This Docker Compose configuration establishes a comprehensive environment utilizing Traefik as a reverse proxy, alongside two containerized applications: MySQL/MariaDB and Snipe-IT. Traefik serves as the primary entry point, managing SSL termination and directing traffic to the respective services based on predefined routing rules and labels.
Overview of Components
- Traefik: Functions as the reverse proxy, facilitating dynamic service discovery and traffic management. It leverages Docker labels for configuration, enabling automatic routing based on service metadata.
- **MySQL/MariaDB **: A relational database management system that provides data storage for the Snipe-IT application.
- Snipe-IT: An open-source asset management system that operates within its own container, relying on MySQL for backend data storage.
Key Features
- SSL Termination: The configuration integrates Let’s Encrypt for automatic SSL certificate generation, ensuring secure HTTPS access to the Snipe-IT application.
- Centralized Traffic Management: By employing Traefik, this setup centralizes traffic handling, reducing complexity in managing multiple services.
- Dynamic Configuration: Traefik automatically detects service changes and updates routing configurations accordingly, minimizing manual intervention.
Configuration Details
The following Docker Compose file illustrates the setup:
version: '3'
# MySQL Database Service
mysql:
image: mariadb:11.4-noble
container_name: snipe_mysql
restart: always
healthcheck:
test: ["CMD", "healthcheck.sh", "--connect", "--innodb_initialized"]
interval: 5s
timeout: 1s
retries: 5
- /volume1/docker/snipeit/db:/var/lib/mysql:rw
- MYSQL_ROOT_PASSWORD=test
- MYSQL_USER=snipe
- MYSQL_PASSWORD=test
- MYSQL_DATABASE=snipe
# Snipe-IT Application Service
snipeit:
image: linuxserver/snipe-it:latest
container_name: snipeit
depends_on:
- mysql
healthcheck:
test: curl -f http://localhost:80/ || exit 1
- /volume1/docker/snipeit/config:/config:rw
labels:
- "traefik.enable=true"
- "traefik.http.routers.snipeitrouter.rule=Host(`snipeit.yoursite.site`)"
- "traefik.http.routers.snipeitrouter.entrypoints=websecure"
- "traefik.http.routers.snipeitrouter.tls.certresolver=snipeitrouter-letsencrypt"
- APP_URL=https://snipeit.yoursite.site
- APP_KEY=base64:ivoEDdeb+0ywdn/+d/lF8414TrIwbFOyz8DI187V8vo=
- MYSQL_PORT_3306_TCP_ADDR=mysql
- MYSQL_PORT_3306_TCP_PORT=3306
- MYSQL_USER=snipe
- PGID=1000
- PUID=1000
# Traefik Reverse Proxy Service
traefik:
image: traefik:v2.10
container_name: traefik
- 80:80
- 443:443
- 8080:8080 # Optional dashboard access; not recommended for production use.
- ./volumes/traefik/letsencrypt:/letsencrypt
command:
- "--api.dashboard=true"
- "--providers.docker=true"
- "--providers.docker.exposedbydefault=false"
- "--entrypoints.web.address=:80"
- "--entrypoints.websecure.address=:443"
- "--entrypoints.web.http.redirections.entryPoint.to=websecure"
- "--entrypoints.web.http.redirections.entryPoint.scheme=https"
- "--certificatesresolvers.snipeitrouter-letsencrypt.acme.httpchallenge=true"
- "--certificatesresolvers.snipeitrouter-letsencrypt.acme.httpchallenge.entrypoint=web"
- "--certificatesresolvers.snipeitrouter-letsencrypt.acme.email=<PUT YOUR E-MAIL HERE>"
- "--certificatesresolvers.snipeitrouter-letsencrypt.acme.storage=/letsencrypt/acme.json"
labels:
- "traefik.http.routers.api.rule=Host(`traefik.snipeit.yoursite.site`)"
- "traefik.http.routers.api.service=api@internal"
- "traefik.http.routers.api.entrypoints=websecure"
- "traefik.http.routers.api.tls.certresolver=snipeitrouter-letsencrypt"
Considerations
- Ensure to modify domain names, email addresses, and other relevant settings to align with your specific deployment requirements.
- The Traefik dashboard provides an interface for monitoring routing configurations and service statuses, enhancing operational oversight.
This Docker Compose configuration exemplifies an efficient method to deploy Snipe-IT with robust SSL support and centralized traffic management via Traefik in a containerized architecture.
