New releases of owncloud/ocis are posted here automatically.
Join @releases-owncloud-infinite-scale to get a DM and a bell for every release.
Security - Update the saml and ws dependencies: #13575
We updated two indirect Go dependencies to fix known vulnerabilities. The module
GitHub - crewjam/saml: SAML library for go · GitHub is now v0.5.2. The module GitHub - gobwas/ws: A tiny WebSocket library for Go. · GitHub is now
v1.5.0. The module GitHub - russellhaering/goxmldsig: Pure Go implementation of XML Digital Signatures · GitHub is now v1.6.1, as the new
saml version requires it.
Bugfix - Use a dedicated ICAP client per scan: #13387
The antivirus service now creates a dedicated ICAP client for every scan instead
of sharing a single client between its workers. This only affects deployments
using ANTIVIRUS_SCANNER_TYPE=icap.
Bugfix - Fix slow builds with GNU Make 4.4: #13470
The file .make/recursion.mk now expands the GO, GOPATH, GOHOSTOS,
GOHOSTARCH and GOHOSTARM variables one time only, before its export.
Before, each use of these variables ran a shell command again. With GNU Make
4.4, these commands ran again and again. A make call took about two minutes
before it started the build, and it printed thousands of “env: ‘GOHOSTOS’: No
such file or directory” errors. Ubuntu 26.04 and the ubuntu-latest GitHub
runner have GNU Make 4.4.
Bugfix - Filter spurious TLS handshake errors from CI test runner output: #13499
Go’s net/http server emits TLS handshake error from <addr>: ... to stderr
whenever a client connects to an HTTPS port but does not complete the handshake.
This happens routinely in acceptance test runs: health-check probes, Playwright
browser initialisation, and curl readiness polls all trigger the message even
though no test ever fails because of it. The messages accumulate in the hundreds
per run and push genuinely interesting output far down the CI log.
The five Python test-runner scripts (run-github.py, run-litmus.py,
run-cs3api.py, run-wopi.py) now pipe each long-lived ocis/ociswrapper
subprocess’s stderr through a background thread that drops lines containing TLS handshake error and forwards everything else to the runner’s stderr unchanged.
Real errors remain fully visible.
The two Bash scripts (tests/ldap-smoke/run.sh,
tests/ldap-smoke-distributed/run.sh) use a Bash process substitution (`2>
(grep -v “TLS handshake error” >&2)`) for the same effect without requiring a
log file.
Bugfix - Wait for app registry before running WOPI cs3 validator tests: #13504
The WOPI cs3 validator occasionally failed with HTTP 500 on OpenInApp calls
during the EditFlows test group. The gateway logged error finding app providers — meaning the app-provider service had not yet finished registering
its mime-type entries with the gateway, even though the ocis_healthy() check
(a graph API call) had already passed.
A new app_registry_ready() probe is added to run-wopi.py that calls GET /app/list and verifies the response contains at least one mime-type entry. This
probe runs after ocis_healthy() and before the WOPI service is started,
ensuring the gateway’s app provider list is populated before the validator
begins issuing OpenInApp requests.
Bugfix - Remove stale group shares in the share manager: #13561
A stale group share is a share ID in the group cache that has no share. On each
listing of the received shares, the share manager found the stale ID again and
uploaded the received.json file of the user again with the same content. The
stale ID stayed, so this repeated on each listing.
The share manager now removes a stale group share from the group cache. It does
this only when it read the share file of the space. It reads each share from the
same copy of that file, so a parallel listing cannot make valid shares look
stale. A Remove no longer uploads a file when the share is not in it. A listing
of the created shares now also reads each share from one copy of the share file.
Before, a parallel listing could hide some shares of a space from the creator.
An update of a share now reads the share again under the space lock. Before, a
parallel failed upload in the same space could remove the space from memory. The
update then reported success, but it did not write the change. An update now
also returns NotFound for a share that a parallel unshare removed. Before, the
update could write the removed share again.
When the upload of a Remove fails, the share manager now reads the file again on
the next call. Before, it kept the share out of memory, but the share stayed in
the file. A retry then found nothing to remove, did not upload, and reported
success. In the received.json file of a user, this also occurred inside one
Remove after a temporary upload error. The same applies to an Add. Before, a
failed upload of an Add kept the new entry in memory. For example, a client got
an error when it accepted a share, but this pod showed the share as accepted.
An unshare and an update of a share now read the share file of the space again
when the share is not in memory. Before, a listing that got a temporary NotFound
left an empty copy of the space in memory. An unshare then did not remove the
share from the file, but it reported success. An update returned NotFound for a
share that existed.
The share manager removes a stale entry only after a grace period of 5 minutes.
During a rolling upgrade, an older version can write the grantee entry before
the share. Without the grace period, a listing in this window removed the entry,
and no group member saw the share. A listing that finds the share again restarts
the grace period. Thus two short losses do not add up to one long loss. Each pod
counts the grace period itself. A pod remembers a stale entry for 1 hour after
the last listing that found it. Thus the grace period also ends on a pod that
finds the entry only once in some minutes. A pod looks for the entries to forget
at most once a minute. Thus a listing that finds many stale entries does not
hold the lock for a long time. When the removal of a stale entry fails, the next
listing tries the removal again at once. The pod forgets the entry only after
the removal.
The share manager now also removes a stale entry when the share file of the
space does not exist. A failed first share in a space leaves such an entry. A
download that gets NotFound is not enough proof, because the NotFound can be
temporary. The share manager checks the file a second time.
