🚨 NGINX HTTP/2 vulnerabilities: affected versions, distribution patches, and mitigation
Two HTTP/2 vulnerabilities can permit unauthenticated remote code execution in NGINX. Upstream fixes are available in 1.30.7 stable and 1.31.9 mainline. Distribution packages may contain backported fixes under older version numbers. See the NGINX security advisories.
This independent summary references Mattias Geniar’s package-status report and the vendor sources linked below.
Which installations are affected?
HTTP/2 must be enabled. The upstream affected ranges differ:
VulnerabilityAffected upstream versionsConditions
CVE-2026-1230071.9.5–1.31.8HTTP/2 flow-control memory corruption; exploitation demonstrated over HTTPS, including static-file servers.
CVE-2026-1236331.19.7–1.31.8HTTP/2 use-after-free associated with scarce connection slots and reverse-proxy processing.
Sources: NGINX affected versions and Wiz research.
Check the binary version and effective configuration locally:
nginx -v
sudo nginx -T 2>/dev/null | grep -n http2
Review matching directives: comments or http2 off; do not establish exposure. An externally reachable origin remains relevant even when normal traffic passes through a CDN.
Distribution package status
Snapshot: the source article’s table was checked on 19 November 2026 at 01:58 UTC. All its distribution entries are represented below. Debian sid has been annotated with newer tracker information. Other entries retain the reported snapshot; repository and architecture availability can change.
Fixed means a package addressing both CVEs was reported available. Pending means work or rollout was underway. No fix means none was reported in that snapshot. Analysis means the vendor had not confirmed its assessment.
Distribution / channelStatusPackage or details
nginx.org packagesFixed1.30.7 stable; 1.31.9 mainline. Reported coverage: Ubuntu 22.04/24.04/26.04; Debian 12/13; RHEL 8/9/10 and rebuilds; SLES 15 SP6+/16; Alpine 3.21–3.24; Amazon Linux 2023. Supported repositories.
Docker official NGINX imageFixednginx:1.30.7 or nginx:1.31.9. Image tags.
NGINX PlusFixes listed; check branchR33 and 37.x affected. Wiz lists 37.0.7.1/37.2.0.1 for CVE-2026-123633 and 37.0.8.1/37.3.0.1 for CVE-2026-123007. Choose a release covering both: F5 advisory 1, F5 advisory 2.
Ubuntu 24.04 LTSNo fixUbuntu tracker.
Ubuntu 22.04 LTSNo fixUbuntu tracker.
Ubuntu 26.04 LTSNo fixUbuntu tracker.
Ubuntu 26.10No fixUbuntu tracker.
Ubuntu 20.04 / 18.04 / 16.04No fixExtended security updates require Ubuntu Pro. Tracker.
Debian 13 trixieNo fix1.26.3-3+deb13u10 vulnerable. Tracker.
Debian 12 bookwormNo fix1.22.1-9+deb12u10 vulnerable. Tracker.
Debian sidUpdated tracker informationArticle snapshot: 1.30.6-4 uploaded, archive availability pending. The current tracker lists that version as fixed for CVE-2026-123007; verify both CVEs and mirror availability before deployment.
Debian forkyNo fix1.30.6-3 vulnerable. Tracker.
RHEL 9No fixDefault package and nginx:1.24/nginx:1.26 streams. Tracker.
RHEL 10No fixRed Hat tracker.
RHEL 8No fixnginx:1.24 stream. Tracker.
AlmaLinux 10Fixed2:1.26.3-16.el10_3.1.alma.2; x86_64, x86_64_v2, aarch64, ppc64le, s390x. ALSA-2026:A024.
AlmaLinux 9 default packageFixed2:1.20.1-32.el9_9.1.alma.3; x86_64, aarch64, ppc64le, s390x. ALSA-2026:A025.
AlmaLinux 9 module streams / AlmaLinux 8No fixAlmaLinux 9 nginx:1.24/nginx:1.26 and AlmaLinux 8 had no listed advisory. Errata.
Amazon Linux 2023Fixed1.30.7-1.amzn2023.0.1; x86_64, aarch64. ALAS2023-2026-3494.
Amazon Linux 2Pendingnginx1 extra awaiting fixes for both CVEs.
Alpine 3.24Fixed1.30.7-r0.
Alpine edgeFixed1.30.7-r0. Packages.
Alpine 3.23 / 3.22, x86_64Fixed1.28.3-r8, backported fixes. Security database.
Alpine 3.23 / 3.22, other architecturesPendingFix recorded in 1.28.3-r8; aarch64 repositories still reported 1.28.3-r7.
Alpine 3.21No fix1.26.3-r3 vulnerable.
Arch Linux, extraFixednginx 1.30.7-1; nginx-mainline 1.31.9-1.
Fedora 45 / 44 / 43No fix1.30.6 reported vulnerable.
SLES 15 SP7 / 16.0 / 16.1; openSUSE Leap 16.0 / 16.1AnalysisVendor assessment pending.
openSUSE TumbleweedNo fix1.31.8-1.1 reported vulnerable.
Snapshot-only entries and rollout details are attributed to the original report. Consult the vendor’s notices for both CVEs before treating an installation as patched.
Apply and verify the fix
Install a vendor-confirmed patched package, then validate the configuration and restart the service. A configuration reload alone does not replace the running executable. See NGINX process control.
On systemd installations, after updating:
sudo nginx -t && sudo systemctl restart nginx
Alpine uses sudo rc-service nginx restart. For containers, deploy the patched image and recreate the container.
If using nginx.org packages, follow the official repository instructions. Back up configuration and check site includes and dynamic-module compatibility before switching package sources.
Check the full installed package version against your vendor advisory; an older upstream version may already include a backport. Red Hat explains this distinction.
Temporary workaround: disable HTTP/2
On NGINX 1.25.1 or later, disable HTTP/2 in each applicable server block and remove legacy http2 parameters from listen directives:
server {
    listen 443 ssl;
    http2 off;
    # Keep the remaining site configuration.
On older versions, remove http2 from every applicable listen directive. Review all virtual hosts sharing the listening address. See the HTTP/2 module documentation and Wiz mitigation guidance.
Test, reload, and allow the old workers to exit. On systemd:
sudo nginx -t && sudo systemctl reload nginx
curl --http2 -sS -o /dev/null -w '%{http_version}\n' https://example.com/
Replace the example URL with your endpoint. With an HTTP/2-capable curl, 1.1 indicates fallback for that endpoint. Test each exposed origin and hostname; a CDN-facing check only tests the CDN connection.
Disabling HTTP/2 is temporary. The same releases address additional issues, including HTTP/3 CVE-2026-121810, so install the security updates even after applying the workaround. Re-enable HTTP/2 once the patched deployment is verified. NGINX advisories.
