#!/bin/bash
# Description: General Firewall Script for Debian/Ubuntu.
# Details: iptables setup.
# Made for: Linux, Cloudpanel (Debian & Ubuntu).
# Requirements: ssh-keygen - ssh-copy-id root@127.0.0.1 (replace IP)
# Version: 0.1
# Make executable: chmod +x firewall.sh
IPT="/sbin/iptables"
### Interfaces ###
PUB_IF="eth0" # public interface
PRV_IF="eth1" # private interface
LO_IF="lo" # loopback
SERVER_IP=$(ifconfig eth0 | grep 'inet addr:' | awk -F'inet addr:' '{ print $2}' | awk '{ print $1}')
########## Allow/block services #################################################
ALLOW_SSH="true"
ALLOW_HTTP="true"
ALLOW_FTP="false"
ALLOW_STEAM="false"
ALLOW_OUTGOING_DNS="true"
ALLOW_OUTGOING_NTP="true"
ALLOW_OUTGOING_SMTP="true"
ALLOW_OUTGOING_ICMP="true"
ALLOW_INCOMING_ICMP="true"
USE_HARDENING_RULESET="true"
########## SSH #################################################
SSH_PORT=22
# This notes every NEW connection to port ${SSH_PORT} and adds it to the recent "list"
# If your IP is on the recent list, and you have ${SSH_LOGIN_ATTEMPT} or more entries on the list in the
# last ${SSH_LOGIN_ATTEMPT_TIMEFRAME} seconds, we drop your request.
SSH_LOGIN_ATTEMPT_PROTECTION="true"
SSH_LOGIN_ATTEMPT=4
SSH_LOGIN_ATTEMPT_TIMEFRAME_SECONDS=90
SSH_ALLOW_ONLY_IP="false"
SSH_ALLOW_ONLY_IP_LIST="122.xx.yy.zz/29"
#### FILES #####
CUSTOM_RULES=/root/.fw/customRules.sh
BLOCKED_IP_TDB=/root/.fw/blocked.ip.txt
SPOOFIP=""
#SPOOFIP="127.0.0.0/8 192.168.0.0/16 172.16.0.0/12 10.0.0.0/8 169.254.0.0/16 0.0.0.0/8 240.0.0.0/4 255.255.255.255/32 168.254.0.0/16 224.0.0.0/4 240.0.0.0/5 248.0.0.0/5 192.0.2.0/24"
#BADIPS=$( [[ -f ${BLOCKED_IP_TDB} ]] && egrep -v "^#|^$" ${BLOCKED_IP_TDB})
### You shouldn't need to change below this line ###
function allowPort() {
if [[ "$1" == "in" ]]; then
$IPT -A INPUT -i ${PUB_IF} -p $2 --dport $3 -m state --state NEW,ESTABLISHED -j ACCEPT
$IPT -A OUTPUT -o ${PUB_IF} -p $2 --sport $3 -m state --state ESTABLISHED -j ACCEPT
else
$IPT -A OUTPUT -o ${PUB_IF} -p $2 --dport $3 -m state --state NEW,ESTABLISHED -j ACCEPT
$IPT -A INPUT -i ${PUB_IF} -p $2 --sport $3 -m state --state ESTABLISHED -j ACCEPT
fi
function customRules() {
if [ -f ${CUSTOM_RULES} ]; then
source ${CUSTOM_RULES}
fi
function clearAllIpTablesRules() {
echo "Clear all firewall rules";
#Default policy is DROP so first change the INPUT FORWARD and OUTPUT policy before the -F or you will be locked.
