To set up your Proxmox environment with two network bridges—one for an untagged network and another for a tagged VLAN (VLAN 51)—you need to configure the /etc/network/interfaces file directly. Below is a step-by-step guide to achieve this configuration.
Configuration Steps
Access the Proxmox Console: You need to log into the console of your Proxmox server. You can do this via SSH or directly through the server’s terminal.
Edit the Network Interfaces File: Open the network interfaces configuration file with a text editor like
nano:nano /etc/network/interfaces -
Configure the Bridges: You will need to add configurations for two bridges. Here’s an example configuration assuming your network interface is
enp0s3:auto lo iface lo inet loopback # Main network interface auto enp0s3 iface enp0s3 inet manual # Bridge for untagged traffic auto vmbr0 iface vmbr0 inet dhcp bridge-ports enp0s3 bridge-stp off bridge-fd 0 bridge-vlan-aware yes # Bridge for VLAN 51 auto vmbr1 iface vmbr1 inet manual bridge-ports enp0s3 bridge-stp off bridge-fd 0 bridge-vlan-aware yes # VLAN 51 configuration post-up ip link add link enp0s3 name enp0s3.51 type vlan id 51 post-up ip link set enp0s3.51 up post-up ip link set vmbr1 up pre-down ip link delete enp0s3.51In this configuration:
vmbr0is set up for untagged traffic and will receive an IP via DHCP.vmbr1is configured for VLAN 51. It creates a VLAN interface (enp0s3.51) for the tagged traffic.
Restart Networking: After saving your changes, restart the networking service to apply the new configuration:
systemctl restart networkingAlternatively, you can reboot the Proxmox server.
Configure Virtual Machines: When you create or configure your virtual machines, assign them to the appropriate bridge:
- For VMs that need access to the untagged network, select
vmbr0. - For VMs that need access to VLAN 51, select
vmbr1and ensure the VM’s network interface is set to use VLAN tagging with ID 51.
Additional Considerations
Managed Switch: Ensure that your switch is configured to handle VLANs correctly. The port connecting to your Proxmox server should be set to trunk mode, allowing both untagged and tagged traffic.
Firewall Settings: If you have a firewall enabled on Proxmox, make sure it allows traffic from the VLANs and the management network.
Testing: After configuration, test connectivity from your VMs to ensure they can reach the intended networks.
This setup should allow you to use both untagged and tagged VLAN traffic on your Proxmox server effectively. If you encounter issues, check the switch configuration and ensure that Proxmox is receiving the correct VLAN tags.
