In Part 1, we explored the overall architecture and set up the VPS-based Pangolin stack as our secure gateway. Now, we’ll focus on implementing the home network side - specifically creating an isolated environment for internet-exposed applications while keeping the rest of your network completely secure.
Setting Up the Isolated Network for Exposed Applications
The cornerstone of our security model is proper network isolation. We’ll implement this using a combination of VLANs, VM isolation, and Docker networks.
1. Creating Network Segments with VLANs
Most modern home routers and switches support VLANs. If yours doesn’t, consider upgrading to one that does, such as:
- UniFi Dream Machine
- pfSense/OPNsense on dedicated hardware
- Managed switches with VLAN support
Here’s how to configure the network segments:
Management VLAN (ID: 10)
Network: 192.168.10.0/24
Gateway: 192.168.10.1
DHCP: Enabled (192.168.10.100-192.168.10.200)
Purpose: Hypervisor management, admin access
Exposed Apps VLAN (ID: 20)
Network: 192.168.20.0/24
Gateway: 192.168.20.1
DHCP: Enabled (192.168.20.100-192.168.20.200)
Purpose: VMs running Newt and internet-exposed applications
Private Apps VLAN (ID: 30)
Network: 192.168.30.0/24
Gateway: 192.168.30.1
DHCP: Enabled (192.168.30.100-192.168.30.200)
Purpose: Internal applications, never exposed to internet
Firewall Rules Implementation
Configure your router/firewall with these rules between VLANs:
# From Management (VLAN 10) to Exposed Apps (VLAN 20)
allow TCP/22 (SSH)
allow TCP/8006 (Proxmox VE)
deny all other traffic
# From Management (VLAN 10) to Private Apps (VLAN 30)
allow TCP/22 (SSH)
allow TCP/80,443 (HTTP/HTTPS)
# From Exposed Apps (VLAN 20) to Management (VLAN 10)
deny all traffic
# From Exposed Apps (VLAN 20) to Private Apps (VLAN 30)
deny all traffic
# From Exposed Apps (VLAN 20) to Internet
allow all traffic
# From Private Apps (VLAN 30) to Management (VLAN 10)
deny all traffic
# From Private Apps (VLAN 30) to Exposed Apps (VLAN 20)
deny all traffic
# From Private Apps (VLAN 30) to Internet
allow HTTP/HTTPS for updates only
2. Setting Up the Proxmox Host
Configure Proxmox networking to support the VLAN setup:
- Log into Proxmox web interface
- Navigate to System > Network
- Create VLAN interfaces:
# Management Network
Type: VLAN
VLAN Tag: 10
Bridge ports: vmbr0
IP address: 192.168.10.2/24
# Exposed Apps Network
Type: VLAN
VLAN Tag: 20
Bridge ports: vmbr0
IP address: none (we'll assign in VM)
# Private Apps Network
Type: VLAN
VLAN Tag: 30
Bridge ports: vmbr0
Apply the changes and reboot if needed.
3. Creating the Exposed Applications VM
This VM will host Newt and the applications you want to expose to the internet. It will have limited network visibility.
- In Proxmox, create a new VM:
General:
- Name: exposed-apps-vm
- Start at boot: Yes
OS:
- Use ISO image: ubuntu-22.04-server-amd64.iso
- Type: Linux
- Version: Ubuntu 22.04
System:
- Graphics card: Default
- SCSI Controller: VirtIO SCSI
Disks:
- Storage: local-lvm
- Disk size: 100 GB
- Format: qcow2
- Cache: writeback
CPU:
- Sockets: 1
- Cores: 4
Memory:
- Memory: 8192 MB
Network:
- Bridge: vmbr0.20 (Exposed Apps VLAN)
- Model: VirtIO
- Install Ubuntu Server 22.04 LTS following the standard installation process
- Configure static IP on the VM:
Edit /etc/netplan/00-installer-config.yaml:
network:
version: 2
ethernets:
ens18:
addresses:
- 192.168.20.10/24
gateway4: 192.168.20.1
nameservers:
addresses: [1.1.1.1, 8.8.8.8]
Apply with:
sudo netplan apply
4. Setting Up Docker with Network Isolation
Install Docker and create isolated networks:
# Install Docker
curl -fsSL https://get.docker.com -o get-docker.sh
sudo sh get-docker.sh
# Create dedicated networks for exposed applications
docker network create --subnet=172.20.0.0/16 exposed-apps
Implementing Newt in a Confined Environment
Newt will run in a Docker container, further isolating it from the host system and only allowing it to communicate with specific application containers.
