Nginx setup, commands and way around
install from source code
building nginx server the source is the ablity to add custom module,or essentially extend the standard nginx functionality.
required libraries:
$ sudo apt install libpcre3 libpcre3-dev zlib1g zlib1g-dev libssl-dev
buid it:
# ./configure --sbin-path=/usr/bin/nginx --conf-path=/etc/nginx/nginx.conf \
--error-log-path=/var/log/nginx/err.log --http-log-path=/var/log/nginx/access.log \
--with-pcre --pid-path=/var/run/nginx.pid --with-http_ssl_module
compile code
# make
install
# make install
adding systemd
# systemctl daemon-reload
and now start the nginx
# systemctl start nginx
startup on boot:
systemctl enable nginx
Location
prefix match
location /greet {
return 200 'Hello from NGINX';
Exact Match
location = /greet {
return 200 "Hello from NGINX exact match";
Regex Match, tilde sign
location ~ /greet[0-9] {
return 200 "Hello from NGINX location - REGEX Match";
More additions will follow in the same thread… http/3 and
insensitive case matching
location ~* /greet[0-9] {
return 200 "Hello from NGINX - REGEX Match";
Preferential prefix match
location ^~ /Greet2 {
if condition
# check static API key
if ( $arg_apikey != 1234 ) {
return 401 "Incorrect API key";
variables
location /inspect {
return 200 "$host\n$uri\n$args";
location /inspect {
return 200 "Name: $arg_name";
logic
set $weekend 'No';
# check if weekend
if ( $date_local ~ 'Wednesday|Thursday' ) {
set $weekend 'Yes';
location /is_weekend {
return 200 $weekend;
Redirect
Temperary redirct
location /logo {
return 307 /images/demo/960x360.gif;
Rewrite
# need more system resources than return
rewrite ^/user/\w+ /greet;
location /greet {
return 200 "Hello rewrite user";
capita group
rewrite ^/user/(\w+) /greet/$1;
location = /greet/john {
return 200 "Hello john";
last match, no need to evaluate more uri
rewrite ^/user/(\w+) /greet/$1 last;
rewrite ^/greet/john /logo;
if the first file exists, so serve it otherwise serve the next one
try_files /images/demo/960x360.gif /john;
# using with variable
try_files $uri /images/demo/960x360.gif /john;
404
try_files $uri /logo.png /greet /404;
location /404 {
return 404 "The file couldn't be found!";
keeping name
try_files $uri /logo.png /greet @404;
location @404 {
custom loggin files
location /secure {
access_log /var/log/nginx/secure.access.log;
access_log /var/log/nginx/access.log;
return 200 "Welcome to secure area."
blocking log for certain requrest
location /secure {
access_log off;
return 200 "Welcome to secure area.";
Configure PHP
installing PHP-FPM to configure with nginx
$ sudo apt install php-fpm
load the index file once the request has been made to our domain
server {
listen 80;
server_name 100.26.249.49;
root /site/demo;
index index.php index.html;
full demo with fastCGI, and permission denied(solved)
user www-data;
events{}
http {
include mime.types;
index index.html;
server {
listen 80;
root /site/demo/basic-89;
location / {
try_files $uri $uri/ =404;
location ~\.php$ {
#Pass php request to php-fpm service (fastcgi)
include fastcgi.conf;
fastcgi_pass unix:/run/php/php7.2-fpm.sock;
increasing the number of worker processes
user www-data;
worker_processes 2;
events{}
# check now
systemctl status nginx
checking cpu on server there’s two command, nproc and lscpu in *nix system.
(auto) for numbers of cpus you want to have worker, keep it auto instead
worker_processes auto;
checking limit of concurrent request ulimit -n.
keeping max concurrent request in nginx
event {
worker_connections <ulimit -n number here> 1024;
changin pid without rebuilding nginx server again
pid /var/run/new_nginx.pid;
event{}
Header
add header, the css,js,png and jpg will be cached for 1month in the user machine
location ~* \.(css|js|jpg|png)$ {
access_log off;
add_header Cache-Control public;
add_header Pragma public;
add_header Vary Accept-Encoding;
expires 1M;
Gzip
compressing request using gzip
http {
gzip on;
gzip_comp_level 3;
gzip_types text/css;
gzip_types text/javascript;
HTTP 2.0
adding http 2, also need ssl certificate
# openssl req -x509 -days 10 -nodes -newkey rsa:2048 -keyout /etc/nginx/ssl/self.key -out /etc/nginx/ssl/self.crt
rebuild the nginx server with flag --with-http_v2_module
nginx.conf
server {
listen 443 ssl http2;
ssl_certificate /etc/nginx/ssl/self.crt;
ssl_certificate_key /etc/nginx/ssl.key;
TSL
generate dhparam openssl dhparam -out /etc/nginx/ssl/dhparam.pem 2048
server {
# Disable SSL
ssl_protocols TLSv1 TLSv1.1 TLSv1.2;
# Optimise cipher suits
ssl_prefer_server_ciphers on;
ssl_ciphers ECDH+AESGCM:ECDH+AES256:ECDH+AES128:DH+3DES:!ADH:!AECDH:!MD5;
# Enable DH Params
ssl_dhparam /etc/nginx/ssl/dhparam.pem;
# Enabl HSTS for a year
add_header Strict-Transport-Security "max-age=31536000" always;
# SSL sessions
ssl_session_cache shared:SSL:40m;
ssl_session_timeout 4h;
ssl_session_tickets on;
http to https redirection
when accessing http://example.com you might get error, to avoid the error redirect to https://example.com
http {
# redirect all traffic to HTTPS
server {
listen 80;
server_name 127.0.0.1/www.example.com;
return 301 https://$host$request_uri;
server {
# all your configuration code goes here..
Rate Limiting
first you need to install siege in your distro: sudo apt install siege.
checking siege working siege -v -r 2 -c 5 url
include mime.types;
# right down the min.types;
# Define Limit zone
# 60 request / 1min
# to MyZONE
limit_req_zone $request_uri zone=MYZONE:10m rate=60r/m;
server {
# all code here
location / {
limit_req zone=MYZONE;
adding burst to specific location. burst mean keeping the request in promsie (for grasping like js).
location / {
limit_req zone=MYZONE burst=5;
nodelay Learn more about nodelay
limit_req zone=MYZONE burst=5 nodelay;
Admin Area ( Basic Auth )
first you need to install apt install apache2-utils
second generate .htpasswd file htpasswd -c /etc/nginx/.htpasswd user1
location / {
auth_basic "Secure Area";
auth_basic_user_file /etc/nginx/.htpasswd;
# .. codes...
Server Push
receiving multiple request at same moment ( by one request in http 2.0)
location = /index.html {
# all the files need to be available for client side
http2_push /style.css
htt2_push /logo.png
Example
location @404 {
location /greet {
# Temperary redirct
location /logo {
# create var
set $weekend 'No';
# check if weekend
set $weekend 'Yes';
location /inspect {
# prefix match
location /Greet2 {
# Exact
location = /greet {
# Preferential prefix match
