#!/bin/bash
#v0.10.2
########################unraid-snapshot-zfs#######################
###################### User Defined Options ######################
# List your ZFS datasets. You can add/remove sets
# readarray -t DATASETS < <(zfs list -o name -H) # when replacing DATASETS below, should return all pools/Datasets, not thoroughly tested yet. If you test this let me know!
DATASET=("zfsbackup/cachebackup")
mapfile -t DATASETS < <(zfs list -r -o name -H "${DATASET}")
# Set Number of Snapshots to Keep
SHANPSHOT_QTY=24
# Snapshot Name Format
SNAPSHOTNAME=$(date "+simplesnap_%Y-%m-%d-%H:%M:%S")
###### Don't change below unless you know what you're doing ######
echo "Starting Snapshot ${SNAPSHOTNAME}"
echo "_____________________________________________________________"
## Validation Steps
# Validate SHANPSHOT_QTY
if ! [[ $SHANPSHOT_QTY =~ ^[0-9]+$ ]]; then
echo "Error: SHANPSHOT_QTY must be a positive integer."
exit 1
fi
# Validate DATASETS
for dataset in "${DATASETS[@]}"; do
if ! zfs list "$dataset" &>/dev/null; then
echo "Error: Dataset '$dataset' does not exist."
exit 1
fi
done
# Function to handle errors
handle_error() {
local error_message="$1"
echo "Error: $error_message"
exit 1
# Function to create snapshot if there is changed data
create_snapshot_if_changed() {
local DATASET="$1"
local WRITTEN
WRITTEN=$(zfs get -H -o value written "${DATASET}")
if [[ "${WRITTEN}" != "0" ]]; then
if ! zfs snapshot "${DATASET}@${SNAPSHOTNAME}"; then
handle_error "Failed to create snapshot for ${DATASET}"
fi
echo "Snapshot created: ${DATASET}@${SNAPSHOTNAME}"
else
echo "No changes detected in ${DATASET}. No snapshot created."
fi
# Function to prune snapshots
prune_snapshots() {
local DATASET="$1"
local KEEP="${SHANPSHOT_QTY}"
# Declare the SNAPSHOTS array
declare -a SNAPSHOTS
# Use mapfile to split the output into the SNAPSHOTS array
if ! mapfile -t SNAPSHOTS < <(zfs list -t snapshot -o name -s creation -r "${DATASET}" | grep "^${DATASET}@"); then
echo "Error: Failed to list snapshots for ${DATASET}"
return 1
fi
local SNAPSHOTS_COUNT=${#SNAPSHOTS[@]}
echo "Total snapshots for ${DATASET}: ${SNAPSHOTS_COUNT}"
local SNAPSHOTS_SPACE
if ! SNAPSHOTS_SPACE=$(zfs get -H -o value usedbysnapshots "${DATASET}"); then
echo "Error: Failed to get space used by snapshots for ${DATASET}"
return 1
fi
echo "Space used by snapshots for ${DATASET}: ${SNAPSHOTS_SPACE}"
if [[ ${SNAPSHOTS_COUNT} -gt ${KEEP} ]]; then
local TO_DELETE=$((SNAPSHOTS_COUNT - KEEP))
for i in "${SNAPSHOTS[@]:0:${TO_DELETE}}"; do
if ! zfs destroy "${i}"; then
echo "Error: Failed to delete snapshot: ${i}"
return 1
fi
echo "Deleted snapshot: ${i}"
done
else
fi
# Iterate over each dataset and call the functions
# create_snapshot_if_changed "${dataset}"
prune_snapshots "${dataset}"
done
echo "----------------------------Done!----------------------------"
