Pangolin + Crowdsec - Recent Guide?
Hi everyone,
does anyone have a recent guide on getting Crowdsec working with Pangolin?
I’m trying to get it configured on Ubuntu 26.04 VPS using docker.
However getting confused between nftables and iptables options and also syslog and journalctl. There also seem to multiple different bouncers recommended - ranging from the standard traefik one to this one: https://github.com/maxlerebourg/crowdsec-bouncer-traefik-plugin?ref=blog.lrvt.de
I’ve used the Pangolin supplied installer with the --crowdsec option which does a lot of the work.
Not just trying to get everything connected but the community guide on the Pangolin site has a few steps missing I think.
I also saw the comment here about not using docker if on a VPS. Can anyone elaborate on why docker route might not be the way to go? I nearly got that working but then broke Pangolin, so I’m back to the docker route again.
Many thanks,
Mike
hey mike,
you’re on the right track using the official installer with --crowdsec — that does most of the heavy lifting (Traefik logging + the maxlerebourg Traefik plugin).
Quick Answers to Your Questions
  • Docker vs Host install: On a VPS, the Docker route (what the installer uses) is usually fine and simpler, especially if your whole stack is Dockerized. The main reason some recommend host install is for the firewall bouncer (nftables/iptables), which needs better kernel access. For most people, the Traefik plugin bouncer (which the installer sets up) is enough and easier.
  • nftables vs iptables: On Ubuntu 26.04 you should use nftables. If you want the firewall bouncer, install the nftables version.
  • syslog vs journalctl: With the Pangolin setup, CrowdSec usually reads Traefik access logs directly (via volume mount). You generally don’t need syslog/journalctl unless you want to monitor SSH/auth logs too.
Troubleshooting Steps
  1. Check current status
    docker logs crowdsec --tail 100
    docker exec crowdsec cscli decisions list
    docker exec crowdsec cscli bouncers list
    docker exec crowdsec cscli lapi status
  2. Verify Traefik is logging
    Check if the access log is being written:
    docker exec traefik tail -f /var/log/traefik/access.log
  3. Check the plugin is applied
    Look in your traefik_config.yml (or dynamic config) for a middleware like:
    http:
      middlewares:
        crowdsec:
          plugin:
            bouncer:
              enabled: true
              crowdsecLapiKey: "your_key_here"
    Then make sure your routers use this middleware.
Common Missing Steps
The community guide sometimes misses:
  • Restarting the stack properly after changes (docker compose down && docker compose up -d)
  • Adding more collections (e.g. crowdsecurity/traefik, crowdsecurity/appsec-virtual-patching)
  • Setting up the bouncer API key correctly between containers
What exactly is not working right now?
For example:
  • No decisions/bans appearing?
  • Traefik plugin errors in logs?
  • CrowdSec container unhealthy?
  • Bans not being enforced?
Share the output of the commands above (especially docker logs crowdsec and cscli decisions list) and I (or others) can give you much more targeted help.
Happy to walk you through the firewall bouncer setup too if you want deeper protection.
Thanks very much for the detailed reply.
I’ve managed to get everything up and running using the combined Pangolin + Crowdsec install with everything apart from the bouncer containerised.
Very glad I have now that I can see everyone and everything trying to break in.
All the best
Mike
Btw I also add this at the end of my ~/.bashrc to avoid typing docker exec -it crowdsec again and again. cscli will work directly after this
cscli() {
    # If terminal is interactive (you typing it), use -it for pretty tables.
    # If it's a pipe or script, drop -t so Docker doesn't throw a TTY error.
    if [ -t 0 ]; then
        docker exec -it crowdsec cscli "$@"
    else
        docker exec -i crowdsec cscli "$@"
    fi
Sorry to jump in this thread, but I haven’t been able to find a way to create a new one.
I’ve posted some questions on the discord which have received no response and I’m not sure if anything is currently being supported.
I saw this topic on the crowdsec manager github and am in a similar situation:
**Link removed: Not allowed to post links to the HHF GitHub**
Crowdsec-Manager in multi-server setup Discussion #129
I’d like to know if there’s some way to be able to use the HHF Crowdsec Manager to see what’s going on with the Traefik Crowdsec bouncer(s) on the Pangolin VPS (i.e., which does not have Crowdsec running on it)?
The HHF Crowdsec Manager on the “CrowdSec Host Machine” that is running the Crowdsec host engines (LAPI & AppSec) can see what they’re doing, but I don’t know how to inspect to see what’s going on with the VPS bouncer or if that’s even something that it can do.
(NB: The “CrowdSec Host Machine” is another machine with the capacity to actually run the CS LAPI and AppSec engines without starving the resource-limited Pangolin VPS of RAM and thus allowing it function acceptably.)
In other words, I’m at a point where
  • The VPS ../docker/pangolin/config/traefik/logs/access.logis (more or less consistently—issue remain) streaming to the CS Host Machine
  • HHF CrowdSec Manager on the CS Host Machine is showing alerts and decisions
  • The VPS Traefik can get a healthcheck back on the LAPI
  • The VPS Traefik seem to be able to connect to the AppSec engine
So it seems like it should be enforcing the decisions, but I don’t really know how to verify that.
Thanks!
