You’re hitting a DNS resolution problem that is very common on Linux (especially Linux Mint, Ubuntu derivatives, or any distro using systemd-resolved + dhcpcd / NetworkManager).
The Pangolin CLI (which uses the olm SDK under the hood) tries to inject its own DNS server (usually something like 100.96.128.1) so that your private resource aliases (e.g. my-server.internal) resolve correctly. On many Linux setups this fails because /etc/resolv.conf is being managed/overwritten by another service, so the changes Pangolin makes are ignored.
Step-by-step fix (safe to try)
Check the current state (run these commands):
ls -l /etc/resolv.conf cat /etc/resolv.conf- If it says
lrwxrwxrwx ... -> /run/systemd/resolve/stub-resolv.conf→ you already have the correct symlink (skip to step 3). - If it is a regular file (
-rw-r--r--) or points somewhere else → continue.
- If it says
Apply the fix (forces the symlink to systemd-resolved’s stub resolver):
sudo ln -sf /run/systemd/resolve/stub-resolv.conf /etc/resolv.conf(The
-foverwrites the old file if needed.) -
Restart/reconnect Pangolin:
- Disconnect if you are connected.
- Re-run your connect command (with debug if you want to see the logs again):
(or however you normally connect).pangolin connect --attach --log-level debug
Verify it worked:
cat /etc/resolv.confYou should now see a
nameserverline starting with100.(the Pangolin DNS).Then test your alias:
ping alias-name # (may not work – see note below) # or better: ssh user@alias-name # or curl http://alias-name:port
Important notes
ICMP ping often doesn’t work even when the alias is correct (Pangolin docs say aliases don’t intercept ICMP). Use SSH, HTTP, or whatever port your service actually uses.
The symlink may get overwritten on reboot if
dhcpcdor NetworkManager is aggressive.
If that happens, add this line to/etc/dhcpcd.conf(then reboot):nohook resolv.confOr create a systemd-resolved drop-in (alternative method):
sudo mkdir -p /etc/systemd/resolved.conf.d sudo nano /etc/systemd/resolved.conf.d/pangolin.confPaste:
[Resolve] DNS=100.96.128.1 # ← use whatever Pangolin actually gives you Domains=~internal # or whatever your alias domain isThen
sudo systemctl restart systemd-resolved. -
Make sure you are on the latest CLI version (0.5.3+ was mentioned as having improvements):
curl -fsSL https://static.pangolin.net/get-cli.sh | bash
If after doing the symlink the alias still doesn’t resolve, paste here:
- Output of
cat /etc/resolv.conf - Output of
pangolin status(or whatever shows your connection) - Your Linux distro + version (
cat /etc/os-release)
If anyone is facing the issue please post below.
