Installing MinIO in Proxmox LXC with Hetzner Storage Box
This guide will walk you through the process of setting up MinIO in a Proxmox LXC container and configuring it to use Hetzner Storage Box as the backend storage.
- Proxmox VE server
- Hetzner Storage Box
- Root access to Proxmox
- Basic understanding of Linux commands
1. Create LXC Container
First, we’ll create a new LXC container in Proxmox:
- Log into your Proxmox web interface
- Click “Create CT” (Container)
- Configure the following settings:
- General: Choose Ubuntu 22.04 template
- Disk: At least 8GB
- CPU: 2 cores minimum
- Memory: 2GB minimum
- Network: Configure with a static IP
2. Configure Container Features
Enable necessary features for the container:
# On Proxmox host
pct set <container-id> -features mount=1,nesting=1
3. Mount Hetzner Storage Box
- Install necessary packages in the container:
apt update
apt install davfs2
- Create mount directory:
mkdir -p /mnt/storage-box
- Configure WebDAV credentials:
echo "/mnt/storage-box <username> <password>" >> /etc/davfs2/secrets
chmod 600 /etc/davfs2/secrets
- Add to /etc/fstab:
https://<username>.your-storagebox.de /mnt/storage-box davfs _netdev,user,rw,uid=1000 0 0
- Mount the storage:
mount /mnt/storage-box
4. Install MinIO
- Download MinIO binary:
wget https://dl.min.io/server/minio/release/linux-amd64/minio
chmod +x minio
mv minio /usr/local/bin/
- Create MinIO user:
useradd -r minio-user -s /sbin/nologin
- Create necessary directories:
mkdir -p /mnt/storage-box/minio-data
chown -R minio-user:minio-user /mnt/storage-box/minio-data
5. Configure MinIO Service
- Create systemd service file:
cat > /etc/systemd/system/minio.service << EOF
[Unit]
Description=MinIO
Documentation=https://min.io/docs
Wants=network-online.target
After=network-online.target
AssertFileIsExecutable=/usr/local/bin/minio
[Service]
WorkingDirectory=/usr/local/
User=minio-user
Group=minio-user
EnvironmentFile=/etc/default/minio
ExecStart=/usr/local/bin/minio server /mnt/storage-box/minio-data --console-address ":9001"
Restart=always
LimitNOFILE=65536
[Install]
WantedBy=multi-user.target
EOF
- Create environment file:
cat > /etc/default/minio << EOF
# MinIO access key and secret key
MINIO_ROOT_USER=admin
MINIO_ROOT_PASSWORD=your-strong-password
EOF
- Start and enable MinIO service:
systemctl daemon-reload
systemctl enable minio
systemctl start minio
6. Configure Firewall
Allow access to MinIO ports:
# If using UFW
ufw allow 9000/tcp # API port
ufw allow 9001/tcp # Console port
7. Access MinIO
- API Endpoint:
http://<container-ip>:9000 - Console:
http://<container-ip>:9001
Log in using:
- Username: admin
- Password: (the one you set in /etc/default/minio)
Performance Considerations
- Enable compression in davfs2:
echo 'use_compression 1' >> /etc/davfs2/davfs2.conf
- Adjust cache settings:
echo 'cache_size 256' >> /etc/davfs2/davfs2.conf
Common Issues
Mount failures:
- Check WebDAV credentials
- Verify network connectivity
- Check storage box quota
Permission issues:
- Verify ownership of directories
- Check SELinux/AppArmor settings
Performance issues:
- Adjust davfs2 cache settings
- Check network latency
- Monitor I/O operations
Logs
Check MinIO logs:
journalctl -u minio -f
Security Recommendations
Enable TLS:
- Generate certificates
- Configure MinIO to use HTTPS
- Update service file accordingly
Configure access policies:
- Create separate users
- Set up bucket policies
- Use IAM policies for fine-grained control
Backup Considerations
Regular configuration backup:
tar -czf minio-config-backup.tar.gz /etc/default/minio /etc/systemd/system/minio.service -
Consider setting up MinIO replication to another instance for data redundancy
Enable Prometheus metrics:
echo "MINIO_PROMETHEUS_AUTH_TYPE=public" >> /etc/default/minio -
Monitor key metrics:
- Storage usage
- Network bandwidth
- Request latency
- Error rates
Maintenance
Regular updates:
systemctl stop minio wget https://dl.min.io/server/minio/release/linux-amd64/minio -O /usr/local/bin/minio chmod +x /usr/local/bin/minio systemctl start minio -
Regular health checks:
- Check storage box mount status
- Verify backup integrity
- Monitor system resources
