Multi-agentcy doesn't work (traefik-log-dashboard discussion #86)
:speech_balloon: GitHub discussion traefik-log-dashboard #86 in Help, started by plakun on GitHub
Hello.
I try to use multiple agent installment with dashboard frontend in kubernetes, and looks like it doesn’t work.
Agents look like ok in dashboard, but i see in dashboard logs that it tries to connect to localhost instead of added agents.
External Image
External Image
External Image
Deployment:
apiVersion: apps/v1
kind: Deployment
metadata:
spec:
  replicas: 1
  selector:
    matchLabels:
      app: traefik-log-dashboard-app
  strategy:
    rollingUpdate:
      maxSurge: 1
      maxUnavailable: 1
    type: RollingUpdate
  template:
    metadata:
      labels:
    spec:
      containers:
      - image: hhftechnology/traefik-log-dashboard:latest
        resources:
          requests:
            cpu: 500m
            memory: 512Mi
          limits:
            cpu: 2000m
            memory: 2048Mi
        env:
        - name: PORT
          valueFrom:
            secretKeyRef:
              key: PORT
        - name: NODE_ENV
          valueFrom:
            secretKeyRef: …
💬 Join in here or [on GitHub](https://github.com/hhftechnology/traefik-log-dashboard/discussions/86).
<!-- hhf-forum-sync -->
your dashboard needs to be configured with the agents’ URLs and authentication tokens.
In Kubernetes, you need to:
  1. Create Kubernetes Services for each agent
  2. Configure the dashboard with agent URLs pointing to those services
  3. Add agents through the dashboard UI
Here’s the detailed solution for future reference:
Solution: Kubernetes Multi-Agent Setup
1. Create Services for Your Agents
First, you need to expose your agents as Kubernetes services. Since your agents are running in Podman, you’ll need to either:
Option A: Run agents in Kubernetes (Recommended)
Option B: Expose Podman agents to Kubernetes (if agents must stay in Podman)
Let me show you Option A (running agents in Kubernetes):
# Agent 1 Deployment
apiVersion: apps/v1
kind: Deployment
metadata:
  namespace: traefik-log-dashboard
spec:
  replicas: 1
  selector:
    matchLabels:
      app: traefik-agent
      instance: agent-01
  template:
    metadata:
      labels:
        app: traefik-agent
        instance: agent-01
    spec:
      containers:
      - name: agent
        image: hhftechnology/traefik-log-dashboard-agent:latest
        - containerPort: 5001
        env:
        - name: PORT
          value: "5001"
        - name: TRAEFIK_LOG_DASHBOARD_ACCESS_PATH
          value: "/logs/access.log"
        - name: TRAEFIK_LOG_DASHBOARD_ERROR_PATH
          value: "/logs/traefik.log"
        - name: TRAEFIK_LOG_DASHBOARD_AUTH_TOKEN
          valueFrom:
            secretKeyRef:
              key: agent-01-token
        - name: TRAEFIK_LOG_DASHBOARD_SYSTEM_MONITORING
          value: "true"
        - name: TRAEFIK_LOG_DASHBOARD_LOG_FORMAT
          value: "json"
        - name: TRAEFIK_LOG_DASHBOARD_GEOIP_ENABLED
          value: "false"
        volumeMounts:
        - name: traefik-logs
          mountPath: /logs
          readOnly: true
        - name: agent-data
          mountPath: /data
        resources:
          requests:
            cpu: 100m
            memory: 128Mi
          limits:
            cpu: 500m
            memory: 512Mi
        livenessProbe:
          httpGet:
            path: /api/logs/status
            port: 5001
          initialDelaySeconds: 10
          periodSeconds: 30
        readinessProbe:
          httpGet:
            port: 5001
          initialDelaySeconds: 5
          periodSeconds: 10
        hostPath:
          path: /var/log/traefik  # Adjust to your Traefik logs location
          type: Directory
      - name: agent-data
        persistentVolumeClaim:
          claimName: agent-01-data
# Agent 1 Service
apiVersion: v1
kind: Service
metadata:
spec:
  selector:
    app: traefik-agent
    instance: agent-01
  - name: api
    port: 5001 …
plakun commented on GitHub:
Well, i did exactly what you wrote in p.4, option 2 :slight_smile:
Dashboard is in k8s.
Traefik is on linux virtual machine, agent is on the same vm in podman.
I have added agents through dashboard UI, added theres keys, i can see agents in UI. But dashboard still tries to connect to default agent on localhost ignoring my settings.