iptables -P INPUT ACCEPT
iptables -P FORWARD ACCEPT
iptables -P OUTPUT ACCEPT
iptables -F
iptables -X
iptables -t nat -F
iptables -t nat -X
iptables -t mangle -F
iptables -t mangle -X
function hardeningRules() {
if [ "${USE_HARDENING_RULESET}" == "true" ]; then
echo "Hardening: Drop sync"
$IPT -A INPUT -i ${PUB_IF} -p tcp ! --syn -m state --state NEW -j DROP
echo "Hardening: Drop Fragments"
$IPT -A INPUT -i ${PUB_IF} -f -j DROP
$IPT -A INPUT -i ${PUB_IF} -p tcp --tcp-flags ALL FIN,URG,PSH -j DROP
$IPT -A INPUT -i ${PUB_IF} -p tcp --tcp-flags ALL ALL -j DROP
echo "Hardening: Drop NULL packets"
$IPT -A INPUT -i ${PUB_IF} -p tcp --tcp-flags ALL NONE -m limit --limit 5/m --limit-burst 7 -j LOG --log-prefix " NULL Packets "
$IPT -A INPUT -i ${PUB_IF} -p tcp --tcp-flags ALL NONE -j DROP
$IPT -A INPUT -i ${PUB_IF} -p tcp --tcp-flags SYN,RST SYN,RST -j DROP
echo "Hardening: Drop XMAS"
$IPT -A INPUT -i ${PUB_IF} -p tcp --tcp-flags SYN,FIN SYN,FIN -m limit --limit 5/m --limit-burst 7 -j LOG --log-prefix " XMAS Packets "
$IPT -A INPUT -i ${PUB_IF} -p tcp --tcp-flags SYN,FIN SYN,FIN -j DROP
echo "Hardening: Drop FIN packet scans"
$IPT -A INPUT -i ${PUB_IF} -p tcp --tcp-flags FIN,ACK FIN -m limit --limit 5/m --limit-burst 7 -j LOG --log-prefix " Fin Packets Scan "
$IPT -A INPUT -i ${PUB_IF} -p tcp --tcp-flags FIN,ACK FIN -j DROP
$IPT -A INPUT -i ${PUB_IF} -p tcp --tcp-flags ALL SYN,RST,ACK,FIN,URG -j DROP
echo "Hardening: Log and get rid of broadcast / multicast and invalid"
$IPT -A INPUT -i ${PUB_IF} -m pkttype --pkt-type broadcast -j LOG --log-prefix " Broadcast "
$IPT -A INPUT -i ${PUB_IF} -m pkttype --pkt-type broadcast -j DROP
$IPT -A INPUT -i ${PUB_IF} -m pkttype --pkt-type multicast -j LOG --log-prefix " Multicast "
$IPT -A INPUT -i ${PUB_IF} -m pkttype --pkt-type multicast -j DROP
$IPT -A INPUT -i ${PUB_IF} -m state --state INVALID -j LOG --log-prefix " Invalid "
$IPT -A INPUT -i ${PUB_IF} -m state --state INVALID -j DROP
fi
function logAndBlockSpoofedIPRules() {
$IPT -N spooflist
for ipblock in $SPOOFIP
do
$IPT -A spooflist -i ${PUB_IF} -s $ipblock -j LOG --log-prefix " SPOOF List Block "
$IPT -A spooflist -i ${PUB_IF} -s $ipblock -j DROP
done
$IPT -I INPUT -j spooflist
$IPT -I OUTPUT -j spooflist
$IPT -I FORWARD -j spooflist
function sshRules() {
if [ "${ALLOW_SSH}" == "true" ]; then
echo "Allow SSH";
if [ "${SSH_ALLOW_ONLY_IP}" == "true" ]; then
# Allow ssh only from selected public ips
for ip in ${SSH_ALLOW_ONLY_IP_LIST}
do
$IPT -A INPUT -i ${PUB_IF} -s ${ip} -p tcp -d ${SERVER_IP} --dport ${SSH_PORT} -j ACCEPT
$IPT -A OUTPUT -o ${PUB_IF} -d ${ip} -p tcp -s ${SERVER_IP} --sport ${SSH_PORT} -j ACCEPT
done
else
# allow for all
$IPT -A INPUT -i ${PUB_IF} -p tcp -d ${SERVER_IP} --dport ${SSH_PORT} -j ACCEPT
$IPT -A OUTPUT -o ${PUB_IF} -p tcp -s ${SERVER_IP} --sport ${SSH_PORT} -j ACCEPT
# allow for all (outbound)
$IPT -A OUTPUT -o ${PUB_IF} -p tcp -s ${SERVER_IP} --dport ${SSH_PORT} -j ACCEPT
$IPT -A INPUT -i ${PUB_IF} -p tcp -d ${SERVER_IP} --sport ${SSH_PORT} -j ACCEPT
fi
if [ "${SSH_LOGIN_ATTEMPT_PROTECTION}" == "true" ]; then
$IPT -I INPUT -p tcp --dport ${SSH_PORT} -i eth0 -m state --state NEW -m recent --set
$IPT -I INPUT -p tcp --dport ${SSH_PORT} -i eth0 -m state --state NEW -m recent --update --seconds ${SSH_LOGIN_ATTEMPT_TIMEFRAME_SECONDS} --hitcount ${SSH_LOGIN_ATTEMPT} -j DROP
