Docker Stack Management Script Guide
Pangolin-Update-Restore-Auto with Crowdsec
https://asciinema.org/a/QnoybaFPNxmZsIhu1LsY7kbsT
Pangolin-Update-Restore-Manual with Crowdsec
https://asciinema.org/a/U97yDZdriFBG8QFFlIsIRnSgp
Overview
This script provides a robust way to manage Docker service deployments by handling two primary operations:
- Updating service versions while maintaining a backup of the previous state
- Restoring services to a previous known working state
Before using the script, ensure you have:
- Docker and Docker Compose installed
- Proper permissions to execute Docker commands
- The following services configured in your docker-compose.yml:
- Pangolin
- Gerbil
- CrowdSec
- Traefik
You need to run the script where you docker-compose.yml file is located for the stack.
Installation
- Save the script to your Docker project directory:
wget https://gist.githubusercontent.com/hhftechnology/c96ae19f5bde3f21a4bfd7db3a1fe00d/raw/f7d0db29332eadad9357508ba4ef98c36da7d322/update-stack.sh
- Make the script executable:
chmod +x update-stack.sh
Basic Usage
The script supports two main commands:
Updating Services
To update your services to new versions:
./update-stack.sh update
When you run this command, the script will:
- Create a backup of your current configuration
- Show you the current versions of all services
- Ask you which services you want to update
- Confirm your choices before proceeding
- Perform the update while maintaining a backup
For each service, you can either:
- Press Enter to keep the current version
- Type a new version number to upgrade/downgrade
- Go to the Pangolin/Gerbil repo to find out the version number
Releases ยท fosrl/pangolin
Example update session:
Current versions:
Current Pangolin tag: 1.0.0-beta.9
Enter new Pangolin tag (or press enter to keep current): 1.0.0-beta.10
Current Gerbil tag: 1.0.0-beta.3
Enter new Gerbil tag (or press enter to keep current):
Current Traefik tag: v3.1
Enter new Traefik tag (or press enter to keep current): v3.2
Current CrowdSec tag: latest
Enter new CrowdSec tag (or press enter to keep current):
Summary of changes:
Pangolin: 1.0.0-beta.9 -> 1.0.0-beta.10
Gerbil: 1.0.0-beta.3 -> 1.0.0-beta.3
Traefik: v3.1 -> v3.2
CrowdSec: latest -> latest
Proceed with these changes? (y/N):
Restoring Services
You can restore services in two ways:
- Restore to the most recent backup:
./update-stack.sh restore
- Restore to a specific backup:
./update-stack.sh restore ./backups/20250205_062549
Backup Management
The script automatically manages backups in the ./backups directory. Each backup includes:
- A complete copy of your docker-compose.yml
- Your entire config directory
- A log file of the operation
- A record of the image tags used
Backups are named using timestamps (e.g., 20250205_062549), making it easy to identify when each backup was created.
Best Practices
- Always test updates in a non-production environment first
- Keep multiple backups to ensure you can restore to various points in time
- Verify services are running correctly after updates or restores
- Monitor the logs during operations for any warnings or errors
If you encounter issues:
- Check the logs in the backup directory
- Ensure all required services are defined in your docker-compose.yml
- Verify you have proper permissions
- Check that all required directories exist and are accessible
Common issues and solutions:
- If services fail to start: Check the Docker logs using
docker compose logs - If restore fails: Ensure the backup directory contains all required files
- If update fails: Verify the new version tags are correct and the images exist
Safety Features
The script includes several safety measures:
- Automatic backup before updates
- Validation of backup contents before restore
- Graceful shutdown of services
- Service verification after operations
- Comprehensive logging of all actions
Tips for Regular Use
- Regularly update your services to get the latest security patches
- Keep at least the last three backups
- Document which versions work well for your setup
- Test restore operations periodically to ensure your backup strategy works
To maintain system health:
- Periodically clean old backups:
find ./backups -type d -mtime +30 -exec rm -rf {} +
- Remove unused Docker images:
docker image prune
This script aims to make service management safer and more reliable. Always refer to your service documentation for specific version compatibility requirements and known issues.
