How a Forgotten Postiz auto-setup.sh Left a Week-Old Zombie Process on My Homelab
How I Tracked Down a Week-Old Zombie Process on My Homelab Server (and What Actually Caused It)
The Symptom
One quiet Sunday afternoon the system status script spat out the classic warning:
=> There is 1 zombie process.
A single zombie is almost never urgent, but this one had been hanging around since 27 September. Time to dig in properly.
Step 1 – Confirm the Zombie Exists
ps aux | awk '$8 ~ /Z/'
Output:
homelab  1935019  0.0  0.0      0     0 ?        Z    Sep27   0:00 [auto-setup.sh] <defunct>
There it is: PID 1935019, owned by the homelab user, state Z, command name [auto-setup.sh] <defunct>.
The square brackets and <defunct> are the kernel’s way of saying “this process is already dead; only the process-table entry remains.”
A cleaner, more structured view:
ps -o pid,ppid,user,stat,start,cmd -p 1935019
    PID    PPID USER     STAT  STARTED CMD
1935019 1934909 homelab  Z      Sep 27 [auto-setup.sh] <defunct>
Step 2 – Find the Parent
The PPID column already told us the parent is 1934909. Let’s inspect it:
ps -o pid,ppid,user,stat,start,cmd -p 1934909
1934909 1934883 homelab  Ssl    Sep 27 temporal-server --env docker start
And confirm the binary:
ls -l /proc/1934909/exe
lrwxrwxrwx 1 homelab homelab 0 Sep 27 10:39 /proc/1934909/exe -> /usr/local/bin/temporal-server
Command line:
cat /proc/1934909/cmdline | tr '\0' ' '; echo
So the long-running parent is Temporal Server (the workflow engine), started with --env docker.
What Actually Happened
At some point on 27 September an auto-setup.sh script was executed under the homelab user. That script finished (or was killed), but its parent — the Temporal Server process — never called wait() / waitpid() to collect the child’s exit status.
The result is a classic zombie: the process is gone, its memory and file descriptors are released, but the process-table slot remains until the parent reaps it.
(Note: official Discourse does not ship an auto-setup.sh. The script came from a different setup tool — in this case a Postfix-related installation helper that the Temporal environment had pulled in or that had been run manually.)
Why Zombies Are (Usually) Harmless
A zombie consumes:
  • one process-table entry
  • a few bytes of kernel memory for the exit status
It uses zero CPU and zero user-space memory. A single zombie that has been sitting there for a week is therefore almost never a problem. You only start caring when:
  • you have dozens or hundreds of them, or
  • the process table is approaching pid_max.
Remedies
Option 1 – The polite way (preferred)
Send SIGCHLD to the parent so it is forced to reap its children:
kill -CHLD 1934909
Then check again:
If the zombie is gone, you’re done.
Option 2 – Restart the parent cleanly
Because the parent is a long-running service (temporal-server), the cleanest operational fix is to restart it the normal way (systemd, docker compose, whatever you use to manage it). When the parent exits, the zombie is re-parented to PID 1 (systemd), which immediately reaps it.
# example – adjust to your actual unit / compose service
systemctl restart temporal
# or
docker compose restart temporal-server
Option 3 – Nuclear option (only if the parent is stuck)
kill 1934909          # SIGTERM
# wait a few seconds
kill -9 1934909       # only if it refuses to die
After the parent dies, the zombie vanishes within a second or two.
Option 4 – Just leave it
If the system is otherwise healthy and you don’t want to touch Temporal right now, you can safely ignore a single long-lived zombie. It will disappear the next time the parent is restarted for any other reason.
Quick Diagnostic Cheat-Sheet
# List all zombies
# Structured view of a specific zombie
ps -o pid,ppid,user,stat,start,cmd -p <zombie-pid>
# Inspect the parent
ps -o pid,ppid,user,stat,start,cmd -p <ppid>
ls -l /proc/<ppid>/exe
cat /proc/<ppid>/cmdline | tr '\0' ' '; echo
# Force the parent to reap
kill -CHLD <ppid>
Take-aways
  1. One zombie is almost never an emergency.
  2. Always look at the parent, never try to kill the zombie itself.
  3. Long-running services (Temporal, databases, message brokers, etc.) are the most common culprits for leftover zombies because they often forget to handle SIGCHLD for short-lived helper scripts.
  4. Keep a note of any one-off setup scripts (auto-setup.sh, install helpers, etc.) that run under long-lived processes — they are frequent sources of this exact problem.
That’s the full post-mortem of a week-old [auto-setup.sh] <defunct> on a Temporal-powered homelab. lol
