New releases of mbombeck/healthlog are posted here automatically.
Join @releases-healthlog to get a DM and a bell for every release.
The first Saturday release, as promised in 1.49. It’s a patch, so nothing new to learn, but it’s a big one: just over a hundred fixes, a good part of them from your reports. If 1.49 felt a bit rough in places, this is the week of sanding that followed.
Restoring your own export into the same account no longer doubles your readings. Glucose keeps its value through a CSV round trip, a date-range export includes the last day you picked, and the CSV import stops reading a day-first date as another day. Garmin, Oura and Strava history imports ride out a provider outage instead of stopping, and a restart no longer starts them twice. FHIR, Gadgetbridge, Health Connect and Apple Health imports refuse broken or oversized files with a clear reason and skip a single bad sample instead of failing as a whole. Bulk actions on up to 100 documents in the vault now take a handful of database writes instead of one per document.
A dose reported by a pill box or another integration settles the dose that’s overdue, not one still hours ahead. A snooze stays with the dose you set it on. Editing a dose time no longer drops an earlier open dose. Live Activities started over the push relay now end when their reason goes (a withdrawn consent, an edited dose time) and come back when you undo a take. A guardian can now remove a medication entered on a managed profile by mistake.
With two devices reporting the same day, readiness, the “vitals out of range” flag and the briefing read from the source you ranked first, like the metric page already did. Readiness counts a reading on the day of your own time zone. Sleep on the Insights overview counts nights instead of stage fragments, so a 7-hour night no longer reads as an hour and a bit. A high stress score reads as high. Readings you take only a few times a month now get a usual range. “Today so far” works again for accounts whose step totals arrive as day totals.
The iPhone app gets the server’s texts in its own language, and an account that never picked one gets the language of the device asking. Signing in on a phone set to another language no longer resets yours. Two settings saved at the same moment, from two tabs or from phone and browser, keep both changes.
A crafted long password can no longer stall the server, and new passwords are capped at 1024 characters (existing ones keep working). The logs no longer name reproductive state or other health classifications. Mental-health questionnaire results no longer reach the Coach or a connected AI assistant, as the Mental wellbeing page always said. API answers are marked as not to be cached by browsers or proxies, and an admin’s “Force logout” now signs the iPhone app out too. The image also picks up the patched libzstd from the base image.
Take a backup first. With the backups volume the container writes a pre-migration dump on its own. There is one migration, 0571, which adds a small table for snoozes. Going back to 1.49.0 means restoring that dump with the 1.49.0 image, not just starting the old image. If you run your own PostgreSQL, keep its major at or below the client tools in the image; the app now tells you plainly when it isn’t. The full list is in the changelog.
@ch3funio tried an empty AI chain on purpose, tested with a slow local model, read the logs line by line and measured the token counts that showed what was wrong. @ferges123 sent an analysis precise down to the lines involved and then spotted a second path. @sdrburgess brought the numbers that pinned down a resting-pulse problem, @kruemelro the side-by-side screenshots, @2q2code a screen recording, @mills1975 a screenshot of the setup check, @aw23edfr4 traced the PostgreSQL version trap, and @VocAddict reported the Garmin backfill failure. Thank you all, this release is a lot better for it.
And a big thank you to everyone who supports HealthLog through GitHub Sponsors or Buy Me a Coffee. Your donations keep the servers and the push relay running, and the relay is the reason a dose you log on one phone now shows up on your other one. I still find it a little unreal that people put their own money behind something I started for myself, and I don’t take it for granted.
See you next Saturday for 1.50.