fi
fi
function icmpRules() {
if [ "${ALLOW_INCOMING_ICMP}" == "true" ]; then
echo "Allow incoming ICMP";
$IPT -A INPUT -i ${PUB_IF} -p icmp --icmp-type 8 -s 0/0 -m state --state NEW,ESTABLISHED,RELATED -m limit --limit 30/sec -j ACCEPT
$IPT -A OUTPUT -o ${PUB_IF} -p icmp --icmp-type 0 -d 0/0 -m state --state ESTABLISHED,RELATED -j ACCEPT
fi
if [ "${ALLOW_OUTGOING_ICMP}" == "true" ]; then
echo "Allow outgoing ICMP";
$IPT -A OUTPUT -o ${PUB_IF} -p icmp --icmp-type echo-request -j ACCEPT
$IPT -A INPUT -i ${PUB_IF} -p icmp --icmp-type echo-reply -j ACCEPT
fi
function httpRules() {
if [ "${ALLOW_HTTP}" == "true" ]; then
echo "Allow HTTP";
#allow http(s) inbound connection/response
$IPT -A INPUT -i ${PUB_IF} -p tcp -m multiport --dports 80,443 -m state --state NEW,ESTABLISHED -j ACCEPT
$IPT -A OUTPUT -o ${PUB_IF} -p tcp -m multiport --sports 80,443 -m state --state ESTABLISHED -j ACCEPT
#allow http(s) outbound connection/response
$IPT -A OUTPUT -o ${PUB_IF} -p tcp -m multiport --dports 80,443 -m state --state NEW,ESTABLISHED -j ACCEPT
$IPT -A INPUT -i ${PUB_IF} -p tcp -m multiport --sports 80,443 -m state --state ESTABLISHED -j ACCEPT
fi
function dnsRules() {
if [ "${ALLOW_OUTGOING_DNS}" == "true" ]; then
echo "Allow outgoing DNS";
allowPort out udp 53
fi
function ntpRules() {
if [ "${ALLOW_OUTGOING_NTP}" == "true" ]; then
echo "Allow outgoing NTP";
allowPort out udp 123
fi
function smtpRules() {
if [ "${ALLOW_OUTGOING_SMTP}" == "true" ]; then
echo "Allow outgoing SMTP";
allowPort out tcp 25
fi
function ftpRules() {
if [ "${ALLOW_FTP}" == "true" ]; then
echo "Allow FTP";
$IPT -A INPUT -p tcp --dport ftp -i ${PUB_IF} -j ACCEPT
$IPT -A INPUT -p udp --dport ftp -i ${PUB_IF} -j ACCEPT
$IPT -A INPUT -p tcp --dport ftp-data -i ${PUB_IF} -j ACCEPT
$IPT -A INPUT -p udp --dport ftp-data -i ${PUB_IF} -j ACCEPT
fi
function steamRules() {
if [ "${ALLOW_STEAM}" == "true" ]; then
echo "Allow Steam";
allowPort in udp "27000:27030"
allowPort out udp "27000:27030"
allowPort in tcp "27014:27050"
allowPort out tcp "27014:27050"
allowPort in udp "4379:4380"
allowPort out udp "4379:4380"
fi
function dropAndCloseEverythingRules() {
echo "Drop And Close Everything";
$IPT -P INPUT DROP
$IPT -P OUTPUT DROP
$IPT -P FORWARD DROP
function dropAndLogEverythingElseRules() {
$IPT -A INPUT -m limit --limit 5/m --limit-burst 7 -j LOG --log-prefix " DEFAULT DROP "
$IPT -A INPUT -j DROP
function unlimitedLoopbackRules() {
$IPT -A INPUT -i ${LO_IF} -j ACCEPT
$IPT -A OUTPUT -o ${LO_IF} -j ACCEPT
function unlimitedPrivateRules() {
$IPT -A INPUT -i ${PRV_IF} -j ACCEPT
$IPT -A OUTPUT -o ${PRV_IF} -j ACCEPT
function createIptablesRules() {
echo "Setting $(hostname) Firewall...";
hardeningRules
sshRules
httpRules
icmpRules
dnsRules
ntpRules
smtpRules
ftpRules
steamRules
customRules
echo " Choose one of the following options:"
echo
echo "[N]ew firewall rules"
echo "[C]lear all firewall rules"
echo "[T]est firewall rules"
echo "[S]ave firewall rules to /etc/network/iptables"
echo "[E]xit"
echo
read choice
case "$choice" in
"N" | "n" )
createIptablesRules
"C" | "c" )
"T" | "t" )
createIptablesRules
iptables-apply
"S" | "s" )
createIptablesRules
iptables-save > /etc/network/iptables
exit 0
esac
Comments and Updates are welcomed
