Setting Up a Docker Stack for Magento 2
This guide outlines the steps to set up a Docker stack for Magento 2 using the latest installer. The setup includes various services like Varnish, Nginx, PHP, OpenSearch, MariaDB, Redis, MailHog, RabbitMQ, and Watchtower. By adjusting the .env file, you can manage multiple projects within a single stack.
- Docker and Docker Compose: Ensure you have Docker and Docker Compose installed on your machine.
- Git: Required for cloning the repository.
Getting Started
Clone the Repository
To get started, clone the Magento 2 Docker setup repository:
git clone https://git.hhf.technology/hhf/magento2.docker.git
cd magento2.docker
Check for Updates
To keep your local repository up to date, run:
git fetch && git pull
Configuration
Adjusting the .env File
Before installation, configure your environment variables in the .env file. This file allows you to set various parameters such as database credentials and project directories.
Installation Steps
Fresh Installation or Existing Project
You can either perform a fresh installation of Magento 2 or work with an existing project located on your filesystem.
Run Installation Script
Execute the installation script:
chmod +x bin/* bin/installDuring this process, you will be prompted to configure your installation settings. Note that using the command with config has known bugs; contributions to fix these are welcome.
Post-Installation Configuration
After installation, modify the
.envfile to change any values as needed. These changes will take effect upon restarting the containers.
Accessing Your Magento Store
Backend: Access the admin panel at http://localhost/admin using:
- Username:
mage2_admin - Password:
mage2_admin123#T
- Username:
Frontend: Visit http://localhost to view your store.
Starting and Managing Containers
For starting your containers after a system reboot, use:
bin/start
To install sample data, run:
bin/sample-data
Using PHP Container
To access the PHP container for command-line operations:
docker exec -it mage2_php bash
Mailhog Configuration
The installation script configures Magento to work with MailHog for email testing. Access MailHog at http://localhost:8025.
Additional Features
- Multiple Projects: You can run multiple projects in parallel by configuring a reverse proxy like Traefik or nginx-proxy.
- Extra Composer Packages: The setup includes additional packages like
yireo/magento2-webp2for WebP conversion andmage2tv/magento-cache-cleanfor cache cleaning. - Xdebug Support: Xdebug can be configured by setting
xdebug.idekey=PHPSTORMin your.envfile.
By following these steps, you can successfully set up a Docker stack for Magento 2 that is flexible and scalable for development purposes. This setup allows for easy management of multiple projects and ensures that your development environment is consistent and portable.
