Script to migrate from Dashy to Homepage
Script to migrate from Dashy (https://dashy.to/) to Homepage (https://gethomepage.dev/)
Get your config.yml from Dashy and place it in the same folder as this script.
Run the script with Python.
The script takes a list of known services that have Widgets in Dashy and tries to automatically match your existing entries to this list, to decide whether an entry should be a bookmark or a service entry.
Adjust MATCH_THRESHOLD as needed depending on how much your titles match service names.
import yaml
import difflib
# Threshold for fuzzy matching (0.0 to 1.0)
MATCH_THRESHOLD = 0.85
with open("dashy_config.yml", "r", encoding="utf-8") as f:
    dashy_config = yaml.safe_load(f.read())
homepage_bookmarks = []
homepage_services = []
KNOWN_SERVICES = """Adguard Home
Atsumeru
Audiobookshelf
Authentik
Autobrr
Azure DevOps
Bazarr
Caddy
Calendar
Calibre-web
Changedetection.io
Channels DVR Server
Cloudflare Tunnels
Coin Market Cap
Crowdsec
Custom API
Deluge
DeveLanCacheUI
Synology Disk Station
Synology Download Station
Emby
ESPHome
EVCC
Fileflows
Flood
FreshRSS
Frigate
FRITZ!Box
GameDig
Gatus
Ghostfolio
Gitea
Glances
Gluetun
Gotify
Grafana
HDHomerun
Health checks
Home Assistant
Homebox
Homebridge
iFrame
Immich
Jackett
JDownloader
Jellyfin
Jellyseerr
Kavita
Komga
Kopia
Lidarr
Linkwarden
LubeLogger
Mastodon
Mailcow
Mealie
Medusa
Mikrotik
Minecraft
Miniflux
MJPEG
Moonraker (Klipper)
Mylar3
MySpeed
Navidrome
Netdata
NetAlertX
Nextcloud
NextDNS
Nginx Proxy Manager
NZBget
OctoPrint
Omada
Ombi
OpenDTU
OpenMediaVault
OPNSense
OpenWRT
Overseerr
Paperless-ngx
PeaNUT
PhotoPrism
PiHole
Plant-it
Tautulli (Plex)
Plex
Portainer
Prometheus
Prowlarr
Proxmox
Proxmox Backup Server
Pterodactyl
Pyload
qBittorrent
QNAP
Radarr
Readarr
Romm
ruTorrent
SABnzbd
Scrutiny
Sonarr
Speedtest Tracker
Stash
Stocks
SWAG Dashboard
Syncthing Relay Server
Tailscale
Tandoor
Technitium DNS Server
Tdarr
Traefik
Transmission
TrueNas
Tube Archivist
Unifi Controller
Unmanic
Uptime Kuma
UptimeRobot
UrBackup
Vikunja
Watchtower
Wg-Easy
What's Up Docker
Xteve
Zabbix
Date & Time
Glances
Greeting
Kubernetes
Logo
Longhorn
Open-Meteo
OpenWeatherMap
Resources
Search
Stocks
Unifi Controller
Weather API"""
# Convert known services to a list and normalize
known_services_list = [service.strip().lower().replace(" ", "") for service in KNOWN_SERVICES.split("\n")]
def is_known_service(title):
    Check if a title matches any known service using fuzzy matching
    # Normalize the title
    normalized_title = title.strip().lower().replace(" ", "")
    # Use difflib to find the closest match
    matches = difflib.get_close_matches(normalized_title, known_services_list, n=1, cutoff=MATCH_THRESHOLD)
    return len(matches) > 0
for dashy_section in dashy_config['sections']:
    services_entries = []
    bookmarks_entries = []
    for dashy_entry in dashy_section['items']:
        entry = {
            dashy_entry['title']: {
                "href": dashy_entry["url"],
                "description": dashy_entry.get("description", "")
        entry_bookmark = {
            dashy_entry['title']: [{
                "abbr": dashy_entry['title'][0:2].upper()
        # Check if the entry is a known service
        if is_known_service(dashy_entry['title']):
            services_entries.append(entry)
        else:
            bookmarks_entries.append(entry_bookmark)
    # Only add sections that have entries
    if services_entries:
        homepage_services.append({
            dashy_section['name']: services_entries
    if bookmarks_entries:
        homepage_bookmarks.append({
            dashy_section['name']: bookmarks_entries
homepage_bookmarks = yaml.dump(homepage_bookmarks)
homepage_services = yaml.dump(homepage_services)
with open("services.yaml", "w+", encoding="utf-8") as f:
    f.write(f"""---
# For configuration options and examples, please see:
# https://gethomepage.dev/latest/configs/services
# Converted from Dashy
{homepage_services}""")
with open("bookmarks.yaml", "w+", encoding="utf-8") as f:
    f.write(f"""---
# https://gethomepage.dev/latest/configs/bookmarks
{homepage_bookmarks}""")
Awesome script hhf!
It is worth mentioning that with all due respect to Dashy as service, it is considered not very safe.
You mean dashy is unsafe to Use, correct? or any vun are there in the script which is migrating to homepage. Just trying to understand.
Yeah, kinda.
The article highlights that Dashy’s authentication is insecure because it relies entirely on client-side mechanisms, making it vulnerable to bypassing through browser developer tools. Sensitive configurations, including API keys, can be accessed and modified without authentication due to the lack of server-side checks. This poses risks for self-hosters, especially if Dashy is exposed to the internet or holds confidential information. The recommendation is to avoid relying on Dashy’s built-in security and use external solutions like reverse proxies for protection.
