Quick question about wildcard certs
Hey all, when I setup Pangolin I was unsure if I should put the prefer_wildcard_cert: true in this location or the flag location. Thanks in advance.
domains:
    domain1:
        base_domain: "xxxx.duckdns.org"
        cert_resolver: "letsencrypt"
or,
flags:
    require_email_verification: false
    disable_signup_without_invite: true
    disable_user_create_org: false
    allow_raw_resources: true
    #prefer_wildcard_cert: true
flags:
this is the correct one. the one you have used is an old flag for previous versions
This topic has had no activity for 30 days. It will close in 7 days unless someone replies.
  • Still broken? Reply with your current versions and logs, and it stays open.
  • Fixed it? Post what worked and mark it as the solution, so the next person finds it.
