Setting Up Domain Aliases in CloudPanel with Independent SSL
- Tested on Ubuntu 22.04 (Jammy Jellyfish) Only on which CloudPanel is installed.
Use it at your own risk on a production server.
It doesn’t alter any imp system files.
Overview
CloudPanel doesn’t natively support adding domain aliases or parked domains without manual configuration. While you can modify the vhost server_name with an addon domain, it shares the SSL certificate with the main domain. This guide provides a solution to create completely independent domain aliases with their own SSL certificates while sharing the main domain’s directory.
Required Components
- CloudPanel installed and configured
- Main website already set up and running
- SSH access with sudo privileges
- Secondary domain name ready to be configured
Main Site Example Structure
Main Site Path: /home/mainsite/htdocs/mainsite.com
Main Site User: mainuser
Main Site URL: mainsite.com
Manual Setup Steps
Create New Site in CloudPanel
- Log into CloudPanel
- Create a new website for your secondary domain
- Choose any template except reverse proxy (PHP recommended)
Generate SSL Certificate
- Use CloudPanel’s interface to generate Let’s Encrypt SSL
- Ensure the certificate is properly issued for the secondary domain
Configure Vhost File
/etc/nginx/sites-enabled/secondarysite.com.conf - Copy configuration from main site’s vhost
- Update
server_nameto secondary domain - Change
{{root}}path to main site’s path - Example:
Update PHP-FPM Pool
- Navigate to:
/etc/php/8.2/fpm/pool.d/ - Modify:
secondarysite.com.conf - Update user and group to main site’s user
- Example:
user = mainuserandgroup = mainuser
- Navigate to:
Restart Services
- Restart PHP-FPM:
systemctl restart php8.2-fpm - Restart NGINX:
systemctl restart nginx
- Restart PHP-FPM:
Automated Setup Using Script
Script Installation
# Download the script
wget https://your-script-url/setup-domain-alias.sh
# Make it executable
chmod +x setup-domain-alias.sh
Script Usage
sudo ./setup-domain-alias.sh -m mainsite.com -s secondarysite.com [-p php_version]
Script Parameters
-m: Main domain name (required)-s: Secondary domain name (required)-p: PHP version (optional, defaults to 8.2)
What the Script Does
- Validates input parameters and requirements
- Creates backups of existing configurations
- Updates NGINX vhost configuration
- Modifies PHP-FPM pool settings
- Tests configurations
- Restarts necessary services
Important Notes
PHP Version
- Default version is 8.2
- Change version number in paths if using different PHP version
- Script allows specifying version with
-pparameter
Alternative Approach
- You can use reverse proxy with internal IP (127.0.0.1:port)
- Port number found in pool.d folder
- Not recommended for WordPress installations due to potential issues
Security Considerations
- Always backup configurations before making changes
- Verify SSL certificate generation
- Check file permissions after setup
- Test website functionality after changes
- Verify SSL certificate status
- Check NGINX configuration syntax
- Examine PHP-FPM pool status
- Review log files for errors:
/var/log/nginx/error.log/var/log/php8.2-fpm.log
Maintenance
- Monitor SSL certificate renewals
- Keep PHP version updated
- Regular backup of configurations
- Check log files periodically
This setup provides a clean solution for domain aliases while maintaining independent SSL certificates and configuration files, all while sharing the main domain’s document root.
