Authentik 2024+ and Traefik 3.x
Overview
This guide assumes that there is a working Traefik v3.x+ running and that the Traefik network is called traefik. I will also be using the embedded outpost instead of a standalone proxy outpost container.
Additionally, I am NOT allowing Authentik to view the Docker socket (/var/run/docker.sock) and auto create providers.
If you want to learn more on how to setup Traefik or just some more detailed explanation, visit Anand and Smart Home Beginner at https://www.smarthomebeginner.com/.
My folder / repo structure is weird because this is a condensed version of what I have running. I did not want to leave dead links or bad configurations, so modify to your environment.
Authentik is heavier on resources than Authelia, but it is pretty neat!
DNS Records
Ensure that a DNS record exists for authentik.domain.tld as the compose and all material here assumes that will be the record name. This is the bare minimum requirement!
I highly recommend Pi-hole https://pi-hole.net/ for your domain!
Records that are used in this example:
traefik.domain.tld- Traefik 3.x Dashboardauthentik.domain.tld- Authentik WebUIwhoami-individual.domain.tld- WhoAmI using Authentik middleware - Individual Providerwhoami-catchall.domain.tld- WhoAmI using Authentik middleware - Domain Wide Catch Allwhoami.domain.tld- WhoAmI no authentik middleware
The way I have my records in Pi-hole setup, since all of these are containers:
DNS Records
| Domain | IP |
| traefik.domain.tld | 192.168.1.26 |
This IP is the host that my containers are running on.
CNAME Records
| Domain | Target |
| authentik.domain.tld | traefik.domain.tld |
| whoami-individual.domain.tld | traefik.domain.tld |
| whoami-catchall.domain.tld | traefik.domain.tld |
| whoami.domain.tld | traefik.domain.tld |
Authentik’s developer has an initial docker compose setup guide and docker-compose.yml located at:
[!NOTE]
In order for the forwardAuth to make sense, I’ve modified the provided docker-compose.yml and added the appropriate Traefik labels. I am also using docker secrets in order to protect sensitive information.
[!NOTE]
I am using “fake” docker secrets and binding them into the compose instead of saving sensitive data in environment variables. You can remove the secrets section and work with regular environment variables if that makes more sense for your environment. This is strictly a working example, hopefully with enough documentation to help anyone else that might be stuck.
First create an environment variable file .env in the same directory as the compose.yaml with the following information, ensuring to update everywhere that has a CHANGEME to match your environment. If you want, these values can all be manually coded into the compose.yaml instead of having a separate file.
Environment Variables File
Check .env for the latest version of the contents below.
.env
# .env
# When both env_file and environment are set for a service, values set by environment have precedence.
# https://docs.docker.com/compose/environment-variables/envvars-precedence/
# CANNOT MIX ARRAYS (KEY: VAL) AND MAPS (KEY=VAL)
# Ex: Cannot have .ENV var as TZ=US and then a var here as DB_ENGINE: sqlite, has to be DB_ENGINE=sqlite
# Otherwise unexpected type map[string]interface {} occurs
# https://github.com/docker/compose/issues/11567
DOCKERDIR=/home/CHANGEME/docker
PUID=1100
PGID=1100
TZ=America/Chicago
DOMAINNAME=domain.tld
#################### Traefik 3 - June 2024 #####################
# Cloudflare IPs (IPv4 and/or IPv6): https://www.cloudflare.com/ips/
CLOUDFLARE_IPS=173.245.48.0/20,103.21.244.0/22,103.22.200.0/22,103.31.4.0/22,141.101.64.0/18,108.162.192.0/18,190.93.240.0/20,188.114.96.0/20,197.234.240.0/22,198.41.128.0/17,162.158.0.0/15,104.16.0.0/13,104.24.0.0/14,172.64.0.0/13,131.0.72.0/22
LOCAL_IPS=127.0.0.1/32,10.0.0.0/8,192.168.0.0/16,172.16.0.0/12
