Optimized Nginx and MySQL files for Cloudpanel Heavy Connection
NGINX configuration for a high-traffic Cloupanel site handling 100K clicks per day.
File is located at
/etc/nginx/nginx.conf
I’ve created an optimized NGINX configuration for high-traffic site. Here are the key optimizations and changes made:
  1. Worker Processes & Connections
    • Increased worker_rlimit_nofile to 65535 to handle more concurrent connections
    • Optimized worker_connections to 65535
    • Enabled multi_accept for better high-traffic handling
    • Disabled accept_mutex for better performance under high load
  2. FastCGI Caching
    • Implemented FastCGI caching with a 100MB zone size
    • Cache valid responses for 60 minutes
    • Added cache bypass options for dynamic content
    • Optimized buffer sizes for typical Laravel responses
  3. Performance Optimizations
    • Tuned keepalive settings for high-traffic scenarios
    • Optimized buffer sizes for different types of requests
    • Implemented efficient file caching settings
    • Added rate limiting to prevent abuse
  4. Security Enhancements
    • Implemented strict SSL configuration
    • Added security headers
    • Protected sensitive Laravel directories
    • Rate limiting for PHP requests
  5. Compression
    • Optimized Gzip compression settings
    • Added Brotli compression support
    • Configured caching for static assets
  6. PHP-FPM Optimization
    • Tuned FastCGI parameters for better performance
    • Implemented request limiting
    • Added connection limiting
    • Optimized timeouts
  7. Logging
    • Enhanced log format to include response times
    • Buffered logging for better performance
    • Disabled logging for common static files
To implement this configuration:
  1. Backup your current configuration
  2. Adjust paths and server names according to your setup
  3. Test the configuration with nginx -t
  4. Gradually implement changes in staging before production
user root;
worker_processes auto;
pid /run/nginx.pid;
error_log  /var/log/nginx/error.log notice;
worker_rlimit_nofile 65535;
include /etc/nginx/modules-enabled/*.conf;
events {
    use                 epoll;
    worker_connections 65535;
    # multi_accept on;
    epoll_events        512;
http {
    # Basic Settings
    geoip_country /etc/nginx/geoip/GeoIP.dat; # the country IP database
    geoip_city    /etc/nginx/geoip/GeoLiteCity.dat; # the city IP database
    real_ip_recursive on;
    set_real_ip_from 127.0.0.1;
    set_real_ip_from 10.0.0.0/8;
    set_real_ip_from 172.16.0.0/12;
    set_real_ip_from 192.168.0.0/16;
    #real_ip_header X-Forwarded-For;
    log_format main '$remote_addr - $remote_user [$time_local] "$request" '
                    '$status $body_bytes_sent "$http_referer" '
                    '"$http_user_agent" "$http_x_forwarded_for"';
    log_format cloudflare '$http_cf_connecting_ip - $remote_user [$time_local] "$request" '
    # Define fastcgi_cache settings
    # FastCGI Cache Settings
    fastcgi_cache_key "$scheme$request_method$host$request_uri$cookie_pll_language";
    fastcgi_cache_use_stale error timeout invalid_header updating http_500 http_503;
    fastcgi_cache_methods GET HEAD;
    fastcgi_buffers 256 32k;        # Reduced number of buffers, still maintaining good performance
    fastcgi_buffer_size 256k;       # Reduced to better match common response sizes
    fastcgi_connect_timeout 3s;    # Reduced to fail faster
    fastcgi_send_timeout 180s;     # Increased for better reliability with slow upstream
    fastcgi_busy_buffers_size 512k;
    fastcgi_temp_file_write_size 512k;
    fastcgi_param SERVER_NAME $http_host;
    fastcgi_ignore_headers Cache-Control Expires Set-Cookie;
    fastcgi_keep_conn on;
    fastcgi_cache_lock on;
    fastcgi_cache_lock_age 1s;     # Increased to reduce cache stampede
    fastcgi_cache_lock_timeout 5s; # Increased for better reliability
    # Proxy Settings
    proxy_buffers 4 256k;           # Optimized for typical response sizes
    proxy_buffer_size 128k;         # Adjusted for headers
    proxy_busy_buffers_size 256k;  # Reduced to save memory
    proxy_connect_timeout 600;      # Reduced to fail faster
    proxy_send_timeout 600;        # Balanced timeout
    proxy_read_timeout 600;        # Balanced timeout
    # TCP Settings
    sendfile on;
    tcp_nopush on;
    tcp_nodelay on;
    # aio threads;                   # Enable async I/O with threads
