I have upgraded to version 2.0 and I am a Pangolin user.
The direct connection to Traefik does not work in my case with “http:traefik:8080”. Attached is a screenshot.
In my “traefik_config.yaml” I have specified this:
api:
insecure: true
dashboard: true
I have pangolin installed with the automatic installer. All on the same network and compose.
I have the same issue.
I suspect it has something to do with the standard pangolin configuration. The Traefik-container uses “network_mode: service:gerbil” for the wireguard connection. If I try to expose port 8080, it is denied because of the network_mode.
Maybe this is why middleware manager cannot reach traefik?
Thanks!
@​viriatusX and @​timmish when you are using pangolin use pangolin api. if you want to tinker with traefik api then you will have to open ports on gerbil
