Maestro-Docker Container Orchestration Made Simple
Maestro
Docker
Python
Maestro is an elegant and lightweight solution for Docker container orchestration that simplifies the complex symphony of container deployments. Like a conductor leading an orchestra, Maestro harmoniously manages your Docker containers with precision and grace.
:bullseye: Features
  • :counterclockwise_arrows_button: Automated container orchestration and lifecycle management
  • :rocket: Boot-time container initialization
  • :video_game: On-demand container reconstruction
  • :musical_keyboard: Interactive container management interface
  • :musical_score: Selective container exclusion
  • :globe_with_meridians: Universal Docker environment compatibility
:rocket: Prerequisites
  • Python 3.6 or higher
  • Docker Engine
  • Docker Compose
  • Appropriate Docker permissions for the executing user
:package: Installation
  1. Clone the repository:
git clone https://git.hhf.technology/hhf/maestro.git
cd maestro
  1. Configure your environment by editing maestro.conf (see Configuration section below)
  2. Ensure scripts have executable permissions:
chmod +x *.py
:gear: Configuration
maestro.conf
The docker-composer.conf file conducts your container orchestra with these essential parameters:
Parameter Description Example
compose-path Directory containing Docker container folders /opt/docker/containers
exclude-containers List of containers to exclude from management ["container1", "container2"]
Example configuration:
compose-path: /opt/docker/containers
exclude-containers:
  - monitoring
  - internal-proxy
Directory Structure
Your container directory should be organized as follows:
compose-path/
โ”œโ”€โ”€ container1/
โ”‚   โ””โ”€โ”€ docker-compose.yml
โ”œโ”€โ”€ container2/
โ””โ”€โ”€ container3/
:musical_score: Usage
Available Scripts
Script Description Use Case
composer.py Main orchestration script Automated container management on system boot
re_compose.py Manual reconstruction tool On-demand container rebuild and reconfiguration
basic_management.py Interactive management interface Basic container operations (start, stop, remove)
Running the Scripts
All scripts must be executed from the same directory as docker-composer.conf.
  1. Automated Boot Management
./composer.py
  1. Manual Container Reconstruction
./re_compose.py
  1. Interactive Container Management
./basic_management.py
System Integration
To enable automatic container management on system boot:
Using systemd
  1. Create a service file:
sudo nano /etc/systemd/system/docker-composer.service
  1. Add the following content:
[Unit]
Description=Maestro Docker Container Orchestration
After=docker.service
Requires=docker.service
[Service]
Type=simple
ExecStart=/path/to/docker-composer.py
WorkingDirectory=/path/to/maestro
User=your-user
Group=docker
[Install]
WantedBy=multi-user.target
  1. Enable and start the service:
sudo systemctl enable docker-composer
sudo systemctl start docker-composer
:locked: Security Considerations
  • Ensure proper file permissions on configuration files
  • Run scripts with minimal required privileges
  • Regularly audit excluded containers list
  • Monitor container logs for unexpected behavior
:wrench: Troubleshooting
Common issues and solutions:
  1. Permission Denied
    • Ensure the executing user is in the docker group
    • Check file permissions on scripts and configuration
  2. Configuration Not Found
    • Verify script execution from correct directory
    • Check docker-composer.conf exists and is readable
  3. Container Exclusion Issues
    • Verify container names match exactly
    • Check for whitespace in configuration
:handshake: Contributing
  2. Create your feature branch
  3. Commit your changes
  4. Push to the branch
  5. Create a new Pull Request
:page_facing_up: License
This project is licensed under the Apache License 2.0 - see the LICENSE file for details.
:clap: Acknowledgments
  • Inspired by Umbrelโ€™s container management approach
  • Built with Python and Docker
  • Community contributions and feedback
For bug reports and feature requests, please use the comments below for bugs and other requests.
:glowing_star: Why Maestro?
Like a masterful conductor, Maestro brings harmony to your Docker container orchestra. It simplifies complex container management tasks into elegant, automated solutions. Whether youโ€™re managing a small ensemble of containers or a full symphony of services, Maestro ensures everything plays together perfectly.