    # directio 512;                  # Enable direct I/O for files > 512 bytes
    # Timeout Settings
    send_timeout 60;              # Reduced to free resources faster
    keepalive_timeout 65;         # Optimal for most cases
    keepalive_requests 2048;      # Increased for better performance
    # Client Request Settings
    client_body_buffer_size 16k;   # Increased for better performance
    client_header_buffer_size 2k;  # Increased slightly
    large_client_header_buffers 4 8k;  # Reduced buffer size
    client_body_timeout 15;        # Reduced for faster failure detection
    client_header_timeout 15;      # Reduced for faster failure detection
    client_max_body_size 100M;     # Increased to handle larger uploads
    # Performance Settings
    server_tokens off;
    port_in_redirect off;
    access_log off;
    # File Cache Settings
    open_file_cache max=500000 inactive=60s;  # Increased cache size
    open_file_cache_valid 120s;               # Increased validity
    open_file_cache_min_uses 2;               # Reduced to cache more files
    open_file_cache_errors on;
    types_hash_max_size 4096;                 # Increased for more MIME types
    map $scheme $fastcgi_https { ## Detect when HTTPS is used
      default off;
      https on;
    include /etc/nginx/blocked_ips;
    # include /etc/nginx/blocked_bots;
    pagespeed off;
    pagespeed XHeaderValue 1;
    # SSL Settings - Hardened Configuration
    ssl_conf_command Options KTLS; # Kernel TLS for better performance
    # Strict ciphersuite selection - most secure TLS 1.3 ciphersuites only, prioritizing security
    ssl_conf_command Ciphersuites TLS_AES_256_GCM_SHA384:TLS_CHACHA20_POLY1305_SHA256;
    # TLS 1.3 only - no fallback to older versions
    ssl_protocols TLSv1.3;
    # Optimized session cache settings
    ssl_session_cache shared:SSL:10m;
    ssl_session_timeout 4h;
    ssl_session_tickets off;
    # Use only the strongest curve
    ssl_ecdh_curve secp384r1;
    ssl_prefer_server_ciphers on;
    # Use more reliable DNS resolvers with DNSSEC support
    resolver 9.9.9.9 149.112.112.112 valid=3600s;
    resolver_timeout 2s;
    # OCSP Stapling
    ssl_stapling on;
    ssl_stapling_verify on;
    ssl_dhparam /etc/nginx/ssl/dhparams.pem;
    # 0-RTT can be risky for some applications - disable if you handle sensitive data
    ssl_early_data on;
    # Strict security headers
    add_header Strict-Transport-Security "max-age=63072000" always;
    # HTTP/3 support with strict settings
    add_header alt-svc 'h3-27=":443"; ma=86400, h3-28=":443"; ma=86400, h3-29=":443"; ma=86400, h3=":443"; ma=86400';
    include /etc/nginx/mime.types;
    default_type application/octet-stream;
    # Logging Settings
    access_log /var/log/nginx/access.log;
    error_log /var/log/nginx/error.log;
    # Limit the requests for php
    limit_conn_zone $binary_remote_addr zone=perip:10m;
    limit_req_zone $binary_remote_addr zone=limit:10m rate=1r/s;
    # Gzip Settings
    gzip on;
    # gzip_static on;
    gzip_min_length 1000;
    gzip_http_version 1.1;
    gzip_comp_level 5;
    gzip_disable "MSIE [4-6]\.";
    gzip_proxied any;
    gzip_vary on;
    gzip_types text/plain
               text/xml
               text/css
               text/javascript
               application/json
               application/javascript
               application/x-javascript
               application/ecmascript
               application/xml
               application/rss+xml
               application/atom+xml
               application/rdf+xml
               application/xml+rss
               application/xhtml+xml
               application/x-font-ttf
               application/x-font-opentype
               application/vnd.ms-fontobject
               image/svg+xml
               image/x-icon
               application/atom_xml;
    gzip_buffers 32 16k;
    # Brotli Settings
    brotli on;
    brotli_comp_level 8;
    brotli_static on;
    brotli_types text/plain text/css application/json application/x-javascript text/xml application/xml application/xml+rss text/javascript image/png image/gif image/jpeg application/javascript image/svg+xml;
    # Virtual Host Configs
    include /etc/nginx/conf.d/*.conf;
    include /etc/nginx/sites-enabled/*.conf;
MySQL configuration for a high-traffic setup with 100K clicks and 38GB of RAM. I’ll create an optimized version focusing on key performance areas.