1. Setting Up Newt Container
Create a dedicated directory for Newt:
mkdir -p /opt/newt
cd /opt/newt
Create a docker-compose.yml file:
exposed-apps:
external: true
newt:
container_name: newt-client
image: fosrl/newt:latest
- PANGOLIN_ENDPOINT=https://pangolin.yourdomain.com
- NEWT_ID=your_newt_id_from_pangolin
- NEWT_SECRET=your_newt_secret_from_pangolin
exposed-apps:
ipv4_address: 172.20.0.2
cap_add:
- NET_ADMIN
- ./logs:/var/log/newt
2. Getting Configuration from Pangolin
To obtain the Newt ID and secret, you need to:
- Log into your Pangolin dashboard on the VPS
- Create a new organization if you don’t have one
- Create a new site (select “Newt” as the connection method)
- Copy the generated ID and secret
- Update your
docker-compose.ymlwith these values
3. Starting and Securing Newt
Start the Newt container:
docker compose up -d
Check that it’s running and connecting correctly:
docker logs -f newt-client
You should see messages about establishing a connection to Pangolin and creating a WireGuard interface. If everything is working, the site status in Pangolin should change to “Online”.
Connecting Exposed Applications
Now we’ll set up the applications that should be exposed to the internet. We’ll create a separate Docker Compose file for each application, ensuring they’re isolated but accessible through Newt.
1. Example: Setting Up Nextcloud
Create directory:
mkdir -p /opt/nextcloud
cd /opt/nextcloud
Create docker-compose.yml:
exposed-apps:
external: true
nextcloud-internal:
internal: true
nextcloud-db:
image: mariadb:10.6
container_name: nextcloud-db
command: --transaction-isolation=READ-COMMITTED --log-bin=binlog --binlog-format=ROW
- nextcloud-internal
- ./nextcloud-db:/var/lib/mysql
- MYSQL_ROOT_PASSWORD=secure_root_password
- MYSQL_PASSWORD=secure_nextcloud_password
- MYSQL_DATABASE=nextcloud
- MYSQL_USER=nextcloud
nextcloud-app:
image: nextcloud:latest
container_name: nextcloud-app
depends_on:
- nextcloud-db
nextcloud-internal:
exposed-apps:
ipv4_address: 172.20.0.10
- ./nextcloud-data:/var/www/html
- MYSQL_HOST=nextcloud-db
- NEXTCLOUD_TRUSTED_DOMAINS=nextcloud.yourdomain.com
- OVERWRITEPROTOCOL=https
Start Nextcloud:
2. Example: Setting Up Jellyfin
Create directory:
mkdir -p /opt/jellyfin
cd /opt/jellyfin
exposed-apps:
external: true
jellyfin:
image: jellyfin/jellyfin:latest
container_name: jellyfin
exposed-apps:
ipv4_address: 172.20.0.11
- ./config:/config
- ./cache:/cache
- /path/to/media:/media
- JELLYFIN_PublishedServerUrl=jellyfin.yourdomain.com
Start Jellyfin:
3. Configuring Resources in Pangolin
For each application, you need to create a resource in Pangolin:
- Log into Pangolin dashboard
- Go to Resources tab and click “Add Resource”
- Fill in details:
- Name: Nextcloud
- Subdomain: nextcloud (will become nextcloud.yourdomain.com)
- Site: Select your site with Newt
- Click “Create Resource”
- On the Connectivity tab:
- Enable SSL: Yes
- Add a target:
- Method: HTTP
- IP Address: 172.20.0.10 (Nextcloud’s IP on the exposed-apps network)
- Port: 80
- Click “Add Target” and “Save Changes”
- On the Authentication tab:
- Configure desired authentication method
- Save changes
Repeat for each application you want to expose.
