***Script***Cleanup a Tailscale installation on MacOS
#!/bin/bash
# If you're having issues with Tailscale after a reinstall, try cleaning up.
# Tailscale recommends the following. I've just scripted it for ease:
# https://tailscale.com/kb/1069/uninstall?q=uninstall&tab=macos+%28standalone%29
# Oh would you look at that, if you've got brew, just use that.
# https://github.com/Homebrew/homebrew-cask/blob/master/Casks/t/tailscale.rb
# NOTE:
# I made this because I was having major authentication issues and I got tired of tidying up for my reinstalls.
# Turns out the issue was that my corporate network suddenly started causing issues.
# Moral of the story... Issues? Try a hotspot before anything else.
# Delete paths
paths=(
    "~/Library/Application Scripts/*.io.tailscale.ipn.macos"
    "~/Library/Application Scripts/io.tailscale.ipn.macos"
    "~/Library/Application Scripts/io.tailscale.ipn.macos.login-item-helper"
    "~/Library/Application Scripts/io.tailscale.ipn.macos.share-extension"
    "~/Library/Caches/io.tailscale.ipn.macos"
    "~/Library/Containers/io.tailscale.ipn.macos"
    "~/Library/Containers/io.tailscale.ipn.macos.login-item-helper"
    "~/Library/Containers/io.tailscale.ipn.macos.network-extension"
    "~/Library/Containers/io.tailscale.ipn.macos.share-extension"
    "~/Library/Containers/Tailscale"
    "~/Library/Group Containers/*.io.tailscale.ipn.macos"
    "~/Library/HTTPStorages/io.tailscale.ipn.macos"
    "~/Library/Preferences/io.tailscale.ipn.macos.plist"
    "~/Library/Tailscale"
for path in "${paths[@]}"; do
    expanded_path=$(eval echo "$path")
    if [ -e "$expanded_path" ]; then
        rm -rf "$expanded_path"
        echo "Deleted: $expanded_path"
    else
        echo "Not found: $expanded_path"
    fi
done
# Remove login keychain items that start with "tailscale"
sudo security dump-keychain | grep -i "tailscale" | cut -d'"' -f4 | while read -r keychain_item; do
    sudo security delete-generic-password -l "$keychain_item"
    echo "Removed keychain item: $keychain_item"
done
# Remove Tailscale from VPN configuration
if [ -e /Library/Preferences/SystemConfiguration/preferences.plist ]; then
    sudo /usr/libexec/PlistBuddy -c "Delete :NetworkServices:*:UserDefinedName:Tailscale" /Library/Preferences/SystemConfiguration/preferences.plist 2>/dev/null
    sudo /usr/libexec/PlistBuddy -c "Delete :NetworkServices:*:Interface:SubType:Tailscale" /Library/Preferences/SystemConfiguration/preferences.plist 2>/dev/null
    echo "Removed Tailscale from VPN configuration"
else
    echo "VPN configuration file not found"
fi
# Restart the network service to apply changes
sudo killall -HUP mDNSResponder
echo "Network service restarted"
