Secure Pangolin Integration with Traefik(Rick and roll)
Overview
This guide covers setting up Pangolin with Traefik, including comprehensive security measures like CrowdSec integration, malicious request blocking, and proper header management.
Configuration Components
Basic Traefik Setup
http:
  middlewares:
    # Basic HTTPS redirection
    redirect-to-https:
      redirectScheme:
        scheme: https
    # Internal network whitelist
    default-whitelist:
      ipWhiteList:
        sourceRange:
        - "10.0.0.0/8"
        - "192.168.0.0/16"
        - "172.16.0.0/12"
Security Headers
Essential security headers to protect against common web vulnerabilities:
    security-headers:
      headers:
        customResponseHeaders:
          Server: ""
          X-Powered-By: ""
          X-Forwarded-Proto: "https"
        sslProxyHeaders:
        hostsProxyHeaders:
          - "X-Forwarded-Host"
        contentTypeNosniff: true
        customFrameOptionsValue: "SAMEORIGIN"
        referrerPolicy: "strict-origin-when-cross-origin"
        forceSTSHeader: true
        stsIncludeSubdomains: true
        stsSeconds: 63072000
        stsPreload: true
        browserXssFilter: true
Malicious Request Protection
Redirects potential attack attempts to a Rick Roll video:
    security-redirects:
      redirectRegex:
        permanent: false
        regex:
          - "^.*/wp-.*"
          - "^.*\.(php|asp|aspx|jsp|cgi|sql|sqlite|sq3|sh)$"
          - "^.*(administrator|phpmyadmin|myadmin|mysql|wp|xmlrpc|Autodiscover|console).*"
          - "^.*(\.env|\.git|\.svn|\.hg|\.DS_Store|wp-config\.php|web\.config|.htaccess).*"
          - "^.*(nmap|nikto|sqlmap|xerosploit|slowloris|shell|backdoor|hack).*"
        replacement: "https://www.youtube.com/watch?v=dQw4w9WgXcQ"
Router Configuration
Setting up routes for different components:
  routers:
    # HTTPS redirect
    main-app-router-redirect:
      rule: "Host(`your-domain.com`)"
      service: next-service
      entryPoints:
        - web
      middlewares:
        - redirect-to-https
    # Next.js application
    next-router:
      rule: "Host(`your-domain.com`) && !PathPrefix(`/api/v1`)"
      entryPoints:
        - websecure
      middlewares:
        - security-headers
        - security-redirects
      tls:
        certResolver: letsencrypt
    # API endpoints
    api-router:
      rule: "Host(`your-domain.com`) && PathPrefix(`/api/v1`)"
      service: api-service
      entryPoints:
        - websecure
      middlewares:
        - security-headers
      tls:
Service Definitions
Backend service configuration:
    next-service:
      loadBalancer:
        servers:
          - url: "http://pangolin:3002"
    api-service:
      loadBalancer:
        servers:
          - url: "http://pangolin:3000"
Implementation Steps
  1. Prerequisites
    • Traefik installed and running
    • Valid SSL certificate setup (Let’s Encrypt)
    • Pangolin application ready for deployment
  2. Configuration File Setup
    • Create a new file named traefik-pangolin.yml
    • Copy the complete configuration provided above
    • Replace placeholder values:
      • your-domain.com with your actual domain
      • Adjust IP addresses and ports as needed
  3. Security Measures
    • HTTPS redirection enforced
    • Strict security headers implemented
    • Malicious request blocking
    • Internal network whitelisting
  4. Validation
    • Test HTTPS redirection
    • Verify security headers using tools like SecurityHeaders.com
    • Verify WebSocket connections
Maintenance and Monitoring
  1. Regular Updates
    • Keep Traefik updated
    • Review and update security rules
  2. Monitoring
    • Monitor Traefik logs for issues
    • Review access patterns regularly
  3. SSL Certificate Management
    • Ensure automatic renewal is working
    • Monitor certificate expiration dates
Best Practices
  1. Security
    • Regularly rotate API keys
    • Keep middleware chains minimal for performance
    • Use specific routing rules to avoid conflicts
  2. Performance
    • Monitor response times
    • Adjust buffer sizes if needed
    • Consider implementing rate limiting
  3. Maintenance
    • Document all custom configurations
    • Keep backups of working configurations
    • Test changes in staging first
Thank you for sharing, this is very useful.
My approach is taking this over to my Coolify setup too, not just my Pangolin one.
have fun with this, this comes from my old nginx deployment.
Bro your username missing a ‘g’ :grinning_face_with_smiling_eyes:
I know. It’s from day one. It’s a good omen.