#CLOUDFLARE_EMAIL= # Moved to Docker Secrets
#CLOUDFLARE_API_KEY= # Moved to Docker Secrets
# Authentik (https://docs.goauthentik.io/docs/)
# Environment Variables (https://docs.goauthentik.io/docs/installation/configuration)
POSTGRES_PASSWORD_FILE=/run/secrets/authentik_postgresql_password
#POSTGRES_USER_FILE=/run/secrets/authentik_postgresql_user
POSTGRES_USER_FILE=/run/secrets/authentik_postgresql_db
POSTGRES_DB_FILE=/run/secrets/authentik_postgresql_db
AUTHENTIK_REDIS__HOST=authentik_redis
AUTHENTIK_POSTGRESQL__HOST=authentik_postgresql
AUTHENTIK_POSTGRESQL__NAME=file:///run/secrets/authentik_postgresql_db
#AUTHENTIK_POSTGRESQL__USER=file:///run/secrets/authentik_postgresql_user
AUTHENTIK_POSTGRESQL__USER=file:///run/secrets/authentik_postgresql_db
AUTHENTIK_POSTGRESQL__PASSWORD=file:///run/secrets/authentik_postgresql_password
AUTHENTIK_DISABLE_STARTUP_ANALYTICS=true
AUTHENTIK_DISABLE_UPDATE_CHECK=false
AUTHENTIK_ERROR_REPORTING__ENABLED=false
AUTHENTIK_LOG_LEVEL=info # debug, info, warning, error, trace
AUTHENTIK_SECRET_KEY=file:///run/secrets/authentik_secret_key # openssl rand 60 | base64 -w 0
AUTHENTIK_COOKIE_DOMAIN=${DOMAINNAME}
# AUTHENTIK_LISTEN__TRUSTED_PROXY_CIDRS: CHANGEME_IFAPPLICABLE # Defaults to all of: 127.0.0.0/8, 10.0.0.0/8, 172.16.0.0/12, 192.168.0.0/16, fe80::/10, ::1/128
DOCKER_HOST: tcp://socket-proxy:2375 # Use this if you have Socket Proxy enabled.
AUTHENTIK_EMAIL__PORT=587
AUTHENTIK_EMAIL__USERNAME=file:///run/secrets/gmail_smtp_username
AUTHENTIK_EMAIL__PASSWORD=file:///run/secrets/gmail_smtp_password
AUTHENTIK_EMAIL__TIMEOUT=10
AUTHENTIK_EMAIL__FROM=file:///run/secrets/gmail_smtp_username
# GeoIP ( https://github.com/maxmind/geoipupdate)
# Environment Variables (https://github.com/maxmind/geoipupdate/blob/main/doc/docker.md)
GEOIPUPDATE_EDITION_IDS="GeoLite2-City GeoLite2-ASN" # Space seperated
GEOIPUPDATE_FREQUENCY=8 # Frequency to check for updates, in hours
GEOIPUPDATE_ACCOUNT_ID_FILE=/run/secrets/geoip_account_id
GEOIPUPDATE_LICENSE_KEY_FILE=/run/secrets/geoip_license_key
Compose File
I really like how Anand did his compose.yaml file to be a stack of includes for cleaner organization.
compose.yaml - Defines the base networks, secrets, and other compose files below to include when ran.
The 2 other whoami containers are inside of the Authentik compose since they are examples, strictly for demonstration and then removed.
Docker Secrets
The following secrets (defined in the base compose.yaml need to be created)
I recommend you create secrets with the following syntax:
echo -n 'VALUE_CHANGEME' > SECRET_NAME_CHANGEME
Check out Traefik’s info at Redirecting.... Cloudflare Specific information: Cloudflare :: Let’s Encrypt client and ACME library written in Go.
cf_emailcf_dns_api_tokenecho -n 'CHANGEME@gmail.com' > cf_email echo -n 'CHANGEME-LONGAPI-CHANGEME' > cf_dns_api_token
Authentik specific (https://docs.goauthentik.io/docs/installation/docker-compose#preparation)
authentik_postgresql_dbauthentik_postgresql_userauthentik_postgresql_passwordauthentik_secret_keyecho -n 'authentik_db' > authentik_postgresql_db echo -n 'authentik_user' > authentik_postgresql_user openssl rand 36 | base64 -w 0 > authentik_postgresql_password openssl rand 60 | base64 -w 0 > authentik_secret_key
Create a gmail account and input the info.
gmail_smtp_usernamegmail_smtp_passwordecho -n 'CHANGEME@gmail.com' > gmail_smtp_username echo -n 'CHANGEME' > gmail_smtp_password
Go to GeoLite Databases and Web Services | MaxMind Developer Portal in order to generate a free license key (https://www.maxmind.com/en/accounts/current/license-key) for use.
geoip_account_idgeoip_license_keyecho -n 'CHANGEME' > geoip_account_id echo -n 'CHANGEME' > geoip_license_key
Traefik Setup
Configuration
I like having Traefik’s configuration in a file, it makes more sense to me compared to passing a ton of command arguments in the compose.
