Pangolin Monitor and Notification Discord - User Guide
Introduction
Pangolin Monitor is a monitoring solution for your Pangolin stack, providing real-time monitoring of containers, system resources, and security metrics with Discord notifications. This menu-based utility helps you maintain the health and security of your Pangolin deployment.
Installation
  1. Download the script :
    curl -o pangolin-monitor.sh https://gist.githubusercontent.com/hhftechnology/69f7ebdb52fcc60ebc8a182e32c664ab/raw/f38268b3dfb3f8e1109377a02185c0969cc2636d/pangolin-monitor.sh
  2. Make the script Executable:
    chmod +x pangolin-monitor.sh
  3. Run the script to access the menu system:
    ./pangolin-monitor.sh
Main Menu
When you run the script without parameters, you’ll see the main menu with these options:
  1. Run Health Check - Performs a quick check of all monitored components
  2. Start Monitoring (Foreground) - Continuously monitors your system in the terminal
  3. Install as Systemd Service - Sets up the monitor to run as a background service
  4. View Container Status - Shows detailed information about your Docker containers
  5. View System Resources - Displays CPU, memory, disk, and load information
  6. View SSH Login Attempts - Shows recent SSH activity, including failed attempts
  7. Analyze Traefik Logs - Examines Traefik access patterns and potential attacks (Not functional In development-- We have a separate script)
  8. Configuration - Opens the configuration submenu (see below)
  9. Generate Security Report - Creates a report and sends it to Discord
  10. Exit - Quits the program
Select an option by entering its number and pressing Enter.
Configuration Menu
When you select option 8 from the main menu, you’ll access these configuration options:
  1. View Current Configuration - Shows your current settings
  2. Edit Configuration File - Opens your configuration in a text editor
  3. Configure Discord Webhook - Sets up Discord notifications
  4. Configure Monitoring Thresholds - Adjusts alert thresholds
  5. Configure Containers to Monitor - Selects which containers to watch
  6. Configure Notification Settings - Controls notification behavior
  7. Reset to Default Configuration - Restores default settings
  8. Toggle Debug Mode - Enables/disables verbose logging
  9. Back to Main Menu - Returns to the main menu
Key Features
Health Checks
The “Run Health Check” option provides a quick overview of:
  • Container status (running/stopped)
  • System resource usage
  • Security status
  • Discord integration status
Health checks will display color-coded warnings when thresholds are exceeded.
Continuous Monitoring
The “Start Monitoring (Foreground)” option:
  • Runs continuous health checks at configured intervals
  • Displays status updates in real-time
  • Sends alerts to Discord when issues are detected
  • Press Ctrl+C to stop monitoring and return to the menu
Container Monitoring
The script monitors the following for each container:
  • Running status
  • Health checks (if implemented)
  • CPU and memory usage
  • Network I/O
  • Error logs
By default, it monitors: pangolin, gerbil, traefik, and crowdsec containers.
System Resource Monitoring
The script checks and alerts on:
  • CPU usage
  • Memory usage
  • Disk space
  • System load
  • Network traffic
Security Monitoring
Security features include:
  • SSH login attempt tracking
  • Attack detection (high network traffic)
  • Log analysis for suspicious activity
  • Potential security issue notifications
Discord Notifications
When properly configured with a webhook URL, the script will send:
  • Health check reports
  • Attack notifications
  • SSH login notifications
  • System resource alerts
  • Regular status reports
Running as a Service
To install as a systemd service:
  1. Select option 3 from the main menu
  2. Provide your sudo password when prompted
  3. The service will be installed, enabled, and started automatically
You can then manage it with standard systemd commands:
sudo systemctl status pangolin-monitor
sudo systemctl restart pangolin-monitor
sudo systemctl stop pangolin-monitor
Command Line Options
For advanced users, the script also supports these command line parameters:
  • --service: Run in service mode (for systemd)
  • --check: Run a single health check and exit
  • --report: Generate a security report and exit
  • --install-service: Install as systemd service
  • --help or -h: Show help information
  • --version or -v: Display version information
Configuration File
The configuration file is automatically created at ./config/pangolin_monitor.conf and contains settings for:
  • Check intervals (how often checks are performed)
  • Alert thresholds (when to trigger warnings)
  • Container names to monitor
  • Discord webhook URL
  • Notification preferences
You can edit this file directly or use the configuration menu to adjust settings.
  • If Discord notifications aren’t working, verify your webhook URL in the configuration
  • For permission issues, try running with sudo
  • Check the log file at ./logs/pangolin-monitor.log for details about errors
  • Enable debug mode through the configuration menu for more verbose logging
The script requires these programs to be installed:
  • Pangolin Stack
  • jq (for JSON processing)
  • bc (for calculations)
  • curl (for network requests)
The script can attempt to install missing dependencies when run with appropriate permissions.
Hi @hhf.technoloy thank for this. Really useful.
I just tired it. Option 3 for running as service gives me this message instead of asking sudo password…
Enter your choice [0-9]: 3
=== Install as Systemd Service ===
This operation requires root privileges.
Please run with sudo: sudo ./main.sh --install-service
i has to run with privilege
OK I will try the script with sudo thank bro. This is really helpful.
In the default config is this intended to send a Health report every minute?
yes 60 sec. but you can change it.
Is there way how to set that if whole health check is okay it wont send notification?
That would be sweet!
Hi @hhf.technoloy
In what format should the webhook be?
I copied the webhook URL from Discord, pasted it and receive an error:
[ERROR] Invalid Discord webhook URL format: https://discordapp.com/api/webhooks/xxxxxxxxxxxxxx/xxxxxxxxxxxx
Invalid webhook URL format.
Thanks
Hi @hhf.technoloy ,
I have the same issue here, the same discord url format and the same “Error –> Invalid Discord webhook URL format”.
Can you help? :slight_smile:
Nevermind, i used option 2 —> “2. Edit Configuration File”. And pasted in at DISCORD_WEBHOOK=”https://discordapp.com/api/….”. It still gives the same error “invalid discord url, couldnt send message” –> But it does send the message, i recieve it in discord and works :smiley:
