#!/bin/bash
# Description: Backup WordPress or website to S3-Compatible Storage
# Requirements: s3cmd and optional Cloudpanel to use Cloudpanel CLI
# Version: 0.3
# Make executable: chmod +x /home/[website-path]/scripts/backup-s3.sh
# Execute the script: sudo /home/[website-path]/scripts/backup-s3.sh
# Variables
DATABASE=("database-name")
WP_DIR=("/home/[website-path]/htdocs/domain.com")
UPLOADS_DIR=("/home/[website-path]/htdocs/domain.com/wp-content/uploads")
THEMES_DIR=("/home/[website-path]/htdocs/domain.com/wp-content/themes")
PLUGINS_DIR=("/home/[website-path]/htdocs/domain.com/wp-content/plugins")
WPCONTENT_DIR=("/home/[website-path]/htdocs/domain.com/wp-content")
BACKUP_DIR=/home/[website-path]/scripts/backups
SCRIPTS_DIR=/home/[website-path]/scripts
CURRENT_DATE=$(date +"%Y-%m-%d")
# s3cmd Information
S3_CMD="/usr/local/bin/s3cmd"
S3_BUCKET=s3://[bucket-name]/[folder-name]/
# Check for WP directory & wp-config.php
if [ ! -d ${WP_DIR} ]; then
echo "[+] ERROR: Directory ${WP_DIR} does not exist"
echo ""
exit
fi
if [ ! -f ${WP_DIR}/wp-config.php ]; then
echo "[+] ERROR: No wp-config.php in ${WP_DIR}"
echo ""
exit
fi
echo "[+] Success: found wp-config.php in ${WP_DIR}"
# Make a backup directory if it does not already exist, and remove any files from that directory
mkdir -p $BACKUP_DIR
rm -rf "${BACKUP_DIR:?}/*"
echo "[+] Success: created and cleaned ${BACKUP_DIR}"
# Dump database using mysqldump (optional)
# echo "[+] Creating Database dump..."
# mysqldump --defaults-extra-file=${SCRIPTS_DIR}/my.cnf "$DB" | gzip > "$BACKUP_DIR/${DATABASE}.sql.gz"
# echo "[+] Success: database dump ${BACKUP_DIR}/${DATABASE}.sql.gz"
# Dump database using Cloudpanel CLI
# https://www.cloudpanel.io/docs/v2/cloudpanel-cli/root-user-commands/
clpctl db:export --databaseName=${DATABASE} --file=$BACKUP_DIR/${DATABASE}.sql.gz
# Create tar bzip2 of the WordPress installation directory and exclusions
echo "[+] Create tar bzip2 for WP files without the wp-content directory"
tar -cjvf ${BACKUP_DIR}/wp_files.tar.bz2 --exclude='wp-content' ${WP_DIR}
echo "[+] Creating others.tar.bz2"
tar -cjvf ${BACKUP_DIR}/others.tar.bz2 --exclude='themes' --exclude='plugins' --exclude='uploads' --exclude='cache' --exclude='updraft' --exclude='backups-dup-pro' --exclude='backups-dup' --exclude='ai1wm-backups' ${WPCONTENT_DIR}
echo "[+] Creating uploads.tar.bz2"
tar -cjvf ${BACKUP_DIR}/uploads.tar.bz2 ${UPLOADS_DIR}
echo "[+] Creating themes.tar.bz2"
tar -cjvf ${BACKUP_DIR}/themes.tar.bz2 ${THEMES_DIR}
echo "[+] Creating plugins.tar.bz2"
tar -cjvf ${BACKUP_DIR}/plugins.tar.bz2 ${PLUGINS_DIR}
# Rename backup directory
mv ${BACKUP_DIR} ${SCRIPTS_DIR}/${CURRENT_DATE}
# Sent to S3-compatible storage
echo "[+] Uploading backup to S3..."
$S3_CMD sync ${SCRIPTS_DIR}/${CURRENT_DATE} ${S3_BUCKET}
# Remove files from s3 older than xx days using a Lifecycle Policy
# https://www.linode.com/docs/products/storage/object-storage/guides/lifecycle-policies/
# Delete lifecycle policy (un)comment to activate or deactivate
# s3cmd dellifecycle ${S3_BUCKET}
# Upload lifecycle_policy.xml (un)comment to activate or deactivate
# s3cmd setlifecycle ${SCRIPTS_DIR}/lifecycle_policy.xml ${S3_BUCKET}
# Clean up files
echo "[+] Removing local files..."
rm -rf ${SCRIPTS_DIR}/${CURRENT_DATE}
echo "[+] Finish!"
echo ""
# End of the script
exit
