Proxmox LXC Docker Backup and Restore
Proxmox Docker Volume Backup and Restore Script
This script facilitates the backup and restoration of Docker volumes within Proxmox LXC containers.
Requirements
  • Ensure sshpass is installed. For installation guidance, refer to Cyberciti: SSH Password Provider.
  • Enable root login with a password on the Proxmox host by following these steps:
    1. Modify the /etc/ssh/sshd_config file with the following settings:
      • ListenAddress 0.0.0.0
      • PasswordAuthentication yes
      • PermitRootLogin yes
    2. Restart the SSH service using:
      systemctl restart sshd
To execute backup and restore operations, use the following commands:
  • Backup a volume:
    ./proxmox.sh backup --host <host> --user <user> --lxc <lxc_number> --volume <volume> --path <path>
  • Restore a volume:
    ./proxmox.sh restore --host <host> --user <user> --lxc <lxc_number> --volume <volume> --path <path>
Parameters
  • host: IP address or hostname of the Proxmox host
  • user: Username for the Proxmox host
  • lxc: LXC container number
  • volume: Name of the Docker volume
  • path: Backup location path
Examples
  • Backing up a volume:
    ./proxmox.sh backup --host 192.168.0.100 --user root --lxc 100 --volume searxng_data --path /Users/husni/backup
    The backup file will be saved at /Users/husni/backup/searxng_data-backup.tar.gz.
  • Restoring a volume:
    ./proxmox.sh restore --host 192.168.0.100 --user root --lxc 100 --volume searxng_data --path /Users/husni/backup
    The backup file will be restored from /Users/husni/backup/searxng_data-backup.tar.gz. Ensure that this file exists, as this action will overwrite any existing files in the Docker volume.
Disclaimer
This script is designed for advanced users. Ensure you fully understand the consequences of backing up and restoring Docker volumes in your environment before proceeding with its use.
Ref:
[1] How can I backup a Docker-container with its data-volumes? - Stack Overflow
[2] Question about backing up docker and restoring tests? - General - Docker Community Forums
[3] CT: how to backup only root volume but... | Proxmox Support Forum
[4] Restore for backup, bare minimum - General - Docker Community Forums
[5] Restoring using proxmox-backup-client within a docker image | Proxmox Support Forum
[6] Nginx Proxy Manager Restore Backup from Docker · tteck/Proxmox · Discussion #2451 · GitHub
[7] Reddit - The heart of the internet
[8] Best practize full backup and restore ( image + volumes + config ) - General - Docker Community Forums
#!/bin/bash
set -e
#!/bin/bash
# Description:        Proxmox LXC Docker Backup and Restore.
# Details:            Proxmox LXC Docker Backup and Restore.
# Made for:           Linux, Proxmox (Debian).
# Requirements:       ssh-keygen - ssh-copy-id root@127.0.0.1 (replace IP)
# Version:            0.1
# Make executable:    chmod +x fproxmox.sh
# This script performs backup and restore operations for Docker volumes within Proxmox LXC containers.
# Requirements:
# - Ensure that `sshpass` is installed. For installation instructions, visit: https://www.cyberciti.biz/faq/noninteractive-shell-script-ssh-password-provider/
# - Root login with a password must be enabled on the Proxmox host. Follow these steps:
#   1. Edit the `/etc/ssh/sshd_config` file and apply the following configuration settings:
#       - ListenAddress 0.0.0.0
#       - PasswordAuthentication yes
#       - PermitRootLogin yes
#   2. Restart the SSH service using the command: `systemctl restart sshd`
# Usage:
# - To backup a volume: `./proxmox.sh backup --host <host> --user <user> --lxc <lxc_number> --volume <volume> --path <path>`
# - To restore a volume: `./proxmox.sh restore --host <host> --user <user> --lxc <lxc_number> --volume <volume> --path <path>`
# - Parameters:
#   - `host`: Proxmox host IP address or hostname
#   - `user`: Proxmox host username
#   - `lxc`: LXC container number
#   - `volume`: Name of the Docker volume
#   - `path`: Path for the backup location
# Example:
# - To backup: `./proxmox.sh backup --host 192.168.0.100 --user root --lxc 100 --volume searxng_data --path /Users/husni/backup`
#     > The backup file will be saved to `/Users/husni/backup/searxng_data-backup.tar.gz`.
# - To restore: `./proxmox.sh restore --host 192.168.0.100 --user root --lxc 100 --volume searxng_data --path /Users/husni/backup`
#     > The backup file will be restored from `/Users/husni/backup/searxng_data-backup.tar.gz`, so please ensure that the file exists. This action will overwrite existing files within the Docker volume.
