To achieve your goal of using Immich for family photo sharing while maintaining individual user logins via Authentik, you can implement a solution involving scope mapping. This approach allows multiple family members to log in with their individual credentials but still share a single Immich account for photo and metadata access.
Proposed Solution
Step 1: Configure Authentik for Scope Mapping
Create a New Scope Mapping:
- Navigate to the Customization > Property Mappings section in Authentik.
- Create a new scope mapping with the following details:
- Name: Choose an appropriate name (e.g., “Immich Family OAuth”).
- Scope Name: Set this to
email. - Expression: Use an expression that maps all family users to a single shared email address. For example:
if request.user.email in ['user1@example.com', 'user2@example.com']: return 'familylogin@email.com' else: return request.user.email
- This expression checks if the logged-in user is one of the family members and returns the shared email for Immich.
Configure OAuth Provider Settings:
- Go to your Immich OAuth provider settings in Authentik.
- Under Advanced Settings > Scopes, ensure that you keep the necessary scopes (like
openid) and add your newly created scope mapping.
Step 2: Modify Immich OAuth Settings
Update Immich Configuration:
- In your Immich instance, navigate to the OAuth settings.
- Ensure that the OAuth provider is set up to accept the new scope mapping you created in Authentik.
Testing:
- Have each family member log in using their individual Authentik credentials.
- Verify that upon logging into Immich, they are recognized as the shared user (
familylogin@email.com).
Step 3: Set Up Guest Access
Create a Guest User:
- In Immich, create a separate user account for guests (e.g.,
guestuser@email.com). - Limit permissions appropriately so that guests can view but not modify shared content.
Configure Guest Access in Authentik:
- You can set up another scope mapping or rule that directs any guest login attempts to this guest user account.
Additional Considerations
- User Permissions: Ensure that permissions are correctly set so that family members can upload and manage photos while maintaining privacy from guests.
- Testing and Iteration: After setting up, conduct thorough testing with different user scenarios to ensure that all mappings work as intended.
By following these steps, you can effectively manage a shared photo library in Immich while allowing individual logins through Authentik, thus simplifying photo sharing and metadata access for your family.
