Logrotate Configuration Guide for Docker Services in Pangolin Stack
This guide provides logrotate configurations for all services identified in the docker-compose and configuration files. Place these configurations in separate files within /etc/logrotate.d/ for proper management.
1. Traefik Logs
File: /etc/logrotate.d/traefik
/root/config/traefik/logs/*.log {
    daily
    rotate 4
    missingok
    notifempty
    compress
    dateext
    dateformat -%Y-%m-%d
    create 0644 root root
    postrotate
        docker kill --signal=USR1 $(docker ps -q -f name=traefik)
    endscript
2. CrowdSec Logs
File: /etc/logrotate.d/crowdsec
/root/config/crowdsec_logs/*.log {
    daily
    rotate 7
    missingok
    notifempty
    compress
    dateext
    postrotate
        docker kill --signal=USR1 $(docker ps -q -f name=crowdsec)
    endscript
# Specific rotation for auth.log
/root/config/crowdsec_logs/auth.log {
    daily
    rotate 7
    missingok
    notifempty
    compress
    dateext
    postrotate
    endscript
# Specific rotation for syslog
/root/config/crowdsec_logs/syslog {
    daily
    rotate 7
    missingok
    notifempty
    compress
    dateext
    postrotate
    endscript
3. Pangolin Application Logs
File: /etc/logrotate.d/pangolin
/root/config/pangolin/logs/*.log {
    daily
    rotate 5
    missingok
    notifempty
    compress
    dateext
    postrotate
        docker kill --signal=USR1 $(docker ps -q -f name=pangolin)
    endscript
Implementation Instructions
  1. Create Configuration Files:
sudo touch /etc/logrotate.d/{traefik,crowdsec,pangolin}
  1. Set Proper Permissions:
sudo chmod 644 /etc/logrotate.d/{traefik,crowdsec,pangolin}
  1. Test Configurations:
sudo logrotate -d /etc/logrotate.d/traefik
sudo logrotate -d /etc/logrotate.d/crowdsec
sudo logrotate -d /etc/logrotate.d/pangolin
Configuration Details Explained
Common Parameters
  • daily: Rotate logs every day
  • rotate N: Keep N rotated logs before deleting
  • missingok: Don’t error if log file is missing
  • notifempty: Don’t rotate empty log files
  • compress: Compress rotated logs using gzip
  • dateext: Add date extension to rotated logs
  • dateformat: Format for the date extension
  • create: Create new log files with specified permissions
Service-Specific Settings
  1. Traefik:
    • Rotation: 4 days (moderate retention for web traffic)
    • Path matches docker volume mount
    • Uses USR1 signal for graceful log rotation
  2. CrowdSec:
    • Rotation: 7 days (longer retention for security logs)
    • Separate configurations for auth.log and syslog
    • Includes all logs in crowdsec_logs directory
  3. Pangolin:
    • Rotation: 5 days (balanced retention)
    • Handles application-specific logs
    • Uses same signal-based rotation mechanism
Monitoring and Maintenance
  1. Regular Checks:
# Check logrotate status
cat /var/lib/logrotate/status
# Test configurations
logrotate -d /etc/logrotate.d/*
# Force rotation (if needed)
logrotate -f /etc/logrotate.d/*
  1. Log File Ownership:
# Ensure proper ownership
sudo chown root:root /etc/logrotate.d/*
sudo chmod 644 /etc/logrotate.d/*
  1. If logs aren’t rotating:
    • Check file permissions
    • Verify paths exist
    • Review logrotate status file
    • Test configuration with debug flag (-d)
  2. If services aren’t reopening log files:
    • Verify docker container names
    • Check if services handle USR1 signal
    • Review service logs for rotation-related errors
Remember to adjust rotation periods and other parameters based on:
  • Available disk space
  • Compliance requirements
  • Log analysis needs
  • Backup schedules