traefik.yaml
# Traefik 3.x (YAML)
# Updated 2024-June-04
# Global configuration - https://doc.traefik.io/traefik/reference/static-configuration/file/
global:
checkNewVersion: false
sendAnonymousUsage: false
# Entrypoints - https://doc.traefik.io/traefik/routing/entrypoints/
entryPoints:
web:
address: ":80"
# Global HTTP to HTTPS redirection
http:
redirections:
entrypoint:
to: websecure
scheme: https
websecure:
address: ":443"
http:
tls:
options: tls-opts@file
certResolver: le
domains:
- main: "domain.tld"
sans:
- "*.domain.tld"
forwardedHeaders:
trustedIPs:
# Cloudflare (https://www.cloudflare.com/ips-v4)
- "173.245.48.0/20"
- "103.21.244.0/22"
- "103.22.200.0/22"
- "103.31.4.0/22"
- "141.101.64.0/18"
- "108.162.192.0/18"
- "190.93.240.0/20"
- "188.114.96.0/20"
- "197.234.240.0/22"
- "198.41.128.0/17"
- "162.158.0.0/15"
- "104.16.0.0/13"
- "104.24.0.0/14"
- "172.64.0.0/13"
- "131.0.72.0/22"
# Local IPs
- "127.0.0.1/32"
- "10.0.0.0/8"
- "192.168.0.0/16"
- "172.16.0.0/12"
# Logs - https://doc.traefik.io/traefik/observability/logs/
log:
level: INFO # Options: DEBUG, PANIC, FATAL, ERROR (Default), WARN, and INFO
filePath: /logs/traefik-container.log # Default is to STDOUT
# format: json # Uses text format (common) by default
noColor: false # Recommended to be true when using common
maxSize: 100 # In megabytes
compress: true # gzip compression when rotating
# Access logs - https://doc.traefik.io/traefik/observability/access-logs/
accessLog:
addInternals: true # things like ping@internal
filePath: /logs/traefik-access.log # In the Common Log Format (CLF) by default
bufferingSize: 100 # Number of log lines
fields:
names:
StartUTC: drop # Write logs in Container Local Time instead of UTC
filters:
statusCodes:
- "204-299"
- "400-499"
- "500-599"
# API and Dashboard
api:
dashboard: true
# Rely on api@internal and Traefik with Middleware to control access
# insecure: true
# Providers - https://doc.traefik.io/traefik/providers/docker/
providers:
docker:
#endpoint: "unix:///var/run/docker.sock" # Comment if using socket-proxy
endpoint: "tcp://socket-proxy:2375" # Uncomment if using socket proxy
exposedByDefault: false
network: traefik # network to use for connections to all containers
# defaultRule: TODO
# Enable auto loading of newly created rules by watching a directory
file:
# Apps, LoadBalancers, TLS Options, Middlewares, Middleware Chains
directory: /rules
watch: true
# Let's Encrypt (ACME)
certificatesResolvers:
le:
acme:
email: "CHANGEME@gmail.com"
storage: "/data/acme.json"
#caServer: "https://acme-staging-v02.api.letsencrypt.org/directory" # Comment out when going prod
dnsChallenge:
provider: cloudflare
#delayBeforeCheck: 30 # Default is 2m0s. This changes the delay (in seconds)
# Custom DNS server resolution
resolvers:
- "1.1.1.1:53"
- "8.8.8.8:53"
acme.json
When traefik comes up and authenticates with Let’s Encrypt a acme.json will be created at
./appdata/traefik/data/acme.json
Rules / Middleware Preparation
I’ve included several of the rules I use in my own setup located at
[!NOTE]
The one that makes Authentik work ismiddlewares-authentik.yamlORforwardAuth-authentik.yaml. They are the exact same thing, but you can decide which name makes more sense to use. In thecompose.yamlI am usingmiddlewares-authentik, but to me it makes more sense to useforwardAuth-authentikso when you are reading the traefik label’s you know what it is supposed to do. Your choice.
In order to setup forwardAuth at a minimum, Traefik requires a declaration. Authentik provides an example, but in accordance with the compose.yaml the values below should make more sense.
