (excluding default networks like ‘bridge’, ‘host’, and ‘none’).
Option B: If Docker is Not Running
Use the provided network discovery script (detailed in Section V).
2. Stop Docker Service
- Navigate to Settings > Docker
- Set “Enable Docker” to “No”
- Click “Apply”
3. Backup (Optional but Recommended)
# Using terminal
cp /mnt/user/system/docker/docker.img /mnt/user/backups/docker.img.bak
# Alternative: Use Unraid's file manager to create a backup
4. Remove Existing Docker.img
- In Settings > Docker:
- Enable “Delete VDISK file”
- Click “Apply”
- Verify the docker.img file is removed
5. Optional Cleanup
- Navigate to Apps > Previous Apps
- Review and remove unnecessary containers
- Document any specific container configurations you wish to preserve
6. Reinitialize Docker
- Return to Settings > Docker
- Set “Enable Docker” to “Yes”
- Configure desired vdisk size (if changing)
- Click “Apply”
7. Recreate Custom Networks
For each custom network previously documented:
docker network create <network_name>
8. Restore Containers
- Select desired containers for reinstallation
- Click “Install Selected”
- Monitor the installation progress
9. Verify Installation
- Check container status
- Verify network connectivity
- Test container functionality
- Review logs for any errors
V. Custom Network Discovery Script
Use this script if Docker is unavailable and you need to identify custom networks.
#!/bin/bash
# Configuration
OUTPUT_FILE="/mnt/user/data/docker_networks.txt"
INPUT_DIR="/boot/config/plugins/dockerMan/templates-user"
# Clear existing output
> "$OUTPUT_FILE"
# Process XML files and extract network information
for file in "$INPUT_DIR"/*.xml; do
grep -oP '(?<=<Network>).*?(?=</Network>)' "$file" | \
grep -v "host" | \
grep -v "bridge" | \
grep -v "br0" | \
grep -v "container:" \
done | sort | uniq > "$OUTPUT_FILE"
echo "Network information exported to $OUTPUT_FILE"
Script Usage
- Save the script with a
.shextension - Make it executable:
chmod +x script_docker.sh - Run the script:
./script_docker.sh - Check the output file for custom network names
Common Issues
Container Won’t Start
- Verify network assignments
- Check container logs
- Confirm port mappings
Missing Networks
- Review network discovery script output
- Check container network dependencies
- Verify network creation commands
Configuration Issues
- Compare against documented settings
- Review container templates
- Check volume mappings
Best Practices
- Always backup before starting
- Document all custom configurations
- Take screenshots of critical settings
- Test container functionality after restoration
- Maintain detailed network documentation
- Regular maintenance and cleanup
Support
For additional assistance:
- Consult Unraid forums
- Review Docker documentation
- Check container-specific documentation
Version Information
- Last Updated: 2024
- Tested on: Unraid 6.x
- Docker version: 20.x and later