File locate at
/etc/mysql/mariadb.conf.d/100-cloudpanel.cnf
##or
/etc/mysql/mysql.conf.d/
I’ve made several important optimizations for 38GB RAM server handling 100K clicks. Here are the key changes and explanations:
  1. Memory Usage:
    • Set innodb_buffer_pool_size to 28GB (75% of your 38GB RAM)
    • Increased innodb_buffer_pool_instances to 16 for better concurrency
  2. Connection Handling:
    • Increased max_connections to 2000 to handle high traffic
    • Increased back_log to 1000 for better connection queue handling
    • Adjusted thread cache and timeout settings
  3. InnoDB Optimizations:
    • Increased innodb_log_file_size to 2GB for better performance
    • Set innodb_flush_log_at_trx_commit = 2 for better performance while maintaining good reliability
    • Optimized I/O settings with increased read/write threads
    • Added innodb_io_capacity settings optimized for SSD
  4. Buffer and Cache Settings:
    • Increased various buffer sizes (join, read, sort) for better performance
    • Disabled query cache as it’s inefficient for high-concurrency workloads
    • Increased temp table sizes to 512M
  5. Table Handling:
    • Increased table cache settings for better concurrent table access
    • Increased open_files_limit to handle more concurrent open tables
  6. Monitoring:
    • Enabled slow query log with 2-second threshold
    • Disabled binary logging unless you need replication
Important notes:
  1. You’ll need to ensure your system’s ulimit settings can handle these values
  2. Monitor the server’s performance and adjust these values based on actual usage patterns
  3. Ensure your filesystem and OS are also optimized for these settings
MariaDB
# === Required Settings ===
pid-file = /var/run/mysqld/mysqld.pid
socket = /var/run/mysqld/mysqld.sock
log-error = /var/log/mysql/error.log
datadir = /home/mysql/
character-set-server = utf8mb4
collation-server  = utf8mb4_general_ci
init-connect = 'SET NAMES utf8mb4'
thread_cache_size = 32
table_open_cache = 2048
sort_buffer_size = 8M
# === InnoDB Settings ===
innodb_file_per_table
innodb = force
innodb_buffer_pool_instances    = 16
innodb_buffer_pool_size = 28G
innodb_file_per_table          = 1
innodb_sort_buffer_size        = 16M
innodb_log_file_size = 2GB
innodb_stats_on_metadata = OFF
innodb_buffer_pool_instances = 8
innodb_io_capacity             = 3000
innodb_io_capacity_max         = 6000
innodb_read_io_threads         = 16
innodb_write_io_threads        = 16
innodb_log_buffer_size = 10M
innodb_flush_method            = O_DIRECT
innodb_log_buffer_size         = 64M
innodb_thread_concurrency = 32
# === Connection Settings ===
max_connections                = 2000    # Increased for high traffic
back_log                       = 1000    # Increased for high traffic
thread_cache_size             = 200     # Increased for better thread handling
thread_stack                  = 256K
interactive_timeout           = 300     # Increased timeout
wait_timeout                 = 300     # Increased timeout
# === Buffer Settings ===
join_buffer_size             = 8M      # Increased for better JOIN performance
read_buffer_size             = 4M      # Increased for better read performance
read_rnd_buffer_size         = 8M      # Increased for better random read performance
sort_buffer_size             = 8M      # Increased for better sorting performance
# === Table Settings ===
table_definition_cache       = 60000   # Increased for more concurrent tables
table_open_cache            = 60000   # Increased for more concurrent tables
open_files_limit            = 100000  # Increased accordingly
max_heap_table_size         = 512M    # Increased for better temp table handling
tmp_table_size              = 512M    # Increased for better temp table handling
# === Query Cache Settings ===
query_cache_size            = 0
query_cache_type           = 0
# === Logging Settings ===
slow_query_log             = 1
slow_query_log_file        = /var/lib/mysql/mysql_slow.log
long_query_time            = 2        # Log queries slower than 2 seconds
log_queries_not_using_indexes = 0
# === Binary Logging ===
disable_log_bin
MySQL
default-authentication-plugin = mysql_native_password
character_set_server = utf8mb4
collation_server = utf8mb4_general_ci
innodb = force
innodb_stats_on_metadata = 0
back_log = 1000
thread_stack = 256K
wait_timeout = 300
slow_query_log = 1
long_query_time = 2
disable_log_bin
# === Added Safety Settings ===
max_allowed_packet = 1024M
[mysqldump]
set-gtid-purged=OFF
ssl-mode=DISABLED
