PYTHON — Building a Django App with Gunicorn, Nginx, and Python in Cloudpanel
Django Deployment Guide for CloudPanel with Gunicorn
Django Application Deployment Guide for CloudPanel
  • CloudPanel installation
  • SSH access to your VPS
  • Domain name
  • Django application codebase
  • Install dependencies from root
# Install required system packages for MySQL client
sudo apt-get update
sudo apt-get install python3-dev default-libmysqlclient-dev build-essential pkg-config
sudo apt-get install python3-mysqldb
1. Initial Site Configuration
1.1 Site Creation
  1. Navigate to CloudPanel dashboard
  2. Select “Add Site” → “Create a Python Site”
  3. Configure domain settings (system will auto-populate additional fields)
1.2 SSL Configuration
2. Application Deployment
2.1 File Transfer
Transfer application files via either:
  • SFTP (FileZilla)
  • CloudPanel File Manager
Note: Exclude virtual environment directories (env/venv)
2.2 Environment Setup
# Navigate to user's home directory
cd /home/hhf-test
# Create and activate virtual environment
python3 -m venv venv
source venv/bin/activate
# Create Django project in the htdocs directory
cd htdocs/test.hhf.technology
# Install required packages
pip install django gunicorn mysqlclient python-dotenv
django-admin startproject config .
2.3 Django Configuration
Create .env file in /home/hhf-test/htdocs/test.hhf.technology:
before that dont forget to create database in clp UI
DEBUG=False
ALLOWED_HOSTS=test.hhf.technology
DB_NAME=your_database_name
DB_USER=your_database_user
DB_PASSWORD=your_database_password
DB_HOST=localhost
DB_PORT=3306
Update config/settings.py:
Django settings for config project.
Generated by 'django-admin startproject' using Django 5.1.3.
For more information on this file, see
https://docs.djangoproject.com/en/5.1/topics/settings/
For the full list of settings and their values, see
https://docs.djangoproject.com/en/5.1/ref/settings/
from pathlib import Path
import os
from dotenv import load_dotenv
load_dotenv()
# Build paths inside the project like this: BASE_DIR / 'subdir'.
BASE_DIR = Path(__file__).resolve().parent.parent
# Quick-start development settings - unsuitable for production
# See https://docs.djangoproject.com/en/5.1/howto/deployment/checklist/
# SECURITY WARNING: keep the secret key used in production secret!
SECRET_KEY = 'django-insecure--xka)7x4-4o32hglmqkssz4(c=4fwv2ka)msy17!)=z@%8ol2k'
# SECURITY WARNING: don't run with debug turned on in production!
DEBUG = True
ALLOWED_HOSTS = os.getenv('ALLOWED_HOSTS').split(',')
# Application definition
INSTALLED_APPS = [
    'django.contrib.admin',
    'django.contrib.auth',
    'django.contrib.contenttypes',
    'django.contrib.sessions',
    'django.contrib.messages',
    'django.contrib.staticfiles',
MIDDLEWARE = [
    'django.middleware.security.SecurityMiddleware',
    'django.contrib.sessions.middleware.SessionMiddleware',
    'django.middleware.common.CommonMiddleware',
    'django.middleware.csrf.CsrfViewMiddleware',
    'django.contrib.auth.middleware.AuthenticationMiddleware',
    'django.contrib.messages.middleware.MessageMiddleware',
    'django.middleware.clickjacking.XFrameOptionsMiddleware',
ROOT_URLCONF = 'config.urls'
TEMPLATES = [
        'BACKEND': 'django.template.backends.django.DjangoTemplates',
        'DIRS': [],
        'APP_DIRS': True,
        'OPTIONS': {
            'context_processors': [
                'django.template.context_processors.debug',
                'django.template.context_processors.request',
                'django.contrib.auth.context_processors.auth',
                'django.contrib.messages.context_processors.messages',
WSGI_APPLICATION = 'config.wsgi.application'
# Database
# https://docs.djangoproject.com/en/5.1/ref/settings/#databases
DATABASES = {
    'default': {
        'ENGINE': 'django.db.backends.mysql',
        'NAME': os.getenv('DB_NAME'),
        'USER': os.getenv('DB_USER'),
        'PASSWORD': os.getenv('DB_PASSWORD'),
        'HOST': os.getenv('DB_HOST'),
        'PORT': os.getenv('DB_PORT'),
# Password validation
# https://docs.djangoproject.com/en/5.1/ref/settings/#auth-password-validators
AUTH_PASSWORD_VALIDATORS = [
        'NAME': 'django.contrib.auth.password_validation.UserAttributeSimilarityValidator',
        'NAME': 'django.contrib.auth.password_validation.MinimumLengthValidator',
        'NAME': 'django.contrib.auth.password_validation.CommonPasswordValidator',
        'NAME': 'django.contrib.auth.password_validation.NumericPasswordValidator',
