New Traefik set-up guide
Hello. I am redoing my treafik setup and I am looking for a newer guide for treafik, middleware-manager, and crowdsec. I am moving away from Pangolin because I am not using a vps. I have and older traefik set up, but it is having problems getting certificates from the dns challenge? Any help will be appreciated.
maybe you are getting timeout. did you backup your acme.json?
Share your traefik.yml
You don’t need a vps to use pangolin
This is what I was using before I used Pangolin. I have made a new acme.json and tried the one from Pangolin. I am wanting a traefik stack without Pangolin, gerbil, etc. I can’t access traefik dashboard. I get
Serving default certificate for request: “cloudflare-ech.com”
remote error: tls: bad certificate
Traefik global configuration
global:
checkNewVersion: true
sendAnonymousUsage: false
Enable traefik ui dashboard
api:
dashboard: true
insecure: true
crowdsec bouncer
experimental:
plugins:
bouncer:
moduleName: GitHub - maxlerebourg/crowdsec-bouncer-traefik-plugin: Traefik plugin for Crowdsec - WAF and IP protection
version: v1.4.2
#metrics:
influxDB2:
address: http://influxdb2:8086
token: pass
org: influx-org
bucket: influx-bucket
# addEntryPointsLabels: true
addRoutersLabels: true
addServicesLabels: true
pushInterval: 60s
Configuring Multiple Filters
log:
level: DEBUG # Set log level to DEBUG for more detailed logs
filePath: “/var/log/traefik/traefik.log” # Path to the Traefik log file
format: json # Log format (json or common)
accessLog:
filePath: “/var/log/traefik/traefik.log” # Path to the access log file
format: json # Access log format (json or common)
filters:
statusCodes:
- “200-299” # Log successful HTTP requests
- “400-599” # Log failed HTTP requests
bufferingSize: 0 # No buffering
fields:
headers:
defaultMode: drop # Drop all headers by default
names:
User-Agent: keep # Keep User-Agent header
The setting below is to allow insecure backend connections.
serverTransport:
insecureSkipVerify: true
Traefik entrypoints (network ports) configuration
entryPoints:
Not used in apps, but redirect everything from HTTP to HTTPS
http:
address: :80
forwardedHeaders:
trustedIPs: &trustedIps
# start of Clouflare public IP list for HTTP requests, remove this if you don’t use it; IP-Bereiche
- 103.21.244.0/22
- 103.22.200.0/22
- 103.31.4.0/22
- 104.16.0.0/13
- 104.24.0.0/14
- 108.162.192.0/18
- 131.0.72.0/22
- 141.101.64.0/18
- 162.158.0.0/15
- 172.64.0.0/13
- 173.245.48.0/20
- 188.114.96.0/20
- 190.93.240.0/20
- 197.234.240.0/22
- 198.41.128.0/17
- 2400:cb00::/32
- 2606:4700::/32
- 2803:f800::/32
- 2405:b500::/32
- 2405:8100::/32
- 2a06:98c0::/29
- 2c0f:f248::/32
# end of Cloudlare public IP list
http:
redirections:
entryPoint:
to: https
scheme: https
HTTPS endpoint, with domain wildcard
https:
address: :443
forwardedHeaders:
# reuse list of Cloudflare Trusted IP’s above for HTTPS requests
trustedIPs: trustedIps
# enable HTTP3 QUIC via UDP/443
#http3:
# advertisedPort: ‘443’
http:
tls:
# Generate a wildcard domain certificate
certResolver: myresolver
domains:
- main: example.com # change this to your proxy domain
sans:
. example.com’ # change this to your proxy domain
middlewares:
- security-headers@file # reference to a dynamic middleware for setting http security headers per default
- rate-limit@file # reference to a dynamic middleware for enabling rate limiting per default
- crowdsec@file # reference to a dynamic middleware for enabling crowdsec bouncer
providers:
providersThrottleDuration: 2s
File provider for connecting things that are outside of docker / defining middleware
file:
filename: /etc/traefik/fileConfig.yml
watch: true
Docker provider for connecting all apps that are inside of the docker network
docker:
watch: true
network: proxy # add Your Docker Network Name Here
endpoint: “tcp://socket-proxy:2375” # use socket-proxy for secure access to docker api
defaultRule: “Host({{ index .Labels \"com.docker.compose.service\"}}.example.com)” # change ‘example.com’ to your proxy domain
exposedByDefault: false
Use letsencrypt to generate ssl certificates
certificatesResolvers:
myresolver:
acme:
email: example.com # the email address used for ssl certificate registration
storage: ./acme.json
#httpChallenge: # acme http challenge; requires port 80 and proper dns entries
# entryPoint: http # specify the entry point for the HTTP challenge (adjust if needed)
dnsChallenge: # acme dns challenge; requires api token of dns provider
provider: cloudflare
propagation:
delayBeforeChecks: 240 # Delay before checking DNS propagation
# Used to make sure the dns challenge is propagated to the right dns servers
resolvers:
- “1.1.1.1:53”
- “1.0.0.1:53”
Step-by-Step
1. ACME / Certificate Handling
  • Ensure acme.json exists and has correct permissions:
    touch acme.json
    chmod 600 acme.json
  • In traefik.yml, confirm:
      myresolver:
        acme:
          email: your@email
          storage: /etc/traefik/acme.json
          dnsChallenge:
            resolvers:
              - "1.1.1.1:53"
              - "1.0.0.1:53"
  • Make sure the Cloudflare API token has Zone.DNS:Edit permissions.
