**Question** I want to understand how a PM2 deployment will differ from a K8s deployment
I want to understand how a PM2 deployment will differ from a K8s deployment. I mean with PM2 deployment I would be able to spawn multiple number of processes to utilize all the cores on my server. And with K8s I will basically be giving a single core to every container… ?
Let me help you understand the key differences between PM2 and Kubernetes (K8s) deployments, particularly regarding process/resource management.
Your understanding has a slight misconception that I’ll clarify:
  1. PM2 (Process Management):
  • PM2 is a process manager that runs on a single machine/server
  • It can indeed spawn multiple Node.js processes using its cluster mode
  • When you use pm2 start app.js -i max, it creates worker processes based on available CPU cores
  • All processes share the same host’s resources (memory, disk, network)
  • Good for vertical scaling on a single machine
  1. Kubernetes (K8s):
  • This is actually a misconception: K8s containers are NOT limited to single cores by default
  • Containers can utilize multiple CPU cores unless explicitly restricted
  • You can configure resource requests and limits:
    resources:
      requests:
        cpu: "1"    # Guaranteed minimum of 1 CPU core
        memory: "1Gi"
      limits:
        cpu: "2"    # Can use up to 2 CPU cores
        memory: "2Gi"
  • K8s provides container orchestration across multiple machines
  • Better for horizontal scaling across multiple nodes
Key Differences:
  1. Scope:
    • PM2: Single server process management
    • K8s: Multi-node container orchestration
  2. Scalability:
    • PM2: Vertical scaling (up on single machine)
    • K8s: Both vertical and horizontal scaling (across machines)
  3. Resource Management:
    • PM2: Shares host resources between processes
    • K8s: Can precisely control resource allocation per container
  4. Use Cases:
    • PM2: Simpler deployments, single-server applications
    • K8s: Complex distributed systems, microservices architectures