# Internationalization
# https://docs.djangoproject.com/en/5.1/topics/i18n/
LANGUAGE_CODE = 'en-us'
TIME_ZONE = 'UTC'
USE_I18N = True
USE_TZ = True
# Static files (CSS, JavaScript, Images)
# https://docs.djangoproject.com/en/5.1/howto/static-files/
STATIC_URL = 'static/'
STATIC_ROOT = BASE_DIR / 'static'
MEDIA_URL = 'media/'
MEDIA_ROOT = BASE_DIR / 'media'
# Default primary key field type
# https://docs.djangoproject.com/en/5.1/ref/settings/#default-auto-field
DEFAULT_AUTO_FIELD = 'django.db.models.BigAutoField'
2.4 Django Configuration
# Database migrations
python3 manage.py makemigrations
python3 manage.py migrate
# Static files collection
python3 manage.py collectstatic
3. Gunicorn Configuration
Create /home/hhf-test/htdocs/test.hhf.technology/gunicorn_config.py:
bind = "unix:/home/hhf-test/htdocs/test.hhf.technology/gunicorn.sock"
workers = 3
timeout = 120
errorlog = "/home/hhf-test/logs/gunicorn_error.log"
accesslog = "/home/hhf-test/logs/gunicorn_access.log"
capture_output = True
4. Systemd Service Setup
Create /etc/systemd/system/django-hhf.service:
[Unit]
Description=Gunicorn daemon for Django Project
After=network.target
[Service]
User=hhf-test
Group=hhf-test
WorkingDirectory=/home/hhf-test/htdocs/test.hhf.technology
ExecStart=/home/hhf-test/venv/bin/gunicorn \
--config /home/hhf-test/htdocs/test.hhf.technology/gunicorn_config.py \
config.wsgi:application
[Install]
WantedBy=multi-user.target
5. Nginx Configuration (in CloudPanel)
Add this configuration to your domain’s nginx config:
  location / {
    proxy_pass http://unix:/home/hhf-test/htdocs/test.hhf.technology/gunicorn.sock;
    proxy_http_version 1.1;
    proxy_set_header X-Forwarded-Host $host;
    proxy_set_header X-Forwarded-Server $host;
    proxy_set_header Host $host;
    proxy_set_header Connection "Upgrade";
    proxy_pass_request_headers on;
    proxy_max_temp_file_size 0;
    proxy_connect_timeout 900;
    proxy_send_timeout 900;
    proxy_read_timeout 900;
    proxy_buffer_size 128k;
    proxy_buffers 4 256k;
    proxy_busy_buffers_size 256k;
    proxy_temp_file_write_size 256k;
  location /static/ {
    alias /home/hhf-test/htdocs/test.hhf.technology/static/;
  location /media/ {
    alias /home/hhf-test/htdocs/test.hhf.technology/media/;
  location ~* ^.+\.(css|js|jpg|jpeg|gif|png|ico|gz|svg|svgz|ttf|otf|woff|woff2|eot|mp4|ogg|ogv|webm|webp|zip|swf)$ {
    add_header Access-Control-Allow-Origin "*";
    add_header alt-svc 'h3=":443"; ma=86400';
    expires max;
    access_log on;
  if (-f $request_filename) {
    break;
6. Final Setup Commands
# Collect static files
python manage.py collectstatic
# Apply migrations
python manage.py migrate
# Set proper permissions
chmod 755 /home/hhf-test/htdocs/test.hhf.technology
chown -R hhf-test:hhf-test /home/hhf-test/htdocs/test.hhf.technology
# Start and enable the service
sudo systemctl start django-hhf
sudo systemctl enable django-hhf
# Check status
sudo systemctl status django-hhf
Create New username password
python manage.py createsuperuser
7. Directory Permissions
Ensure these directories exist with proper permissions:
mkdir -p /home/hhf-test/logs
mkdir -p /home/hhf-test/htdocs/test.hhf.technology/static
mkdir -p /home/hhf-test/htdocs/test.hhf.technology/media
chown -R hhf-test:hhf-test /home/hhf-test/logs
chmod -R 755 /home/hhf-test/logs
Here’s the standard content of a Django manage.py file:
#!/usr/bin/env python
"""Django's command-line utility for administrative tasks."""
import os
import sys
def main():
    """Run administrative tasks."""
    os.environ.setdefault('DJANGO_SETTINGS_MODULE', 'config.settings')
    try:
        from django.core.management import execute_from_command_line
    except ImportError as exc:
        raise ImportError(
            "Couldn't import Django. Are you sure it's installed and "
            "available on your PYTHONPATH environment variable? Did you "
            "forget to activate a virtual environment?"
        ) from exc
    execute_from_command_line(sys.argv)
if __name__ == '__main__':
    main()
A few key points about this file:
  1. The file should be placed in your project’s root directory: /home/hhf-test/htdocs/test.hhf.technology/manage.py
  2. Make sure the file has executable permissions:
chmod +x manage.py
  1. The important line is:
This line tells Django where to find your settings file. In your case, it should point to config.settings since we created the project with the name ‘config’.