2. Dashboard Access
  • The error cloudflare-ech.com suggests Traefik is serving its default cert instead of your domain cert.
  • Double-check:
    • Your DNS records (A/CNAME) point to the server.
    • The Host() rule in your router matches the domain you’re using.
    • Example:
      http:
        routers:
          traefik:
            rule: Host(`traefik.example.com`)
            service: api@internal
            entryPoints:
              - https
            tls:
3. CrowdSec Bouncer Integration
  • The plugin config looks fine, but ensure you also define the middleware in fileConfig.yml:
    http:
      middlewares:
        crowdsec:
          plugin:
            bouncer:
              enabled: true
              api_url: http://crowdsec:8080
              api_key: ${CROWDSEC_BOUNCER_KEY}
  • Then attach it to routers:
    middlewares:
      - crowdsec@file
4. Middleware-Manager
  • If you want a middleware-manager (like traefik-middleware-manager), it can simplify attaching defaults:
    • Security headers
    • Rate limiting
    • CrowdSec bouncer
  • acme.json exists, correct permissions.
  • Cloudflare API token scoped properly.
  • DNS records resolve to server IP.
  • Router Host() matches domain.
  • Dashboard router defined with TLS + certResolver.
  • CrowdSec bouncer middleware attached.
docker-compose.yml
  traefik:
    image: traefik:v3.1
    container_name: traefik
    command:
      - --configFile=/etc/traefik/traefik.yml
      - "80:80"
      - "443:443"
      - "8080:8080"   # dashboard/API
      - ./config/traefik/traefik.yml:/etc/traefik/traefik.yml:ro
      - ./config/traefik/rules:/rules
      - ./acme.json:/etc/traefik/acme.json
      - proxy
  middleware-manager:
    image: hhftechnology/middleware-manager:traefik-int
    container_name: middleware-manager
      - ./data:/data
      - ./config/traefik/rules:/conf
      - ./config/middleware-manager:/app/config
      - ./config/traefik:/etc/traefik
      - ./config/middleware-manager/templates.yaml:/app/config/templates.yaml
      - ./config/middleware-manager/templates_services.yaml:/app/config/templates_services.yaml
      - TRAEFIK_API_URL=http://traefik:8080
      - TRAEFIK_CONF_DIR=/conf
      - DB_PATH=/data/middleware.db
      - PORT=3456
      - PLUGINS_JSON_URL=https://raw.githubusercontent.com/hhftechnology/middleware-manager/traefik-int/plugin/plugins.json
      - TRAEFIK_STATIC_CONFIG_PATH=/etc/traefik/traefik.yml
      - ACTIVE_DATA_SOURCE=traefik
      - "3456:3456"
      - proxy
  crowdsec:
    image: crowdsecurity/crowdsec:latest
    container_name: crowdsec
      - ./config/crowdsec:/etc/crowdsec
      - ./data/crowdsec:/var/lib/crowdsec/data
      - /var/log:/var/log:ro
      - proxy
  crowdsec-bouncer:
    image: fbonalair/traefik-crowdsec-bouncer:latest
    container_name: crowdsec-bouncer
      - CROWDSEC_BOUNCER_API_KEY=${CROWDSEC_BOUNCER_KEY}
      - CROWDSEC_AGENT_HOST=crowdsec:8080
      - proxy
  proxy:
    external: true
traefik.yml
global:
api:
  dashboard: true
  insecure: false
log:
  level: INFO
accessLog: {}
entryPoints:
  http:
    address: ":80"
    http:
      redirections:
        entryPoint:
          to: https
          scheme: https
  https:
    address: ":443"
providers:
  docker:
    endpoint: "unix:///var/run/docker.sock"
    network: proxy
  file:
    directory: /rules
    watch: true
  myresolver:
    acme:
      email: you@example.com
      dnsChallenge:
        resolvers:
          - "1.1.1.1:53"
          - "1.0.0.1:53"
fileConfig.yml (dynamic middlewares)
http:
  middlewares:
    security-headers:
      headers:
        frameDeny: true
        sslRedirect: true
        contentTypeNosniff: true
        browserXssFilter: true
    rate-limit:
      rateLimit:
        average: 100
        burst: 50
    crowdsec:
      plugin:
        bouncer:
          enabled: true
Setup Checklist
  • touch acme.json && chmod 600 acme.json
  • Create proxy network:
    docker network create proxy
  • Set CROWDSEC_BOUNCER_KEY in .env (generate with cscli bouncers add traefik-bouncer).
  • Update you@example.com and example.com to your domain.
  • Ensure Cloudflare API token has Zone.DNS:Edit.
Ping me on cord HHF Technology for detailed step by step
Thank you for your help and time
This topic has had no activity for 30 days. It will close in 7 days unless someone replies.
  • Still broken? Reply with your current versions and logs, and it stays open.
  • Fixed it? Post what worked and mark it as the solution, so the next person finds it.