#!/bin/bash
# CloudPanel Domain Alias Setup Script
# This script automates the process of setting up a domain alias with independent SSL in CloudPanel
# Function to display script usage
usage() {
echo "Usage: $0 -m main_domain -s secondary_domain [-p php_version]"
echo "Example: $0 -m mainsite.com -s alias.com -p 8.2"
exit 1
# Function to check if running with sudo privileges
check_sudo() {
if [ "$EUID" -ne 0 ]; then
echo "Please run this script with sudo privileges"
exit 1
fi
# Function to validate domain name format
validate_domain() {
if [[ ! $1 =~ ^[a-zA-Z0-9][a-zA-Z0-9-]{1,61}[a-zA-Z0-9]\.[a-zA-Z]{2,}$ ]]; then
echo "Invalid domain format: $1"
exit 1
fi
# Parse command line arguments
while getopts ":m:s:p:" opt; do
case $opt in
m) MAIN_DOMAIN="$OPTARG";;
s) SECONDARY_DOMAIN="$OPTARG";;
p) PHP_VERSION="$OPTARG";;
\?) echo "Invalid option -$OPTARG"
usage;;
:) echo "Option -$OPTARG requires an argument"
usage;;
esac
done
# Check if required arguments are provided
if [ -z "$MAIN_DOMAIN" ] || [ -z "$SECONDARY_DOMAIN" ]; then
usage
fi
# Set default PHP version if not provided
PHP_VERSION=${PHP_VERSION:-8.2}
# Validate inputs
check_sudo
validate_domain "$MAIN_DOMAIN"
validate_domain "$SECONDARY_DOMAIN"
# Configuration variables
MAIN_USER=$(stat -c '%U' /home/*/htdocs/"$MAIN_DOMAIN" 2>/dev/null)
if [ -z "$MAIN_USER" ]; then
echo "Error: Could not find main domain's user"
exit 1
fi
MAIN_PATH="/home/$MAIN_USER/htdocs/$MAIN_DOMAIN"
VHOST_PATH="/etc/nginx/sites-enabled"
PHP_POOL_PATH="/etc/php/$PHP_VERSION/fpm/pool.d"
echo "Starting domain alias setup..."
echo "Main Domain: $MAIN_DOMAIN"
echo "Secondary Domain: $SECONDARY_DOMAIN"
echo "PHP Version: $PHP_VERSION"
echo "Main User: $MAIN_USER"
# Step 1: Verify that the main site exists
if [ ! -d "$MAIN_PATH" ]; then
echo "Error: Main site directory not found at $MAIN_PATH"
exit 1
fi
# Step 2: Backup original configuration files
timestamp=$(date +%Y%m%d_%H%M%S)
echo "Creating backup of configuration files..."
if [ -f "$VHOST_PATH/$SECONDARY_DOMAIN.conf" ]; then
cp "$VHOST_PATH/$SECONDARY_DOMAIN.conf" "$VHOST_PATH/$SECONDARY_DOMAIN.conf.backup_$timestamp"
fi
if [ -f "$PHP_POOL_PATH/$SECONDARY_DOMAIN.conf" ]; then
cp "$PHP_POOL_PATH/$SECONDARY_DOMAIN.conf" "$PHP_POOL_PATH/$SECONDARY_DOMAIN.conf.backup_$timestamp"
fi
# Step 3: Update the vhost configuration
echo "Updating NGINX vhost configuration..."
sed -i "s|{{root}}|$MAIN_PATH|g" "$VHOST_PATH/$SECONDARY_DOMAIN.conf"
sed -i "s|server_name .*;|server_name $SECONDARY_DOMAIN;|g" "$VHOST_PATH/$SECONDARY_DOMAIN.conf"
# Step 4: Update PHP-FPM pool configuration
echo "Updating PHP-FPM pool configuration..."
sed -i "s|user = .*|user = $MAIN_USER|g" "$PHP_POOL_PATH/$SECONDARY_DOMAIN.conf"
sed -i "s|group = .*|group = $MAIN_USER|g" "$PHP_POOL_PATH/$SECONDARY_DOMAIN.conf"
# Step 5: Test configurations
echo "Testing NGINX configuration..."
nginx -t
if [ $? -ne 0 ]; then
echo "Error: NGINX configuration test failed"
exit 1
fi
# Step 6: Restart services
echo "Restarting services..."
systemctl restart php$PHP_VERSION-fpm
echo "Setup completed successfully!"
echo "Please verify that:"
echo "1. The SSL certificate has been generated for $SECONDARY_DOMAIN"
echo "2. The website is accessible at https://$SECONDARY_DOMAIN"
echo "3. All file permissions are correct"
echo ""
echo "Backup files were created with timestamp: $timestamp"