  1. Make sure your project structure looks like this:
├── manage.py
├── config/
│   ├── __init__.py
│   ├── settings.py
│   ├── urls.py
│   └── wsgi.py
You can verify the structure with:
tree /home/hhf-test/htdocs/test.hhf.technology
Let me know if you need help with any other files or configurations!
(venv) hhf-test@homelab:~/htdocs/test.hhf.technology$ python manage.py collectstatic
Traceback (most recent call last):
  File "/home/hhf-test/htdocs/test.hhf.technology/manage.py", line 11, in main
ModuleNotFoundError: No module named 'django'
The above exception was the direct cause of the following exception:
  File "/home/hhf-test/htdocs/test.hhf.technology/manage.py", line 22, in <module>
    main()
  File "/home/hhf-test/htdocs/test.hhf.technology/manage.py", line 13, in main
    raise ImportError(
ImportError: Couldn't import Django. Are you sure it's installed and available on your PYTHONPATH environment variable? Did you forget to activate a virtual environment?
Let’s fix this step by step. First, let’s verify and recreate the virtual environment and installation:
# 1. First, let's see what version of Python you have
python3 --version
# 2. Remove the old virtual environment
cd /home/hhf-test
rm -rf venv
# 3. Create a new virtual environment with the specific Python version
# 4. Activate the virtual environment
# 5. Verify you're in the virtual environment
which python
# Should show: /home/hhf-test/venv/bin/python
# 6. Upgrade pip
python -m pip install --upgrade pip
# 7. Install Django with verbose output to see any potential issues
pip install django -v
# 8. Verify Django is installed
pip list | grep Django
# 9. Try to import Django in Python to verify it's accessible
python -c "import django; print(django.__version__)"
# 10. Navigate to your project directory
cd /home/hhf-test/htdocs/test.hhf.technology
# 11. Now try collectstatic again
If you’re still getting the error, let’s check your Python paths:
# Check Python path
python -c "import sys; print(sys.path)"
Also, let’s verify the project structure:
# Show the project structure
ls -la /home/hhf-test/htdocs/test.hhf.technology
If the issue persists, try explicitly setting the PYTHONPATH:
export PYTHONPATH="/home/hhf-test/venv/lib/python3.x/site-packages:$PYTHONPATH"
# Replace 'python3.x' with your Python version (e.g., python3.8, python3.9, etc.)
You can also try installing Django with pip3 explicitly:
pip3 install django
Finally, if none of the above works, we can try an alternative approach:
# 1. Create requirements.txt
echo "Django>=4.2
gunicorn
python-dotenv
pymysql" > requirements.txt
# 2. Install all requirements
pip install -r requirements.txt
# 3. Verify installation
pip freeze
Please run these commands and let me know:
  1. What is the output of python --version?
  2. What is the output of pip list | grep Django?
  3. What is the output of which python when your virtualenv is activated?
  4. What files do you see when you run ls -la in your project directory?
This information will help us pinpoint the exact issue.
Celery with Django in production
First go to your respective dir with the site user not root.
cd /home/test-hhf/
cd /home/test-hhf/htdocs/test.hhf.technology
pip install -U Celery
1. Create a systemd service file for Celery
sudo nano /etc/systemd/system/celery.service
[Unit]
Description=Celery Service
[Service]
Type=forking
User=www-data
Group=www-data
WorkingDirectory=/home/test-hhf/htdocs/test.hhf.technology
Environment=DJANGO_SETTINGS_MODULE=your_project.settings
EnvironmentFile=/etc/conf.d/celery
ExecStart=/bin/sh -c '${CELERY_BIN} -A ${CELERY_APP} multi start ${CELERY_NODES} \
--pidfile=${CELERY_PID_FILE} \
--logfile=${CELERY_LOG_FILE} \
--loglevel=${CELERY_LOG_LEVEL}'
ExecStop=/bin/sh -c '${CELERY_BIN} multi stopwait ${CELERY_NODES} \
--pidfile=${CELERY_PID_FILE}'
ExecReload=/bin/sh -c '${CELERY_BIN} -A ${CELERY_APP} multi restart ${CELERY_NODES} \
[Install]
2. Create the configuration file
sudo mkdir /etc/conf.d
sudo nano /etc/conf.d/celery
# Names of nodes to start
CELERY_NODES="worker1"
# Path to celery binary
CELERY_BIN="/home/test-hhf/htdocs/test.hhf.technology/venv/bin/celery"
# App instance to use
CELERY_APP="your_project"
# Where to store process ids
CELERY_PID_FILE="/var/run/celery/%n.pid"
# Log file
CELERY_LOG_FILE="/var/log/celery/%n%I.log"
# Log level
CELERY_LOG_LEVEL="INFO"
3. Create required directories
sudo mkdir /var/log/celery
sudo mkdir /var/run/celery
sudo chown -R test-hhf:test-hhf /var/log/celery
sudo chown -R test-hhf:test-hhf /var/run/celery
4. Enable and start the service
sudo systemctl daemon-reload
sudo systemctl enable celery
sudo systemctl start celery
5. Check status
sudo systemctl status celery
