Pentesting Tactics
Welcome to Pentesting Tactics, your ultimate reference guide for effective penetration testing, designed for both beginners and experienced professionals in the cybersecurity field.
Our carefully curated content directs you to essential insights and strategies across various pentesting domains. Whether you’re exploring the nuances of service and protocol testing or delving into the complexities of web vulnerabilities, we offer comprehensive resources.
No matter your focus within cybersecurity, our materials are tailored to enhance your learning and pentesting experience.
Explore our straightforward, practical guides aimed at advancing your pentesting skills.
Begin your journey now and elevate your cybersecurity knowledge with Pentesting Tactics.
Citations:
[1] A Complete Guide to Penetration Testing - DZone
[2] https://www.bluevoyant.com/knowledge-center/penetration-testing-complete-guide-to-process-types-and-tools
[3] Comprehensive Guide to Pentesting Methodology: From Zero to Hero | by ElNiak | InfoSec Write-ups
[4] What is Penetration Testing? A Complete Guide
[5] A Comprehensive Guide To Types Of Penetration Testing | Wattlecorp Cybersecurity Labs
[6] https://www.getastra.com/blog/security-audit/types-of-penetration-testing/
[7] https://www.eccouncil.org/cybersecurity-exchange/whitepaper/a-comprehensive-guide-to-penetration-testing/
Default Port: 389
LDAP (Lightweight Directory Access Protocol) is a lightweight directory access protocol commonly used to access directory services (such as Active Directory). LDAP operates over TCP/IP and typically uses port 389. Secure LDAP (LDAPS) employs SSL/TLS over LDAP and typically uses port 636.
Connect
LDAP Search
You can connect to an LDAP server and perform a search using the ldapsearch command. Example usage:
ldapsearch -x -h <ldap-server> -b <base-dn> -D <bind-dn> -w <password> -s <search-scope> <filter>
LDAP Authentication
To authenticate against an LDAP server, you can use the ldapwhoami command. Example usage:
ldapwhoami -x -h <ldap-server> -D <bind-dn> -w <password>
Recon
LDAP Server Information
To gather information from an LDAP server, you can use the ldapsearch command. For example, to list all objects:
ldapsearch -x -h <ldap-server> -b "" -s base "(objectclass=*)"
Enumeration
Enumerate Users
LDAP queries can be used to enumerate users. For example, to list all users:
ldapsearch -x -h <ldap-server> -b "ou=users,dc=example,dc=com" "(objectclass=inetOrgPerson)"
Attack Vectors
After successfully exploiting an LDAP server, post-exploitation activities may include:
Dumping Directory Information
Extracting sensitive information such as user credentials, group memberships, and organizational units from the LDAP server.
ldapsearch -h <LDAP-server> -p <port> -x -b "<base-DN>" "(objectclass=*)"
Privilege Escalation
Exploiting misconfigurations or vulnerabilities to escalate privileges and gain higher levels of access.
ldapmodify -h <LDAP-server> -p <port> -x -D "<admin-DN>" -w "<admin-password>" -f <ldif-file>
Data Modification
Modifying directory information, such as adding or deleting user accounts, groups, or attributes.