Security Monitoring and Logging
To ensure your setup remains secure, implement comprehensive monitoring:
1. Setting Up Prometheus and Grafana for Monitoring
Create a monitoring stack in your Private Apps VM:
private-apps:
external: true
prometheus:
image: prom/prometheus:latest
container_name: prometheus
- private-apps
- ./prometheus:/etc/prometheus
- prometheus-data:/prometheus
command:
- '--config.file=/etc/prometheus/prometheus.yml'
- '--storage.tsdb.path=/prometheus'
- '--web.console.libraries=/etc/prometheus/console_libraries'
- '--web.console.templates=/etc/prometheus/consoles'
- '--web.enable-lifecycle'
grafana:
image: grafana/grafana:latest
container_name: grafana
- private-apps
- grafana-data:/var/lib/grafana
- GF_SECURITY_ADMIN_PASSWORD=secure_grafana_password
- GF_USERS_ALLOW_SIGN_UP=false
prometheus-data:
grafana-data:
2. Centralizing Logs with Loki and Promtail
Add to your monitoring stack:
loki:
image: grafana/loki:latest
container_name: loki
- private-apps
- ./loki:/etc/loki
- loki-data:/loki
command: -config.file=/etc/loki/loki-config.yml
promtail:
image: grafana/promtail:latest
container_name: promtail
- private-apps
- ./promtail:/etc/promtail
- /var/log:/var/log
- /var/lib/docker/containers:/var/lib/docker/containers:ro
command: -config.file=/etc/promtail/promtail-config.yml
loki-data:
3. Security Alerts and Monitoring
Create Grafana dashboards for:
- Newt connection status
- Failed authentication attempts on Pangolin
- CrowdSec alerts and actions
- Network traffic patterns
- Connection attempts between isolated networks
Testing the Security Boundaries
Verify that your isolation is working as expected with these tests:
1. Network Connectivity Tests
Test isolation from the Exposed Apps VM:
# Should fail - no route to Management VLAN
ping 192.168.10.1
# Should fail - no route to Private VLAN
ping 192.168.30.1
# Should succeed - internet connectivity
ping 8.8.8.8
2. Application Access Tests
Access https://nextcloud.yourdomain.com from external network
- Should prompt for authentication through Pangolin
- After auth, should access Nextcloud
Try accessing the raw IP directly:
- http://172.20.0.10 from local network
- Should fail due to network isolation
Test internal services from external network:
- Try accessing AdGuard Home or other private services
- Should be completely inaccessible
3. Security Scanning
Run security scans against your exposed domain:
# Install nmap
apt install nmap
# Scan exposed ports
nmap -sS -sV yourdomain.com
# Only ports 80, 443 and 51820 should be visible
Maintenance and Updates
Updating Pangolin Stack
Update the Pangolin stack on your VPS:
cd /opt/pangolin
docker compose pull
docker compose down
Updating Newt
Update Newt on your Exposed Apps VM:
cd /opt/newt
docker compose pull
docker compose down
Updating Applications
Each application should be updated according to its own schedule:
cd /opt/application-directory
docker compose pull
docker compose down
Benefits of This Architecture
This architecture provides several key advantages:
Zero Trust Security Model
- Every connection requires authentication
- Network segments have no implicit trust
- Applications are isolated from each other
No Exposure of Home Network
- VPS serves as the only internet-facing component
- No port forwarding on home router
- Home IP address remains private
Simplified Management
- Centralized authentication through Pangolin
- Consistent access control across all applications
- Easy addition of new exposed services
Resilience to IP Changes
- Home network can have dynamic IP
- WireGuard tunnel re-establishes automatically
- Services remain available during IP transitions
Enhanced Monitoring
- Centralized logging of access attempts
- Clear visibility of traffic patterns
- Anomaly detection across the security boundary
- Ability to quickly identify potential compromise
- Historical trends for capacity planning
Disaster Recovery Planning
Despite the security benefits of this architecture, it’s essential to plan for potential failures. Here’s how to ensure service continuity:
1. Backup Strategy
Implement a comprehensive backup strategy:
# Create backup script for Pangolin configuration
mkdir -p /opt/pangolin/backups
cat > /opt/pangolin/backup.sh << 'EOF'
#!/bin/bash
DATE=$(date +%Y-%m-%d)
BACKUP_DIR="/opt/pangolin/backups"
CONFIG_DIR="/opt/pangolin/config"
# Stop services to ensure consistent backup
cd /opt/pangolin
docker compose stop pangolin
# Create backup archive
tar -czf "$BACKUP_DIR/pangolin-config-$DATE.tar.gz" -C "$CONFIG_DIR" .