# Middlewares (https://github.com/htpcBeginner/docker-traefik/blob/master/appdata/traefik2/rules/cloudserver/middlewares.yml)
# 2024 update: https://github.com/htpcBeginner/docker-traefik/tree/master/appdata/traefik3/rules/hs
# https://www.smarthomebeginner.com/traefik-docker-compose-guide-2022/
# Dynamic configuration
http:
middlewares:
# Forward Authentication - OAUTH / 2FA
forwardAuth-authentik:
forwardAuth:
trustForwardHeader: true
authResponseHeaders:
- X-authentik-username
- X-authentik-groups
- X-authentik-email
- X-authentik-name
- X-authentik-uid
- X-authentik-jwt
- X-authentik-meta-jwks
- X-authentik-meta-outpost
- X-authentik-meta-provider
- X-authentik-meta-app
- X-authentik-meta-version
The Forward Authentication WILL NOT work unless the middleware is enabled.
[!WARNING]
“Priority based on rule length” Authentik generates the priority for authentication based on rule length (Traefik label). This means if you have a rule (Traefik label) for Authentik to listen on multiple host names withOR, ||statements, it will have a higher priority than the embedded outpost. Refer to goauthentik/authentik#2180 about setting the priority for the embedded outpost.
Bringing the Stack Online
Time to start up the stack and begin configuration. Ensure this command is ran from the same directory as compose.yaml.
docker compose up -d
Authentik Setup
Because Authentik uses cookies, I recommend using Incognito for each piece of testing, so you don’t have to clear cookies every time or when something is setup incorrectly.
[!WARNING]
While using a container behind Authentik, it prompts for authentication, and then flashes but doesn’t load. This generally indicates cookies are messing up the loading. So use INCOGNITO.
Initial Setup
With Authentik being reverse proxied through Traefik and the middleware showing as enabled in Traefik’s dashboard, then configuration of Authentik can begin.
- Navigate to Authentik at
https://authentik.domain.tld/if/flow/initial-setup/ - Login to Authentik to begin setup.
[!NOTE]
If this is the first time logging in you will have to set the password forakadmin(default user). If establishing the default credentials fails - the setup is not working correctly.
The default user is akadmin, which is a super user. This initial setup will setup the Super User’s email and Password. You will change the username FROM akadmin to whatever you want.
The first screen you’ll see after setting the password and email is:
You can change the username from akadmin to whatever.
In the Admin Interface go to
- Directory
- Users
- Click on Edit beside
akadmin
(Information) Error Screen before Provider and Application
I think this is important for anyone that attempts to set this up.
If you attempt to navigate to a page that IS using Authentik’s forwardAuth middleware but haven’t finished setting up a provider and application (individual or domain wide catch all) then you will see a screen like this:
Applications / Providers
In the current version, for this documentation 2024.6.0, Authentik now includes a Wizard to aid with setting up a Application and Provider instead of manually doing it.
I am going to set up my Individual Application manually and the Domain Wide / Catch All using the Wizard. ONLY to show how you can do either method, both work!
[!NOTE]
I am using the embedded outpost. The embedded outpost requires version2021.8.1or newer. This prevents needing the seperate Forward Auth / Proxy Provider container.
[!WARNING]
Individual applications have a higher priority than the catch all, so you can set up both!
Domain Wide / Catch All (forwardAuth) using the Wizard
In order for this to “Catch All” you must set a traefik middleware on each service. Look inside the compose.yaml. This specific snippet is from the whoami-individual service inside the authentik/compose.yaml:
Specifically the middlewares-authentik@file" line.
labels:
- "traefik.enable=true"
## HTTP Routers
- "traefik.http.routers.whoami-individual-rtr.rule=Host(`whoami-individual.${DOMAINNAME}`)"
## Middlewares
- "traefik.http.routers.whoami-individual-rtr.middlewares=middlewares-authentik@file"
Navigate to:
- Applications
- Applications
- “Create with Wizard”
Wizard Page 1 - “Application Details”
- Name:
Domain Wide Forward Auth Catch All - Slug:
domain-wide-forward-auth-catch-all - Group:
empty - Policy Engine Mode:
any - UI Settings:
- Launch URL:
empty
Do NOT put anything in the Launch URL, it needs to autodetect since it’s the catch all rule - Open in new tab:
unchecked
- Launch URL:
Wizard Page 2 - “Provider Type”
- Forward Auth (Domain Level)
Notice the blue highlight underneath showing the selection!