# Script starts here
# Function to prompt for SSH password securely
prompt_password() {
    read -sp "Enter SSH password: " SSH_PASS
    echo
# Function to perform backup
backup() {
    PROXMOX_HOST=$1
    PROXMOX_USER=$2
    LXC_NUMBER=$3
    DOCKER_VOLUME=$4
    BACKUP_PATH=$5
    echo "Starting backup from Proxmox host: $PROXMOX_HOST, LXC: $LXC_NUMBER, Docker volume: $DOCKER_VOLUME"
    prompt_password
    # Create backup directory if it doesn't exist
    mkdir -p "$BACKUP_PATH"
    # Perform the backup
    sshpass -p "$SSH_PASS" ssh "$PROXMOX_USER@$PROXMOX_HOST" "mkdir -p /backup"
    sshpass -p "$SSH_PASS" ssh "$PROXMOX_USER@$PROXMOX_HOST" "pct exec $LXC_NUMBER -- docker run --rm -v $DOCKER_VOLUME:/mnt/data -v /backup:/backup alpine tar czf /backup/$DOCKER_VOLUME-backup.tar.gz -C /mnt/data ."
    sshpass -p "$SSH_PASS" ssh "$PROXMOX_USER@$PROXMOX_HOST" "pct pull $LXC_NUMBER /backup/$DOCKER_VOLUME-backup.tar.gz /backup/$DOCKER_VOLUME-backup.tar.gz"
    sshpass -p "$SSH_PASS" scp "$PROXMOX_USER@$PROXMOX_HOST:/backup/$DOCKER_VOLUME-backup.tar.gz" "$BACKUP_PATH/"
    echo "Backup completed and saved to $BACKUP_PATH"
# Function to perform restore
restore() {
    PROXMOX_HOST=$1
    PROXMOX_USER=$2
    LXC_NUMBER=$3
    DOCKER_VOLUME=$4
    BACKUP_PATH=$5
    echo "Starting restore to Proxmox host: $PROXMOX_HOST, LXC: $LXC_NUMBER, Docker volume: $DOCKER_VOLUME"
    prompt_password
    # Perform the restore
    sshpass -p "$SSH_PASS" scp "$BACKUP_PATH/$DOCKER_VOLUME-backup.tar.gz" "$PROXMOX_USER@$PROXMOX_HOST:/backup/"
    sshpass -p "$SSH_PASS" ssh "$PROXMOX_USER@$PROXMOX_HOST" "pct push $LXC_NUMBER /backup/$DOCKER_VOLUME-backup.tar.gz /backup/$DOCKER_VOLUME-backup.tar.gz"
    sshpass -p "$SSH_PASS" ssh "$PROXMOX_USER@$PROXMOX_HOST" "pct exec $LXC_NUMBER -- docker run --rm -v $DOCKER_VOLUME:/mnt/data -v /backup:/backup alpine tar xzf /backup/$DOCKER_VOLUME-backup.tar.gz -C /mnt/data"
    echo "Restore completed from $BACKUP_PATH"
# Main script logic
if [ $# -lt 1 ]; then
    echo "Usage: $0 {backup|restore} --host <host> --user <user> --lxc <lxc_number> --volume <volume> --path <path>"
    exit 1
fi
COMMAND=$1
shift
while [ $# -gt 0 ]; do
    case "$1" in
    --host)
        PROXMOX_HOST=$2
        shift 2
    --user)
        PROXMOX_USER=$2
        shift 2
    --lxc)
        LXC_NUMBER=$2
        shift 2
    --volume)
        DOCKER_VOLUME=$2
        shift 2
    --path)
        BACKUP_PATH=$2
        shift 2
        echo "Invalid parameter $1"
        exit 1
    esac
done
case "$COMMAND" in
backup)
    backup "$PROXMOX_HOST" "$PROXMOX_USER" "$LXC_NUMBER" "$DOCKER_VOLUME" "$BACKUP_PATH"
restore)
    restore "$PROXMOX_HOST" "$PROXMOX_USER" "$LXC_NUMBER" "$DOCKER_VOLUME" "$BACKUP_PATH"
    echo "Invalid command $COMMAND"
    exit 1
esac