# Restart services
docker compose start pangolin
# Retain only last 7 backups
find "$BACKUP_DIR" -name "pangolin-config-*.tar.gz" -type f -mtime +7 -delete
EOF
chmod +x /opt/pangolin/backup.sh
Schedule this backup to run daily:
# Add to crontab
(crontab -l 2>/dev/null; echo "0 2 * * * /opt/pangolin/backup.sh") | crontab -
2. Failover VPS Configuration(only tested with cf)
For critical applications, consider setting up a standby VPS:
- Provision a second VPS with identical configuration
- Regularly sync Pangolin configuration to the standby:
rsync -avz --delete /opt/pangolin/config/ standby-vps:/opt/pangolin/config/ - Configure DNS with low TTL (Time To Live) values
- Create a simple health check script:
cat > /opt/health-check.sh << 'EOF' #!/bin/bash MAIN_VPS="pangolin.yourdomain.com" BACKUP_VPS="standby.yourdomain.com" DNS_API_KEY="your_dns_provider_api_key" # Check if main VPS is responding if curl -s --max-time 10 https://$MAIN_VPS/api/v1/health > /dev/null; then echo "Main VPS is healthy" exit 0 fi # If we got here, main VPS is down, activate failover echo "Main VPS appears down, activating failover..." # Update DNS record (example using Cloudflare API) curl -X PATCH "https://api.cloudflare.com/client/v4/zones/$ZONE_ID/dns_records/$RECORD_ID" \ -H "Authorization: Bearer $DNS_API_KEY" \ -H "Content-Type: application/json" \ --data '{"content":"'"$BACKUP_VPS_IP"'"}' echo "Failover complete. DNS should propagate shortly." EOF chmod +x /opt/health-check.sh
3. Recovery Documentation
Create detailed recovery documentation that includes:
- Complete network diagram with all IP addresses and VLANs
- Step-by-step recovery instructions for each component
- Configuration backup locations and restoration procedures
- Contact information for service providers and domain registrars
- Credentials stored in a secure password manager
Advanced Network Hardening
To further strengthen your setup, consider these advanced hardening techniques:
1. Implement Network Intrusion Detection (Use at your own desecration)
Deploy Suricata in IDS mode on your router/firewall to detect suspicious activities:
# Install Suricata on a dedicated monitoring system or security gateway
apt install suricata
# Configure Suricata to monitor traffic between VLANs
cat > /etc/suricata/suricata.yaml << 'EOF'
# Suricata configuration snippet
af-packet:
- interface: eth0.20
cluster-id: 99
cluster-type: cluster_flow
defrag: yes
- interface: eth0.30
cluster-id: 98
defrag: yes
EOF
# Enable and start Suricata
systemctl enable suricata
systemctl start suricata
2. Implement MAC Address Filtering (Use at your own desecration)
For an additional layer of security, implement MAC address filtering on your router/switch to only allow known devices on each VLAN:
# Example configuration for UniFi Security Gateway
config firewall rule {
name 'VLAN20 MAC Filter'
description 'Only allow authorized devices on Exposed Apps VLAN'
default-action drop
rule {
action accept
description 'Allow Exposed Apps VM'
mac-address AA:BB:CC:DD:EE:FF
interface eth0.20
3. Regular Security Auditing
Implement regular security audits:
# Create security audit script
cat > /opt/security-audit.sh << 'EOF'
#!/bin/bash
REPORT_DIR="/opt/security/reports"
mkdir -p $REPORT_DIR
echo "Starting security audit on $DATE" > "$REPORT_DIR/audit-$DATE.log"
# Check for unauthorized containers on exposed network
echo "=== Exposed network containers ===" >> "$REPORT_DIR/audit-$DATE.log"
docker network inspect exposed-apps | grep -E '"Name"|"IPv4Address"' >> "$REPORT_DIR/audit-$DATE.log"
# Check for unauthorized connections
echo "=== Unexpected connections ===" >> "$REPORT_DIR/audit-$DATE.log"
netstat -tnp | grep -v -E '(127.0.0.1|172.20.0)' >> "$REPORT_DIR/audit-$DATE.log"
# Check Docker image vulnerabilities
echo "=== Container vulnerabilities ===" >> "$REPORT_DIR/audit-$DATE.log"
for container in $(docker ps --format '{{.Image}}'); do
trivy image $container --severity HIGH,CRITICAL >> "$REPORT_DIR/audit-$DATE.log"
done
# Check for failed authentication attempts
echo "=== Failed authentications ===" >> "$REPORT_DIR/audit-$DATE.log"
grep "authentication failure" /var/log/auth.log | tail -100 >> "$REPORT_DIR/audit-$DATE.log"
echo "Security audit complete. Report saved to $REPORT_DIR/audit-$DATE.log"
EOF
chmod +x /opt/security-audit.sh
Schedule weekly audits:
(crontab -l 2>/dev/null; echo "0 3 * * 0 /opt/security-audit.sh") | crontab -
Scaling the Architecture
As your self-hosting needs grow, you may need to scale this architecture. Here’s how to do it seamlessly:
1. Multiple Application Groups
You can create multiple isolated application groups by replicating the pattern:
# Create additional isolated networks
docker network create --subnet=172.21.0.0/16 media-apps
docker network create --subnet=172.22.0.0/16 productivity-apps
docker network create --subnet=172.23.0.0/16 game-servers
Each network would have its own Newt client with specific access restrictions:
# Example media-apps Newt client
media-apps:
external: true
media-newt:
container_name: media-newt-client
- NEWT_ID=media_newt_id_from_pangolin
- NEWT_SECRET=media_newt_secret_from_pangolin
media-apps:
ipv4_address: 172.21.0.2
cap_add:
- NET_ADMIN
2. Multiple Physical Locations
If you have applications in multiple physical locations, you can set up Newt clients at each location:
- Create a site in Pangolin for each location
- Deploy Newt to each location
- Configure resources to use the appropriate site
- Maintain separate network isolation at each location
Performance Optimization
While security is the primary focus, performance optimization ensures a good user experience:
1. Content Delivery Optimization
Implement Traefik cache middleware on your Pangolin VPS:
# Add to Traefik configuration
http:
middlewares:
cache:
plugin:
souin:
default_cache:
ttl: "3600s"
urls:
"static.yourdomain.com":
ttl: "86400s"
"media.yourdomain.com/thumbnails":
ttl: "43200s"
default_cache_control: "public, max-age=86400"
log_level: "info"
2. Application-Specific Optimizations
For media streaming applications like Jellyfin, optimize for direct streaming:
# Jellyfin container configuration
- JELLYFIN_FFmpegProbeSize=10000000
- JELLYFIN_TranscodingTempPath=/transcode
- JELLYFIN_EnableHardwareEncoding=true
- /dev/dri:/dev/dri # For hardware acceleration
- ./transcode:/transcode
- ./config:/config
- ./media:/media:ro
Troubleshooting Common Issues
Prepare for common issues by documenting troubleshooting steps:
1. Tunnel Connectivity Issues
If Newt loses connection to Pangolin:
# Check Newt logs
docker logs newt-client
# Check route table
ip route
# Test connection to Pangolin
curl -v --max-time 10 https://pangolin.yourdomain.com/api/v1/health
# Restart Newt if needed
docker compose restart newt
2. Application Access Issues
If applications are inaccessible:
# Verify application container is running
docker ps | grep application-name
# Check application logs
docker logs application-container
# Verify network connectivity from Newt to application
docker exec -it newt-client ping 172.20.0.10
# Check Pangolin resource configuration
curl -v --max-time 10 https://pangolin.yourdomain.com/api/v1/resources/application-name
3. Authentication Issues
If users can’t authenticate:
# Check Pangolin authentication logs
docker logs pangolin | grep "authentication"
# Verify Traefik is forwarding authentication headers
docker logs traefik | grep "forward auth"
# Test authentication flow
curl -v --max-time 10 https://pangolin.yourdomain.com/api/v1/auth/check
# Restart authentication components if needed
docker compose restart pangolin traefik
Future Enhancements
Consider these future enhancements to further improve your setup:
1. Geo-Location Based Access Control
Implement country-based restrictions:
# Add GeoIP middleware to Traefik
http:
middlewares:
country-whitelist:
ipWhiteList:
sourceRange:
- "10.0.0.0/8" # Local networks
ipStrategy:
depth: 1
geoip:
countries:
- "US"
- "CA"
3. Behavioral Analytics
Implement advanced threat detection using behavioral analytics:
# Deploy Elastic Stack for behavioral analytics
elasticsearch:
image: docker.elastic.co/elasticsearch/elasticsearch:8.7.0
- discovery.type=single-node
- xpack.security.enabled=true
- ELASTIC_PASSWORD=secure_elastic_password
kibana:
image: docker.elastic.co/kibana/kibana:8.7.0
- ELASTICSEARCH_HOSTS=http://elasticsearch:9200
elastic-agent:
image: docker.elastic.co/beats/elastic-agent:8.7.0
- FLEET_ENROLLMENT_TOKEN=your_fleet_token
- FLEET_URL=https://fleet.yourdomain.com
- FLEET_INSECURE=false
The multi-part architecture we’ve designed creates a robust, secure environment for hosting internet-accessible applications while maintaining strong isolation principles. By placing Pangolin on a VPS and running Newt in an isolated environment on your local network, you’ve created a security model with multiple layers of protection.
Key benefits of this implementation include:
- Complete network isolation between internet-exposed and private applications
- Zero-trust security model where all access requires explicit authentication
- No direct internet exposure of your home network or private services
- Centralized management through the Pangolin dashboard
- Flexible scaling options for future growth
- Resilience to network changes through WireGuard’s persistent tunnels
- Comprehensive monitoring and security controls
By following this architecture, you’ve created a setup that rivals commercial solutions while maintaining complete control over your data and infrastructure. As self-hosting becomes increasingly popular, this approach provides the perfect balance between accessibility and security.
Remember that security is an ongoing process. Regularly update all components, review logs, conduct security audits, and stay informed about emerging threats to ensure your self-hosted infrastructure remains safe and reliable.
