Nextcloud using Nginx & Docker Compose
This sample config set includes:
- Nextcloud setup using Docker-Compose
- Nginx serves the Docker using reverse-proxy
- Systemd service file (optional)
There are examples of the nginx config that include:
- Top-level dir mode (serving directly on https://example.com or https://subdomain.example.com)
- Sub directory mode (serving on https://example.com/nextcloud or https://subdomain.example.com/nextcloud - or other directory name)
[docker-compose.yml]
version: "3"
nginx:
image: nginx:stable
- ./nginx/nginx.conf:/etc/nginx/nginx.conf:ro
# put HTTPS certificates here
- /etc/letsencrypt/live/example.com/fullchain.pem:/root/ssl/cert.pem:ro
- /etc/letsencrypt/live/example.com/privkey.pem:/root/ssl/key.pem:ro
- 443:443
links:
- nextcloud
nextcloud:
image: nextcloud:latest
links:
- mysql
- 8080:80
# replace example.com with your domain/subdomain
- VIRTUAL_HOST=example.com
- VIRTUAL_PORT=8080
# update credentials here
- MYSQL_HOST=mysql
- MYSQL_DATABASE=nextcloud
- MYSQL_USER=nextcloud
- MYSQL_PASSWORD=nextcloud
- APACHE_DISABLE_REWRITE_IP=1
- TRUSTED_PROXIES=172.21.0.0 172.21.0.1 172.21.0.2 172.21.0.3
- nextcloud:/var/www/html
# update the path of your config here (or comment out)
- ./nextcloud/config.php:/var/www/html/config/config.php
mysql:
image: mysql:8.0
- MYSQL_ROOT_PASSWORD=nextcloud
- mysql:/var/lib/mysql
mysql:
nextcloud:
nginx:
[nextcloud.config.php]
<?php
// You might need to add the following config parts to your existing config if you have one
$CONFIG = array (
// replace with your subdir name if necessary
'overwritewebroot' => 'nextcloud',
# docker hosts
'trusted_proxies' =>
array (
0 => '172.21.0.0',
1 => '172.21.0.1',
2 => '172.21.0.2',
3 => '172.21.0.3',
// add your domain here
'trusted_domains' =>
array (
0 => 'example.com',
'dbtype' => 'mysql',
// update this if necessary
'overwrite.cli.url' => 'http://example.com/nextcloud',
[nextcloud.service]
# /etc/systemd/system/nextcloud.service
[Unit]
Description=Nextcloud
Requires=docker.service
After=docker.service
StartLimitIntervalSec=0
[Service]
Type=oneshot
RemainAfterExit=yes
#Restart=always
RestartSec=10
User=root
# change to your directory with docker-compose.yml
WorkingDirectory=/root/apps
ExecStart=/usr/bin/docker-compose up -d
ExecStop=/usr/bin/docker-compose down
[Install]
WantedBy=multi-user.target
[nginx.rootdir.conf]
# This config file is for when setting nextcloud on the root of the domain/subdomain (https://example.com/)
events {
worker_connections 1024;
http {
server {
listen 443 ssl;
ssl_certificate /root/ssl/cert.pem;
ssl_certificate_key /root/ssl/key.pem;
# replace example.com with your domain or subdomain
server_name example.com;
access_log /dev/stdout;
error_log /dev/stderr;
add_header Strict-Transport-Security "max-age=15552000; includeSubDomains" always;
# Server configuration
location = /.well-known/carddav {
return 301 $scheme://$host/remote.php/dav;
location = /.well-known/caldav {
location ^~ /.well-known {
return 301 $scheme://$host/index.php$uri;
location / {
proxy_set_header Host $host;
# "nextcloud" can be replaced with your docker image name (also through docker-compose.yml)
proxy_pass http://nextcloud/;
[nginx.subdir.conf]
# This config file is for when setting nextcloud on the a subdirectory in the domain/subdomain (https://example.com/nextcloud/)
events {
http {
server {
listen 443 ssl;
location /nextcloud/ {
# replace nextcloud with your subdir name if needed
return 301 $scheme://$host/nextcloud/remote.php/dav;
return 301 $scheme://$host/nextcloud/index.php$uri;
