In the readme Quick Start it describes how to list multiple paths for monitoring multiple traefik logs via TRAEFIK_LOG_PATH
But it appears that in itself does not monitor the access logs. It’s necessary to specify TRAEFIK_LOG_FILE, however it appears that only a single access log file can be monitored at a time e.g. - TRAEFIK_LOG_FILE=/logs/access.log.
This does not work: TRAEFIK_LOG_FILE=/logs/access.log,/logs/remote-traefik/access.log, neither does this TRAEFIK_LOG_FILE=/logs/*
According to this this feature is somehow supported.
Under Quick Start the following is mentioned: Automatically discovers .log files in directories
.env
# Path to your Traefik log file or directory
# Can be a single path or comma-separated list of paths
# Examples:
# - Single file: /path/to/traefik.log
# - Single directory: /path/to/logs/
# - Multiple paths: /path/to/logs1/,/path/to/logs2/,/path/to/specific.log
TRAEFIK_LOG_PATH=/logs/
# Backend API port (optional, default: 3001)
PORT=3001
# Frontend port (optional, default: 3000)
FRONTEND_PORT=3000
docker logs of backend only monitoring traefik.log, despite support for monitoring all .log files
i.e. 2025/08/07 07:17:32 Setting up monitoring for log file(s): [/logs/traefik.log]
2025/08/07 07:17:32 MaxMind database loaded successfully from: /maxmind/GeoLite2-City.mmdb
[GIN-debug] [WARNING] Creating an Engine instance with the Logger and Recovery middleware already attached.
[GIN-debug] [WARNING] Running in "debug" mode. Switch to "release" mode in production.
- using env: export GIN_MODE=release
- using code: gin.SetMode(gin.ReleaseMode)
[GIN-debug] GET /api/stats --> main.getStats (4 handlers)
[GIN-debug] GET /api/logs --> main.getLogs (4 handlers)
[GIN-debug] GET /api/services --> main.getServices (4 handlers)
[GIN-debug] GET /api/routers --> main.getRouters (4 handlers)
2025/08/07 07:17:32 Server running on port 3001
[GIN-debug] GET /api/geo-stats --> main.getGeoStats (4 handlers)
[GIN-debug] GET /api/geo-processing-status --> main.getGeoProcessingStatus (4 handlers)
[GIN-debug] POST /api/set-log-file --> main.setLogFile (4 handlers)
[GIN-debug] POST /api/set-log-files --> main.setLogFiles …