I see another ticket where topic starter acted exactly how it is written in manual and he has same problem - Multi Agent Not Working · Issue #89 · hhftechnology/traefik-log-dashboard · GitHub
Btw there is no wget in dashboard image to trobleshoot connectivity as it said in p.5.
kubectl get pods -n traefik-log-dashboard
NAME                                     READY   STATUS    RESTARTS   AGE
traefik-log-dashboard-55786d8659-tw7rk   1/1     Running   0          2d19h
kubectl exec -it traefik-log-dashboard-55786d8659-tw7rk -n traefik-log-dashboard -- wget -O- http://traefik-agent-01:5001/api/logs/status
2025-10-20T04:48:21.321366Z: 2025-10-20T04:48:21.321072Z: executable file `wget` not found in $PATH: No such file or directory
hhftechnology replied in a thread on GitHub to plakun:
I see another ticket where topic starter acted exactly how it is written in manual and he has same problem - https://github.com/hhftechnology/traefik-log-dashboard/issues/89
you can ship the health check for the dashboard, till i figure how to archive this optimal.
currently i don’t have perfect fix, and i don’t want to apply a bandage.
other than that, multi agent work just fine
osmollo commented on GitHub:
Hi!
I have the same problem but im using docker-compose to deploy the containers:
I have 2 agents in different servers behind a traefik proxy and the dashboard instance is in a thind server with connectivity with agents
agent-1:
  traefik_agent:
    container_name: traefik_agent
        PORT: '5000'
        TRAEFIK_LOG_DASHBOARD_ACCESS_PATH: /logs/access.log
        TRAEFIK_LOG_DASHBOARD_AUTH_TOKEN: <token_agent_1>
        TRAEFIK_LOG_DASHBOARD_ERROR_PATH: /logs/traefik.log
        TRAEFIK_LOG_DASHBOARD_GEOIP_CITY_DB: /geoip/GeoLite2-City.mmdb
        TRAEFIK_LOG_DASHBOARD_GEOIP_COUNTRY_DB: /geoip/GeoLite2-Country.mmdb
        TRAEFIK_LOG_DASHBOARD_GEOIP_ENABLED: true
        TRAEFIK_LOG_DASHBOARD_LOG_FORMAT: json
        TRAEFIK_LOG_DASHBOARD_SYSTEM_MONITORING: true
    image: hhftechnology/traefik-log-dashboard-agent:dev-dashboard
    labels:
        traefik.docker.network: traefik
        traefik.http.routers.traefik_agent-secure.rule: Host(`agent.mydomain1`)
        traefik.http.services.traefik_agent.loadbalancer.server.port: '5000'
    - traefik
    - traefik:/logs:ro
    - agent_geoip:/geoip:ro
    - agent_positions:/data
agent-2:
  traefik_agent:
        LOG_LEVEL: debug
        PORT: 5000
        TRAEFIK_LOG_DASHBOARD_AUTH_TOKEN: <token_agent_2>
    labels:
        traefik.http.routers.traefik_agent-secure.rule: Host(`agent.mydomain2`)
    - traefik
    - traefik:/logs:ro
dashboard:
  traefik_dashboard:
    container_name: traefik_dashboard
        NODE_ENV: production
        PORT: 3000
    image: hhftechnology/traefik-log-dashboard:dev-dashboard
    labels:
        backup: false
        caddy: log.mydomain
        caddy.import: tinyauth_forwarder *
        caddy.reverse_proxy: '{{upstreams 3000}}'
        caddy_ingress_network: traefik_dashboard
    - traefik_dashboard
And this is the agent configuration in dashboard:
  "version": "1.0",
  "exportDate": "2025-10-20T16:29:21.097Z",
  "agents": [
      "id": "agent-1",
      "name": "agent-1",
      "url": "https://agent.mydomain1",
      "token": "<token_agent_1>",
      "location": "off-site",
      "number": 1,
      "tags": [] …
osmollo replied in a thread on GitHub to osmollo:
Hi!!! I was testing the dashboard with the browser’s devtool opened and the error 500 is due to the request to the agent api really attacks to dashboard domain:
External Image
It works!!!
After reading the other discussion about this issue (Multi Agent Not Working · hhftechnology/traefik-log-dashboard · Discussion #90 · GitHub) I updated the docker image with tag dev-dashboard and voilá!
Thank you so much
using dev-dashboard with pv in k8s realy helped, thx.
Now I see that when switching the data source, some fields get “stuck” — their data doesn’t update until the browser page is reloaded.
@​plakun @​osmollo check the docs for issues . latest release should fix all the pending issues. image: hhftechnology/traefik-log-dashboard-agent:2.1.0
You should fix docs in Release Release v2.1.0 · hhftechnology/traefik-log-dashboard · GitHub
there is wrong tag “v2.1.0”
osmollo replied in a thread on GitHub to hhftechnology:
Hi! thank you so much for the update…
@​hhftechnology In the release notes, i saw that default port for agent has changed to 8080, is it correct? I guess that is a breaking change that should be more vissible. Also in release notes, the link to CHANGELOG.md is not working, that file doesn’t exist
Regards
Hi!
@​hhftechnology I was trying to update my containers and none of those docker images exist:
External Image
hhftechnology replied in a thread on GitHub to hhftechnology:
Remove the v.
Yes , I will do it today
oh f*ck! it was @​plakun said in the below comment, sorry
