The guide you sent was about how to setup crowdsec without docker, on a VPS, to work with Pangolin. So i donΒ΄t have a compose for crowdsec.
You should not use docker crowdsec if you install this on VPS.
Guide for Debian and Ubuntu Systems
This document provides instructions for installing and configuring CrowdSec on Debian and Ubuntu.
1. Install CrowdSec
The installation process begins with adding the official CrowdSec repository and then installing the package using the
aptpackage manager.
- Execute the installer script to add the CrowdSec repository to your systemβs sources.
curl -s https://install.crowdsec.net | sudo bash
- Install the CrowdSec agent.
sudo apt update sudo apt install crowdsec -y ...
I mean, would you still recommend to install crowdsec that way on a VPS, or would you just install it via docker? Because that way, gives me the error I described.
this is a great guide. I am nearly through it but a bit stuck on step 3.3
you mention /etc/crowdsec/acquis.yaml
but I donβt have that file.Φ« Do I need to create it?
Or has it been replaced with /etc/crowdsec/config.yaml?
If the latter, can you give a bit more context about where those entries should go? right at the end? or do they need to go into a specific section?
Many thanks!
Mike
Have been following this, very useful so thanks.
Curious about why you suggest running crowdsec natively on a VPS is the way to go, rather than Docker? Just making troubleshooting a bit harder as most of the guides are based on Docker.
There also seems to be a step missing about how to turn on traefik access logs so that crowdsec has something to read. Iβm just trying to get that working now.
And for anyone else looking for /etc/crowdsec/acquis.yaml , they seem to have moved to a directory approach, where you can store multiple different sources e.g.
mike@bla-1:/etc/crowdsec/acquis.d$ ls -al
total 24
drwxr-xr-x 2 root root 4096 May 20 17:32 .
drwxr-xr-x 15 root root 4096 May 19 20:29 ..
-rw-r--r-- 1 root root 132 May 19 20:29 appsec.yaml
-rw-r--r-- 1 root root 112 May 20 17:31 pangolin.yaml
-rw-r--r-- 1 root root 387 May 19 20:20 setup.linux.yaml
-rw-r--r-- 1 root root 365 May 19 20:20 setup.sshd.yaml
My current issue is that my pangolin-traefik bouncer doesnβt seem to be pulling anythingβ¦
ββββββββββββββββββββββββββββββββββββββββββββββββββββββββββββββββββββββββββββββββββββββββββββββββββββββββββββββββββββββββββββββββββββββββββββββββββββββββββββββββββββββββββββββββββββββββ
Name IP Address Valid Last API pull Type Version Auth Type
cs-firewall-bouncer-1779218773 βοΈ api-key
cs-firewall-bouncer 127.0.0.1 βοΈ 2026-05-20T16:41:17Z crowdsec-firewall-bouncer v0.0.34-debian-pragmatic-amd64-4144555453620958398aee64253dfd90bbc1f698 api-key
pangolin-traefik βοΈ api-key
Any ideas what to check?
Thanks,
Mike
@cmj01 you will have your files under
Ah thatβs great, thanks!
