A short guide to get Sonarr and Radarr working to pass “HTTP Basic credentials” working on my Unraid setup.
Asuming your setup was following the Traefik Forward Auth - Single Applications guide
the middleware in “fileConfig.yml” needs to be ammended to have “authorization” at the end of authResponseHeaders.
authResponseHeaders:
- X-authentik-username
- X-authentik-groups
- X-authentik-email
- X-authentik-name
- X-authentik-uid
- X-authentik-jwt
- X-authentik-meta-jwks
- X-authentik-meta-outpost
- X-authentik-meta-provider
- X-authentik-meta-app
- X-authentik-meta-version
- authorization
Authentication setup was using this guide
the second missing setp for me was adding group access to the application.
On the Admin page, under Applications>Applications, click the Application name (NOT Edit)
Select “Policy/Group/User Bindings” tab
then “Bind exisiting policy/group/user” and select the group you created earlier containing your Radarr Users
thanks for sharing the updates.
To configure multiple middlewares in Traefik on Unraid, you can use a chain middleware approach.
@alextrical
To combine multiple middlewares in Traefik, you can use the chain middleware feature. This allows you to apply multiple middleware configurations to a single router.
Syntax for Combining Multiple Middlewares
Define Each Middleware: First, define each middleware separately using labels in your Docker configuration. For example:
labels:
- "traefik.http.middlewares.auth@file"
- "traefik.http.middlewares.theme@file"
Create a Chain Middleware: Then, create a new chain middleware that includes the individual middlewares you want to combine. Use a comma to separate them:
labels:
- "traefik.http.middlewares.my-chain.chain.middlewares=auth@file,theme@file"
Apply the Chain Middleware to a Router: Finally, apply this chain middleware to your router:
labels:
- "traefik.http.routers.my-router.middlewares=my-chain@file"
Example Configuration
Here’s an example of how this might look in a Docker Compose file:
version: '3'
my-service:
image: my-image
labels:
- "traefik.enable=true"
- "traefik.http.routers.my-router.rule=Host(`example.com`)"
- "traefik.http.middlewares.auth.basicauth.users=user:password"
- "traefik.http.middlewares.theme.customheader.X-Theme=dark"
Key Points
- Comma Separation: Ensure that you separate multiple middlewares with a comma within the chain definition.
- Unique Names: Each middleware should have a unique name to avoid conflicts.
- Testing: After setting up, verify that all middlewares are functioning correctly by checking the Traefik dashboard.
To set up Traefik to allow internal-only access to certain sites, you can use the IPWhitelist middleware (now known as IPAllowList). This middleware allows you to limit access based on client IP addresses.
- Define the IPAllowList Middleware: Create a dynamic configuration file (e.g.,
dynamic.yaml) and define the IPAllowList middleware with the allowed IP ranges.
http:
middlewares:
internal-only:
ipAllowList:
sourceRange:
- "192.168.0.0/16" # Replace with your internal IP range
- "10.0.0.0/8" # Replace with your internal IP range
- Apply the Middleware to Your Routers: In your
docker-compose.yml or Traefik configuration file, apply the middleware to the routers for the services you want to restrict to internal access.
code:
labels:
- "traefik.http.routers.code.rule=Host(`code.domain.tld`)"
- "traefik.http.routers.code.entrypoints=web"
- "traefik.http.routers.code.middlewares=internal-only@file"
traefik:
labels:
- "traefik.http.routers.traefik.rule=Host(`traefik.domain.tld`)"
- "traefik.http.routers.traefik.entrypoints=web"
- "traefik.http.routers.traefik.middlewares=internal-only@file"
mariadb:
labels:
- "traefik.http.routers.mariadb.rule=Host(`mariadb.domain.tld`)"
- "traefik.http.routers.mariadb.entrypoints=web"
- "traefik.http.routers.mariadb.middlewares=internal-only@file"
- Mount the Dynamic Configuration File: Ensure that the dynamic configuration file is mounted in your Traefik container.
traefik:
- "./dynamic.yaml:/etc/traefik/dynamic.yaml"
- Update Your Traefik Configuration: Update your Traefik static configuration to include the dynamic configuration file.
providers:
file:
filename: /etc/traefik/dynamic.yaml