Wizard Page 3 - “Provider Configuration”
- Name:
Provider for Domain Wide Forward Auth Catch All - Authentication Flow:
empty
This is user choice, I recommend getting the basics setup and THEN modifying authentication flow for the catch all - Authorization Flow:
default-provider-authorization-explicit-consent (Authorize Application)
Explicit requires user interaction aka clicking a button to continue versus implicit which is just trust - External Host:
https://authentik.domain.tld - Cookie Domain:
domain.tld - Token Validity:
hours=24
When all is done, you should have success. If not, carefully review the previous settings. You most likely forgot https:// in front of authentik.domain.tld
Embedded Outpost (Domain Wide)
Navigate to the Outposts screen and edit the Embedded Outpost:
- Applications
- Outposts
- Edit the Embedded Outpost
Notice how the above picture has Providers empty?
Update the Outpost to have the Domain Wide Forward Auth Catch All in Selected Applications
BEFORE Adding
AFTER Adding
Now the Embedded Outpost shows the Provider for the Catch All rule instead of it being empty/blank:
Domain Wide / Catch All Test/Validation
Now that the catch all rule is in place, validate it using the already running whoami-catchall container created:
Navigate to whoami-catchall.domain.tld and it will immediately redirect you to Authentik to login:
Sign in with your username or email address initially created. After inputting username & password, it should show you the “Redirecting” screen prior to actual redirection:
X-Authentik-Meta-App: domain-wide-forward-auth-catch-all
Individual Application (forwardAuth) manual
Maybe you don’t want to use the wizard, though I’m not sure why. So here’s how you can do it without the Wizard.
Note: This does not seem to be required on everyone’s setup. Individual Application forwardAuth does not work on mine without this label. I recommend you check your setup both with this label.
[!NOTE]
“providers/proxy: no exposed urls #3151” This PR greatly simplifies the Forward auth setup for traefik and envoy. It’ll remove the requirement/outpost.goauthentik.ioto be openly accessible, which makes setup easier and decreases attack surface.
This label is applied to the authentik_server container. Even if you don’t use individual applications, keep this label just in case you DO in the future!
labels:
- "traefik.http.routers.authentik-output-rtr.rule=HostRegexp(`{subdomain:[a-z0-9-]+}.${DOMAINNAME}`) && PathPrefix(`/outpost.goauthentik.io/`)"
Provider Creation (Individual Application) - Manual
In the Admin Interface, go to:
2. Applications
3. Providers
4. Create
Select Proxy Provider
Use the following settings:
- Name:
whoami-individual provider - Authentication Flow:
empty
default-provider-authorization-explicit-consent (Authorize Application) - Type:
Forward auth (single application)
Single Application is where we change it up! - External Host:
https://whoami-individual.domain.tld - Token Validity:
hours=24
After hitting Finish it will show that it’s not bound to an Application:
Application Creation (Individual Application) - Manual
- Applications
- Applications
- Create
- Name:
whoami-individual application - Slug:
whoami-individual-application - Group:
empty - Provider:
This is where you bind it to the previously created provider! - Backchannel Providers:
any - UI Settings
- Launch URL:
Since this is an individual application, specify where it is found at
- Launch URL:
Embedded Outpost (Individual Application)
- Applications
- Outposts
Highlight any application you want the outpost to be able to provide for. In this case Highlight whoami-individual application
BEFORE HIGHLIGHT
Notice that BEFORE highlighting and adding to Selected Applications, it still has only the Domain Wide Forward Auth Catch All rule in Selected Applications:
AFTER HIGHLIGHT
After hitting Update the Outpost page will show that the embedded outpost now has both providers bound to it:
Individual Application Test/Validation
Now that the individual application rule is in place, validate it using the already running whoami-individual container created:
Navigate to whoami-individual.domain.tld and it will immediately redirect you to Authentik to login:
X-Authentik-Meta-App: whoami-individual-application
(Optional) New User Creation
- Directory
- Users
- Create
Fill in the required information:
(Optional) Add user to Administrator/Superuser Group
Inside the Admin Interface do the following steps to add a user to the Admins group:
- Directory
- Groups
- Left click/Open
authentik Admins
Next, add an existing user to the Users tab:
- Users
- Add existing user
Add the user
(Optional) Change user password
Inside the Admin Interface do the following:
- Directory
- Users
- Left click/Open the specific user
Yubikey
Read this section before just doing it!
https://docs.goauthentik.io/docs/flow/stages/authenticator_webauthn/#authenticator-attachment
[!WARNING]
To prevent locking yourself out and having to start over by deleting your postgres database, create a backup administrator (as done above) or work on a non-administrator account.
[!NOTE]
If you are unable to perform the below steps, skip to the Force Authentication section below.
Recommended to Switch to standard browser / NOT Incognito.