The share manager now writes a share before the entry for the grantee. When a
write fails, it removes the entries that it wrote, also the entry for the
grantee. The removal also runs when the request was cancelled. Each removal has
its own timeout, so a slow removal does not stop the next one. Thus a failed
share does not block a new share with the same grantee. The share manager
removes the share and the entry of the creator at the same time, so a failed
share waits for at most two timeouts. An unshare removes the share also when the
entry for the grantee cannot be removed, and it reports success. Before, the
client got an error for a share that was gone. The next listing of the grantee
removes the stale entry.
The share manager now removes many shares together, with one upload for each
document. A purge of a space with 20 group shares did 41 uploads and now does 3.
A listing that finds 20 expired shares did 60 uploads and now does 3. A listing
removes the expired shares of all spaces together. The setting
SHARING_USER_JSONCS3_MAX_CONCURRENCY limits the parallel removals. Its default
does not change and is 1. The removals always use a limit of at least 3. Before,
the removal of one share updated its 3 documents in parallel. With a limit of 1,
an unshare needed one more round trip to the storage.
The share cleanup of the ocis shares commands now removes all orphaned shares
together, with one upload for each document. Before, it removed the shares one
at a time. 20 orphaned shares in one space did 60 uploads and now do 3. A Stat
error no longer stops the cleanup with a panic. The cleanup skips that share and
checks the next share. The cleanup also stops with an error log when it cannot
get a gateway client. Before, it stopped with a panic.
The share manager now sends one ShareExpired event for each expired share.
Before, each listing that found the expired share sent an event, also when the
removal failed. Thus the users got many expiry notifications.
The share manager no longer keeps an empty space entry in the created cache and
in the group cache. Before, each listing read the share file of a deleted space
again.
When a space is deleted, the share manager now logs the errors of the share
cleanup. Before, it sent them to a disabled logger.
Each log line of a share listing now has the fields of one share only. Before, a
later line had the fields of all earlier shares, and a log search found the
wrong share.
A Remove on the created cache or on the group cache no longer panics when the
user or group has no entry for the space of the share, or when the share ID has
no delimiter. Before, the panic stopped the sharing service, also in an unshare
and in the cleanup of orphaned shares.
fix: [stable-8.2][OCISDEV-1685] remove stale group shares in the share manager by 2403905 · Pull Request #13561 · owncloud/ocis · GitHub
fix: [stable-9.0][OCISDEV-1685] remove stale group shares in the share manager by 2403905 · Pull Request #13545 · owncloud/ocis · GitHub
fix: [stable-9.0][OCISDEV-1685] remove stale group shares in jsoncs3 by 2403905 · Pull Request #833 · owncloud/reva · GitHub
fix: [stable-8.0][OCISDEV-1685] remove stale group shares in jsoncs3 by 2403905 · Pull Request #813 · owncloud/reva · GitHub
Bugfix - Only open supported file types in web viewer apps: #13585
Viewer apps in the web UI, like the PDF viewer, could be opened for any file by
entering its address directly, even when the app does not support that file
type. The file was then loaded and shown anyway.
Viewer apps now check that the file type is supported before loading the file
and show an error message otherwise.
Bugfix - Make the share cache locks cancellable: #13597
Requests that wait for a lock of the share caches of the jsoncs3 share manager
now give up when their context is done, instead of waiting until they get the
lock. Requests that the client already abandoned no longer pile up and keep
their memory under load. The provider cache also rejects updates with an empty
storage, space or share id.
[full-ci] chore(deps): [OCISDEV-1661][OCISDEV-1564][OCISDEV-1195][OCISDEV-1197][OCISDEV-1729] bump reva by LukasHirt · Pull Request #13597 · owncloud/ocis · GitHub
fix: [OCISDEV-1564] make jsoncs3 share cache locks cancellable by LukasHirt · Pull Request #866 · owncloud/reva · GitHub
fix: [OCISDEV-1729] validate ids in Cache.Update and add UpdateShare CAS regression tests by LukasHirt · Pull Request #862 · owncloud/reva · GitHub
Bugfix - Cache decoded node attributes: #13597
The file metadata cache keeps a bounded, process-local layer of already decoded
node attributes, so reading cached attributes no longer decodes them on every
access. Every read still checks the value in the configured cache store, so the
result is the same as before. By default the layer is limited to 16384 entries
and about 64 MiB per cache.
perf: [OCISDEV-1197] cache decoded node attributes in the file metadata cache by LukasHirt · Pull Request #864 · owncloud/reva · GitHub
Bugfix - Reduce the cost of listing storage spaces: #13597
Listing the storage spaces of a user, as done by /graph/v1.0/me/drives, no
longer reads the type of every space root from disk, and grants are parsed
without setting up a csv reader for each grant.
perf: [OCISDEV-1195] reduce the cost of listing storage spaces by LukasHirt · Pull Request #865 · owncloud/reva · GitHub
Bugfix - Expose the etag of shared drives: #13597
The mountpoint drives of received shares in /graph/v1.0/me/drives now carry
a root.eTag, so clients can detect changes in shared folders by comparing the
etag of the drive root. The shares jail and mountpoint drives fall back to a
stable default etag when the shared resource has no etag.
fix: [OCISDEV-1661] expose etag of mountpoint spaces by LukasHirt · Pull Request #863 · owncloud/reva · GitHub
Enhancement - Harden the Collabora deployment examples: #13389
The ocis_full and ocis_ocm deployment examples now ship a hardened Collabora
configuration. Collabora is restricted to the hosts it needs, runs on its own
internal network that only the proxy and the collaboration service share, and
the admin console requires explicitly configured credentials
(COLLABORA_ADMIN_USER and COLLABORA_ADMIN_PASSWORD). If you copy these
examples, make sure to set the credentials in your .env file.
Enhancement - Update Mockery to 2.53.8: #13470
We updated the mockery tool in .bingo/mockery.mod from v2.53.5 to v2.53.8.