IF you are in the Admin Interface navigate to the User Interface via the button at the top left:
Navigate to the MFA Devices screen:
- Settings
- MFA Devices
- Enroll
- WebAuthn device
Enrollment with Credential on Key
If you are unsure about this, then review the following Yubikey documentation / explanation (Yubico Support Guest Portal)
If you are being prompted for a PIN (including setting one up), and you’re not sure which PIN it is, most likely it is your YubiKey’s FIDO2 PIN.
Now complete the WebAuthn Setup:
Hit next and you’ll see that you are about to setup your key:
[!CAUTION]
By performing the setup like this, it asks to create a credential on the Yubikey device itself. If you want to make it where it does NOT create the credential itself skip setup for now and go to theModify WebAuthn Credential Creation Locationsection where I will show how to change the save credential to key option. After changing that option, you can revisit setup.
STOP - Read the Above Caution Statement before continuing!
If you’re ok with creating the credential on your key, continue!
- Go to the Admin Interface
- Flows and Stages
- Stages
- Edit
default-authenticator-webauthn-setup
Review the default settings:
Edit the Resident key requirement
- Default:
Preferred: The authenticator can create and store a dedicated credential, but if it doesn't that's alright too
Unfortunately, if I try to skip the dedicated credential, I am unable to setup a Yubikey. I am going to set this option to:
- Modified:
Discouraged: The authenticator should not create a dedicated credential
(Optional) Edit the User verification depending on your WebAuthn expertise.
I am leaving it default:
- Default:
Preferred: User verification is preferred if available, but not required
(Optional) Authenticator preference
Authentik by default has no preference set for the Authenticator, as shown in the above picture. This can be changed to be explicitly Yubikey OR Windows Hello/TouchID. If you do not want to be prompted by Windows Hello, as shown in the Windows Hello section, then set this to A "roaming" authenticator, like a YubiKey.
Finish Registration
If you chose to NOT save your key on the Yubikey like above, then scroll back up to continue the registration / finish it.
(Troubleshooting) Windows Hello
Press ESC to continue to actual Yubikey enrollment. This only seems to happen if you have previously setup Windows Hello.
[!NOTE]
If you are prompted for a PIN that you do not know, go to theEnrollment with Credential on Keysection for the Yubikey documentation link to address the PIN. Optionally, you can also Force it to skip Windows Hello and go straight to the Yubikey by modifying thedefault-authenticator-webauthn-setup, as seen in the(Optional) Authenticator preferencesection above.
(Optional) Force Multi-Factor Authentication (MFA)
- Flows & Stages
- Stages
- Edit
default-authentication-mfa-validation
Change the Device Classes to what options you want you or other users to have (by default). I am only going to REMOVE static tokens.
Modify the Not configured action to Force the user to configure an authenticator:
- Default:
Continue - Modified:
After setting the Not configured action to Force the user to configure an authenticator it will unlock the Configuration stages options as seen above.
This section, as it says right below it
Stages used to configure Authenticator when user doesn’t have any compatible devices. After this configuration Stage passes, the user is not prompted again.
When multiple stages are selected, the user can choose which one they want to enroll.
- Select:
default-authenticator-totp-setup (TOP Authenticator Setup Stage) - Select:
default-authenticator-webauthn-setup (WebAuthn Authenticator Setup Stage)
In order to highlight multiple, use the Shift key.
Hit Update
Open another INCOGNITO browser and navigate back to the whoami-individual URL or authentik’s URL and sign in.
After entering the username/password a new window pop-up asks to select an authenticator method – choose default-authenticator-webauthn-setup. The following steps should match the Yubikey section above.
This will only give you this option if you did not previously register your Yubikey inside of the MFA devices.
Domain Wide (Tenet) Policies
View the Default Flows by going to the Admin Interface
- System
- Brands
- Edit
authentik-default
Expand down Default flows
Notice that the DEFAULT Authentication flow is default-authentication-flow (Welcome to authentik!)
Navigate to:
- Flows and Stages
- Flows
In order to view the default default-authentication-flow.
Why does this matter? To understand the way YOU have this identity tool setup.
graph LR
B --> C[Authorization];
C --> D[Login];
Authentication default
graph LR
A[Start] --> B[Username];
B --> C[Password];
C --> D{MFA Configured?};
D -->|No| F[Login];
E --> F;
Authorization defaults
Explicit
graph LR
A[Start] --> B[Consent];
B --> C[Continue];
Implicit
graph LR
A[Start] --> B[Continue];
